Question about Desa International GWP20T GLOWARM Wall Mounted Panel Heater
Piolet light keeps going out
I need a phone # so I can talk to some one about my piolet light going out on my natural gas wall heater. I checked for leaks like it told me to on the side panel of the heater, but there was no leaks. So I checked the instruction on the side panel & they told me that it needs fixed by a profestional. Who do I contact to get it repaired before winter gets here?
muttandjeff
  • 359 Answers
SOURCE: heater will not stay lit
sounds like the thermocouple is going out this is the part the flame from the pilot burns on and tells the gas valve to stay open by producing a small amount of electrical current in milli-amps these can be purchased @ a good hardware store and you must position as it is when it comes out , and must be the same length , make sure to connect to gas valve clean and tight , also is there a moisture trap in the line if so you might need to turn off gas and make sure it is free of moisture , this is a good place to start with these items
Posted on Jan 17, 2009
  • 16 Answers
SOURCE: piolet will not light- no spark
on what type of heating appliance
Posted on Aug 17, 2009
jusjunk
  • 72 Answers
SOURCE: my mr heater won't stay running
No pilot in this unit.
Check the thermocouple and its connections.
The thermocouple is the device that has the copper cable connecting it to the vave unit. It leads up into where the burner can "heat it up". This indicates to the controll valve that the gas is actually burning and keeps the valve open.
Posted on Jan 06, 2010
SOURCE: I have a natural gas infared 30,000 BTU heater
IT COULD BE THE AIR GAS MIXTURE, ALSO COULD HAVE WRONG SIZE FUEL ORFICE
The sir gas is contorled by an opening ajustment where the gas comes out of orfice. (usualy it turns to make smaller or lager opening. More or less air}
Posted on Feb 17, 2010
  • 674 Answers
SOURCE: piolet light wont stay lit. I changed the
On some pilots there are small holes in the pilot tip for air to enter right about where the tip is attached to the pipe. These sometimes get clogged with dust or lint and will not let the pilot burn because it doesn't have the right fuel/air mix.
Posted on Mar 17, 2010
How to relight piolet
The H Series electronic ignition does not have a pilot light. It has an electronic ignition that, if all conditions are met, will start the heating process
Aug 09, 2014 | Hayward H Series Pool & Spa Heater...
The heater piolet light goes out when you move to use the heater
There is a thermo coupler that shuts the gass off if it is ba. It is locacted just in front of the pilot flame It has to sense the pilot to let the gss through. It is an easy fix and inexpensive.
Nov 12, 2009 | Empire DV-215 Direct Vent Natural Gas...
The piolet light will not stay lit on a GE Profile Smart Water heater.
Make sure there is not a direct draft hiting heater. this wil always blow out flame.
It could be thermo-cuppling. If this is bad,it wont leave gas come in to keep piolet light lite. hope this helps. :)
Jul 05, 2009 | Water Heaters
Piolet stays on,. burners do not go on heater will not start
could be many things ,start with pressure switch,check for continuity with multi-meter.if press switch isnt sensing water flow, your unit will not call for heat.let me know
Jul 04, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
PILOT LIGHT WILL NOT LIGHT
the thermocouple not only keeps the pilot on but lets the gas valve know its okay to open on a call for heat, remove your thermocouple and clean it with a fine grit sandpaper and if this doesn't work replace it all together.
Jun 02, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Lighting the pool heater
You will need to buy a new thermo couple 8.00 part from ace it is the little copper line close to piolet flame,it sences the piolet and allows the gas to open and feed,it is wore out,burned out,replace.
Mar 30, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
How flem sensor works in furness
After you hearthe click from the ignitor your piolet will light. the flame sensor (mounted next to the piolet (tip in the flame) ) will sence the heat from the piolet sending a milivolt siginal back to the ignation board. once the board knows there is a piolet and the system is safe the main valve will open igniting the burner trays.
Mar 16, 2009 | Goodman GMS90703BXA Heater
Pilot light wont lit up
Change The Thermostat Cause If Your Getting Gas But The Water Heater Doesn't Detect The Heat It Will Close The Valve. When Lighting You Hold The Button Down For About 30 seconds so the thermostat will detect flame and stay lit. Check To Make Sure The Thermostat Is Where It Should Be. Heres A Picture Of What It Will Look Like.
You Can Replace Them If Need Be Will Be Available At Sears Or Home Depot. Also They May Sell Them At other Local Hard Ware Stores.
Happy Fixing And Thanks For Using Fixya.com
Sincerely,
Michael Scott
Jan 19, 2009 | Vanguard International Vanguard BY Rheem...
The pilot won't light up
Hi Welcome to fixit.com
Make sure the gas/propane is on and or working elsewhere in the house. If the piolet wont light ....and its a standing flame piolet ....its the thermocouple gone bad. Please rember to leave me some positive feedback ! Thanks !
Dec 16, 2008 | Bosch AquaStar Indoor Natural Gas Tankless...
Desa International GWP20T GLOWARM  Wall Mounted Panel Heater Logo
140 people viewed this question
Top Desa International Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
mcijoe
Level 1 Expert
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
