Question about Microsoft Windows Vista Ultimate Edition
DOOM won't run in Vista ...what can I do also Duke, Hexen, etc.
  • 3 Answers
Are you certain your DOOM game is compatible with your Vista Operating System? Vista comes in 32 bit and 64 bit versions. Software compatibility depends on the game being designed for the specific OS you have. If you're running 64 bit Vista, I'm guessing your game is designed for Windows XP or 32 bit Vista.
Posted on Oct 01, 2009
I turned on duke 200 and as soon as i removed the stand! The display went off. Since then, nothing is shown on the display and the bike does bot even start. Just wondering what could be the fault?
Hi, Malkeet and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Main fuse or circuit breaker may be blown or faulty.
10. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below Good luck and have nice a day.
KTM Duke 200 refuses to start What do you think can be the problem
HELP Starting problem KTM Duke 125
What to do When Your Motorcycle Won Start
2012 Duke 125 200 Repair Manual pdf
Apr 17, 2016 | Motorcycles
Radio, doom light and door buzzer won't work in 1999 toyato corolla
Check the fuse in the fuse box.
The fuse box is under the steering wheel or under the front hood.
Oct 18, 2012 | Toyota Corolla Cars & Trucks
Original doom
It is not compatiable to vista... You have to check compatiability of the game before installing. Or u can try using these steps
right click on shortcut
select properties
there press CTRL+TAB for windows change until
There u can find compatiablitiy check box
select the check box and select the WINDOWS2000 compatiabilty and run the game
HAVE FUN
GOODLUCK :)
Jan 02, 2008 | Microsoft Windows Vista Ultimate Edition
Can someone please help
Ok, the PSP emulator is a program that emulates the work of PSP on your computer, and take a portion of your PC's CPU to emulate the PSP's Processor. Or you can say it's a program that runs your PSP games through a window. To Run your "Doom on PSP" I can paste some text from the readme.txt inside this file: http://psp-news.dcemu.co.uk/files/doompspv005plus.zip Release Notes for Doom-PSP 0.05 plus: To Install fw 1.0 and 2.0(with loader) 1. Create Doom dir under Games. 2. Copy save, wads, inst, config.ini, and timidity.cfg into doom folder. 3. copy eboot.pbp from fw10 into doom dir. 4. copy any main wads into doom/wads dir and pwads into doom/wads/pwads dir. 5. launch game, select wads and play! to set up controls press L+R+Start and follow instructions. fw 1.5 1. Create Doom dir under Games. 2. Create Doom% dir under Games. 2. Copy save, wads, inst, config.ini, and timidity.cfg into doom folder. 3. copy eboot.pbp from fw15/Doom into doom dir. 5. copy eboot.pbp from fw15/Doom% into doom% dir. 4. copy any main wads into doom/wads dir and pwads into doom/wads/pwads dir. 5. launch game, select wads and play! to set up controls press L+R+Start and follow instructions. Then give us feedback. Play nice with your PSP. Goodluck
May 17, 2007 | Sony PlayStation Portable (PSP) Console
Microsoft Windows Vista Ultimate Edition Logo
96 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
