HP L7780 wont print in black. It prints in grey, I have replaced the print cartridges and the printhead is good
  • 58 Answers
Open solution center-->settings-->printer settings-->color tab, change the settings from there.
Posted on Oct 02, 2009
Officejet pro l7780 not printing
OfficeJet 7880 Not Printing
A little more information would have been helpful in troubleshooting this problem. Did the printer ever work correctly? Did it just start printing yellow lines one day? Has it been out of use for a long time or, did you buy it in this condition. Also, is your computer a Windows PC or a Mac and which version of the OS are you using?
If you don\'t have the manual, you need to download one. I saw a link in a previous post or you can go to HP.com. The manual is crap as far as troubleshooting but it has all the part numbers of ink cartridges and printheads.
From the skimpy info you have supplied, I am going to assume there is something wrong in the ink supply system.
1. First you need to print a test page to find out if anything other than yellow can get to the paper. Find the HP Printer Utility. Again, not knowing what computer and OS you are using, I can\'t give you any explicit info. On Windows you might find something in Control Panels>Printer or under Programs you might find the HP Printer Utility. On a Mac maybe System Preferences>Printers or Go>Applications>HP Control Center.
2. If it only prints yellow boxes, or yellow boxes with streaks, you can run the Clean Printheads utility and reprint the test page. If you get more yellow or other colors start to show up, this indicates there\'s something wrong in the whole ink supply chain.
The HP 7xxx printers use the CYMK color system and have separate ink cartridges for each color: cyan, yellow, magenta, and black(K). In addition, the printheads are separate from the ink cartridges: yellow/black printhead and cyan/magenta printhead.
3. The problem could be in the ink cartridges or the printheads, or both. If the printer has been sitting for a long time, the ink will gel and clog up the whole system. Check the ink cartridges first. Are all four of them installed? Are they HP brand? Take them out one at a time, shake them and the reinstall them. Print another test page. Did anything change?
4. If more colors are printing, even with streaks, you should probably replace all the cartridges with GENUINE HP cartridges that are not expired. This could cost you $50-$60 on an eBay purchase but if you buy non-HP, or expired cartridges, you will not be a happy camper, long term. If you want to do this on the cheap, buy a black cartridge and see if you can at least start printing text. If you\'re making progress, you can buy the color cartridges later.
5. If replacing the cartridges fixed the problem, you\'re home relatively "free". If you have to replace either or both of the printheads, this can be expensive. They can run from $50-$100 each, so you\'ll have to make a decision on how much you want to spend on a printer that sold for $175 at Costco 6-7 years ago. Don\'t get me wrong, this is one of HP\'s better print engines but you will have to make an economic decision based on how much it\'s going to cost to bring this printer back to life. You can probably pick up a used 7xxx printer on Craigslist for $50-$75.
Hope this helps.
Sep 22, 2014 | HP Officejet Pro L7780 All-In-One InkJet...
I installed a new black cartridge and my L7780 is still telling me to replace the empty ink cartridge
You may want to try the clean the printhead:
  1. Press the Setup button.
  2. Select Tools.
  3. Select Clean Printhead.
Oct 29, 2017 | HP Officejet Pro L7780 All-In-One InkJet...
The following printhead has a problem black/yellow the printer will not print. These are new ink cartiladge
Hello and welcome to FixYa!
In the HP OfficeJet Pro L7780 the printheads are actually separate from the ink cartridges. In your case, it sounds like the black/yellow head has worn out and will need to be replaced. The good news is, this is a user replaceable part. The bad news is, the replacement heads are not cheap. Amazon has the HP 88 Black/Yellow printhead listed currently for about $61.
http://www.amazon.com/HP-Yellow-Officejet-Printhead-Packaging/dp/B000BO9L8M/ref=dp_cp_ob_e_title_0
YouTube has a nice video that explains how to install the printheads here:
http://www.youtube.com/watch?v=8Zl0LUxBSvg
I hope this helps!
Mar 02, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
Printer is printing gray and not black
Hve you checked the level of your Black ink cartridge. Normally when it runs a little low the black comes out all faded and grey. If it is still resonably full then I suggest you give it a good clean.
Once this is done print a couple of test pages top see if there is any change.
Feb 10, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
Alignment failed refer to device documentation hp L7780
You need to remove the black/yellow printhead and dab it on a damp paper towel until you see a solid line of black ink on the towel when you press it. It won't pass the alignment until all colors work properly.
Nov 19, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Black ink problem with printout on hp7780
Always try replacing the ink cartridges first.
It sounds like the print heads in the 7780 are bad. Don't confuse the ink cartridges with print heads. The cartridges fit inside the print heads. You will need to change the heads. Here is a link to HP's how-to.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00841890&tmp_track_link=ot_faqs/top_issues/en_us/c00841890/loc:1&lc=en&dlc=en&cc=us&lang=en&product=2512010
Could have the same problem with the Dell.
Jun 01, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Generic black ink cartridge causing black ink to not print
Never mix dye and pigment inks/machines Head could be screwed Try copying many black text only pages up to 200 but run head clean after 50 or so Inkypete
Apr 20, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Printer won't print black ink
The HP88 black cartridge contains is a pigment ink type which I've found from painful experience has just not been tested properly by HP for use with this printhead.
The problem will not be the cartridge but most likely the printhead which will have clogged due to heat, lack of humidity, etc..
The best solution I've found to date is to purchase a new printhead and find a 3rd party ink supplier with dyebase black ink instead of the pigment type. The printhead is much less likely to clog and can cope with a wider range of temperatures and environments compared to the original black.
I hasten to add this is based on my experience in four primary schools and from three printers at home all of which use the HP88 cartridge... Warm and dry environments just stop this printhead after a short period of time whereas cool, humid spaces seem to keep the printers working much longer.
Hope this helps.
Feb 25, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Printhead Problems
Since buying the L7780 printer for our business office two years ago, the printer has been a work horse for us. The problems I've seen online about scanning, paper jams and ink cartridge issues have been none existent. Then it was time to change the print head. The L7780 printed several pages before the print head error message appeared and the printer ceased printing. We tried all the solutions offered online including another print head and cartridges but to no avail. We were ready to buy a new printer. Then a member our team whom we dubbed “Service Tech 130” came up with the solution. Service Tech 130 simply pried the chips off both print heads with a screw driver and super glued the old chip onto the new print head. Now the printer has been working as if nothing was every wrong.
For this to work for those of you having the same problem, you would have to be in possession of the old print head that worked prior to the error. Attached is an image showing the location of the chip. Hope this works for you as it did for us.9101d4c.gif
Apr 02, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Problem printing with HP Business inkjet 1200
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
Oct 28, 2007 | HP Business Inkjet 1200dtn Printer
151 people viewed this question
k24674
jasbo
jasbo
