Question about Amana AOCS3040 Electric Single Oven
When burners are turned on Code F1 shows up and starts beeping
    President:
  • 744 Answers
Hello, an F1 error code for an Amana refers to a failed watchdog circuit or ERC (Electronic range control) and need to be replaced. This can be located inside the control panel and is normally accessed from the back of the range. If you have any other questions please feel free to comment again. Mike
Posted on Oct 01, 2009
Oven is beeping and showing f1
Hello Charlie,
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced
GENE
Nov 06, 2011 | Neff B1421 Electric Single Oven
Amana self cleaning oven Model ACS7270AS, Seril 10924419AT F1 And F5 code come on control panel and continuous beep. All burners and other oven controls seem to come on ok. How do we clear the beeping...
Both F1 and F5 are the code for a board failure; it would need to be replaced. What you could try is disconnect the oven for a few minutes and then turn the power back on. If that does not do the trick you would need a board
May 24, 2011 | Ovens
Error code F1 flashes and beeps on control panel
Hi
Error code F1 means a faulty keypad or connection problem with the keypad. You will need to check the connections of the keypad with the main board. Pressing Start/Cancel key may temporariliy resolve the issue, however, to resolve the issue you might need to change the keypad if the wiring to the keypad seems ok.
1. Disconnect power to oven.
2. Gain access to the back of the clock (electronic range control or ERC).
3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
4. Make sure everything is clear and will not short out when power is turned back on.
5. Turn power back on to stove.
6. Watch for the F1 and listen for the beep.
If it still shows as F1 then you'll need to replace the keypad.
Hope it helps...
Daniel
Aug 13, 2010 | Magic Chef Ovens
Dacor oven beeps and shows F1 code
-F1- Alarm “System Watchdog Circuit”
The system will detect a failure in the internal watchdog element relay circuits and will activate a
cancel feature. F1 will be displayed in the time digits and will beep until the cancel button or another
function is selected. An F1 failure could be detected in cook or time of day mode. With an F1 failure
the ERC is picking up a command to supply heat without receiving an input from the membrane. The
watch dog circuit is designed to prevent this.
If the beep continues after pressing cancel check the main control (ERC)
Dacor
Aug 20, 2009 | Dacor ECS130 Epicure Electric Single Oven
Top burner is stuck on and F1 showed on the display
Hi Krista,
Unfortunately, F1 is a fault code for a failed electronic control... it'll have to be replaced. The reason the burner is on is that the relay controlling it has welded closed allowing power to the burner full time.
If you choose to repair this yourself, could you provide the model number? That way, I could pull up schematics and stuff I need to further help you.
SG
Apr 05, 2009 | Kenmore Ovens
After a power outage oven will no longer work
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 02, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
Fault Code F1
Frigidaire oven fault code F1 means the electronic clock control is bad and should be replaced. That is the electronic control board that shows your clock display and is also called clock or eoc, depending on your model.
Mar 25, 2008 | Frigidaire (FEB30S7D) Oven
Error code F1 and beeping
Means replace the $300 control board. And if your like me.....do it twice within 12 months.
Jan 30, 2008 | Jenn-Air JJW8530C Expressions Collection...
"F1" error code on Magic Chef gas range Model 3488XRA
the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
Jan 03, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Amana AOCS3040 Electric Single Oven Logo
294 people viewed this question
Top Amana Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Ismael Rodriguez...
Are you an Amana Oven Expert? Answer questions, earn points and help others
