Kenmore washer mdl#110.23832100 spin cycle motor
Kenmore washer mdl#110.23832100 ,during spin cycle spin cycle motor runs, pump runs, drum does not until i lift and close lid then it spins out normally when i lift and close the lid it sounds like something engages the motor and all is well untill the next spin cycle and i gotta do it again
    Problem Solver:
  • 5 Answers
Its going to be only 1 of 2 or maybe both things, on your washer its going to be a faulty transmission that is stuck in nuetral OR will be a bad clutch/brake assembly that is stuck or has a broken finger that is catching after you slow it down but usually it would make a bad clicking noise if that was the issue so plan on the transmission. Its actually pretty easy to do if you have some mechanical ability. Another rare but possibility would be the block that holds the tub on the tranny shaft, but you would hear a bad noise also when you lifted the lid.
Posted on Oct 01, 2009
    President:
  • 744 Answers
Hello, looks like your lid switch is on it's way out, replace it...you will find it normally about half way down under the lid. If not there you will find it in the control panel on the right side next to the water level control. The reason it works some times and not others is because some times it fails to push the lid switch down far enough to engage. the lid switch is a safety divice inteneded to stop you opening the lid while in a high speed spin. If you have any other questions please feel free to comment again. Mike
Kenmore agitates doenst spin
You will have to look at the inside of the washer when in spin cycle to see what is going on. Is the spinner motor not engaging the drum? Is the spinner working at all? It sounds like the spinner isn't being moved against the drum before the spin cycle starts. Most washers use a seperate spinner motor, which is lifted off the drum by a relay and / or solenoid and if one or more of those is malfunctioning, it will cause your described problem.
Dec 22, 2007 | Kenmore Elite HE4 Electric Dryer
Have old kenmore elite he3 washer. Have wet laundry after spin out. Have checked ball be low drum, replaced strainer, pump motor, cleaned all hoses. Did a test run in the drain and spin cycle. For like 7...
If the washer is taking more water during spin, then most likely it is thinking the water level is low for the load. It is a smart washer and tries to adjust water according to load. This can mean the level sensor is giving wrong sensor. I would try to run the washer with a cleaning agent (not bleach) available from specialist stores or washing machine retailers.
Also observe if the drain pump is running all through the spin cycle. If not that is likely causing water to remain. But controller is thinking there is no water and not starting the pump when required.
You should be able to locate the parts in these diagrams.
KENMORE ELITE Washer Parts Model 11049962600
Sep 20, 2014 | Washing Machines
The washer loads water and pumps it out like normal, but it does not spin. It goes through the cycle but with no spinning of the drum. Why dose it not spin?
broken belt on drum drive motor? bad motor on drum? bad connection on motor? if you remove the oval panel on the back you can see the motor, belt and drum assembly
Feb 12, 2011 | Kenmore Front Load Washer
Washer not spinning in spin cycle
My maytag neptun mah4000ww washer stop spinning in spin cycle.
Now it stop spin even during regular cleaning cycle. What to do?
How mach it may cost?
Jul 10, 2010 | Maytag Neptune Washer
THE DRUM OF THE WASHER DOESN'T SPIN
drive coupler, or something stuck in between the tubs. there is a couple of things that can do that
Oct 07, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/ http://www.davesrepair.com/DIYhelp/DIY285753.htm
Sep 01, 2009 | Kenmore Washing Machines
My washer does not spin or move during wash cycle the moter runs but nothing is moving.
Hi, this motor has faulty windings, causing it to lock up and not rotate the drum/basket. replace this motor asap if possible.
May 29, 2009 | Kenmore Washing Machines
Kenmore washer 80 series misses spin during wash.
You may need to replace the motor coupling between the pump and motor...
Apr 07, 2009 | Kenmore Washing Machines
Washing Machines Logo
228 people viewed this question
Top Washing Machines Experts
