Question about HP PSC 1315 All-In-One InkJet Printer
I have a hp psc1315xi printer and all of a sudden it stopped printing from my pc; i did change some settings because i wanted to print on a smaller piece of paper, but i believe i put them all back, can you help me? prior to this it was working just fine.
    Scholar:
  • 67 Answers
If you are using Windows XP or Vista download this utility, install it and run it it would show up the any errors and you can fix them .
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-56143-4&lc=en&dlc=en&cc=us&product=374572&os=228〈=en
Good luck
Brad
Posted on Oct 01, 2009
Brother MFCJ870DW Cuts Off/Chops Off/Truncates Left Side Return Address By About Half An Inch On #10 Com Envelope, Suddenly Started Happening
Check carefully that you have specified it to use the # 10 and that the format does not include a wide margin. If that fails, try printing the Return address 'right justified' and see what happens.
Feb 01, 2014 | Office Equipment & Supplies
When printing 4x6 recipe cards on the food network the cards print in very small type - it used to print normal size - then one day it started printing smaller ?? thanks alex
Try reseting the printers settings into defaults, its in the menu if your printer has a lcd screen that is.
also if that doesnt solve the problem some settings have been changed on the pc side, would need to figure out what exactly has changed or who has changed them.
Apr 24, 2008 | Office Equipment & Supplies
My hp photosmart 475 will not print 5 x 7, how do I change it?
that is in the printer settings when printing a document or photo if the original is larger or smaller, then you need to select that size from the printer settings panel when trying to print.
this link may help too
May 17, 2012 | HP Refurbished Photosmart 475 Compact...
HP Laserjet 4700dn suddenly stops printing in color although the cartriges are new and were working well. What is the problem?
>Go to menu settings, select set as default setting, do color calibration.. try for the print..> take configuration page, verify the firmware version, if low, download from hp web site, up load as specified..
Feb 01, 2012 | HP LaserJet 4700DN Printer
I have a HPC7280 all in one. it is asking to insert a memory card for copies. why? how do i get around that.
It sounds to me like you have selected an option to print directly from a memory card at one time. Here are excerpts from the user manual for your machine to change printer settings:
Change the print settings
You can customize the print settings of the HP All-in-One to handle nearly any print
task.
Windows users
Before you change print settings, you should decide if you want to change the settings
for the current print job only, or if you want to make the settings the defaults for all
future print jobs. How you display print settings depends on whether or not you want
to apply the change to all future print jobs or just to the current print job.
To change the print settings for all future jobs
1. In the HP Director, click Settings, point to Print Settings, and then click Printer
Settings.
2. Make changes to the print settings, and click OK.
To change the print settings for the current job
1. On the File menu in your software application, click Print.
2. Make sure the HP All-in-One is the selected printer.
3. Click the button that opens the Properties dialog box.
Depending on your software application, this button might be called Properties,
Options, Printer Setup, Printer, or Preferences.
4. Make changes to the print settings, and click OK.
5. Click Print or OK in the Print dialog box to print the job.
I believe that this should help you get around your issue. Here is a link to the entire user manual for future reference.
http://h10032.www1.hp.com/ctg/Manual/c00276605.pdf
Dec 22, 2010 | HP PSC 1610 All-In-One InkJet Printer
Have a hp photosmart premium c309 and have changed the ink cartridge and the black ink is not printing well. All the other colors prink well
HP Photosmart Premium C309 not printing black
Got that problem also, Black would not print but dark grey would be printed ???
What i did and it worked was reset to factory settings, unpluging the printer for ± 25 seconds
holding 3 and # for and other 25 seconds went and after pitting power back on
then re-enterring your setting, all went fine
http://h30434.www3.hp.com/t5/Other-printing-questions/Photosmart-C309-suddenly-stopped-printing-black-ink-any-solution/m-p/495549#M30719
Hopping this will help others
Nov 10, 2010 | Office Equipment & Supplies
Printer suddenly stopped working with quickbooks but will still work with all other programs. window states: change port assignments or reinstall software. printer is hooked up wirelessly
  1. Open the QuickBooks sample company and try to print the same form or type of form. If it prints successfully, your company data, form template, or customized report may be damaged.
  2. Reopen your company file and try to print an uncustomized (standard/default) form template or non-memorized report. If the issue occurs again, refer to Verifying and rebuilding the QuickBooks company data and then attempt to print again.
  3. If you were printing a batch of forms in QuickBooks, attempt to print a single form. If successful, try printing smaller batches.
  4. If you were able to print from QuickBooks in the past from this company file:
  5. Turn off the printer, restart your computer, and then turn the printer back on.
  6. In QuickBooks, choose File > Printer Setup and check the printer settings for the specific form you're trying to print.
  7. Click Help in this area for more detailed instructions on these settings.
  8. Ensure that you have the latest printer drivers for your printer. Go to the manufacturer's website to download and install the most current drivers.
  9. Replace the QuickBooks Qbprint.qbp file:
  10. Close QuickBooks.
  11. Rename the qbprint.qbp file.
  12. Open QuickBooks and attempt to print again.
  13. If the issue persists, repair the QuickBooks installation.
Mar 07, 2010 | HP Officejet Pro L7680 All-In-One Printer
How do I change the print size my printer prints
The size font used by the printer is changed in the application that you are using to print.
Most applications have a fint setting that you can make the print larger or smaller.
Feb 07, 2010 | HP Photosmart 2610 All-In-One InkJet...
Printer not printing documents in que
my printer hp psc1315xi all in one printer copier, scanner will not print any documents, not even a test print, there is also a doucument in it that am not able to delet from the printer
Jan 22, 2009 | HP PSC 1315 All-In-One InkJet Printer
How to print smaller coupons.
I am answering this assuming your printer is attatched to a pc and not a standalone unit. You need to define what size you want your prints to be in the printer settings or properties menu window of your pc itself. Click on your printer icon and go to properties, or it should open up this window when you first go to print a job. Know your required size and specify it to the program you are in, ie i assume because you are printing a flier, you have scanned it first, so once it is scanned, open up the image in windows viewer, and tell it what size you want it to print out. Auto printing buttons on a printer are set to manufacturers default settings to a standard size.
Aug 13, 2007 | HP PSC 2175 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
49 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
