Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Does not wash properly, does not drain
While washing the dishwasher was making a heavy clunky noise. When done there was some water left in the bottom of the drain. The dishes were not rinse thouroughly.
    Scholar:
  • 146 Answers
Pull your spray arms and make sure the holes are clean. Next with the spray arm off check your impellors and make sure they are not broken or worn. Last but not least check your drain and make sure it flows smoothly. One of these is causing you problems.
Posted on Dec 21, 2007
Our Haier HDC1804TW counter-top dishwasher does not complete the washing cycle. It stops after 90 minutes which should be 115 minutes for heavy washing according to the manual. The washing light is...
Since mine does the very same thing, it's my guess that is the sterilising cycle as by this point it has already washed, done a short fill to remove any remaining detergent, and two rinses. I'm also assuming the second short fill is just to cover the heating element and/or to to generate an amount of steam having being heated by the element (I'm basing that assumption on the heat of the dishes at the end of end of the cycle and the heat of the water when it drains)
Mar 05, 2011 | Haier HDC1804TW Dishwasher
Water will not drain out
Check the drain filter located at the bottom of the wash tub. Clean if clogged. The pump noise could be due to non availability of the washed water continuously due to clog.
Clean the drain filter. Check the final drain output after the pump(hose) for free flow if you have connected it to a drain system.
Aug 03, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
We discovered broken glass dish in bottom of dishwasher with some pieces below the bottom pump area. Shortly after the washer is making a louder noise during operation time. The water pump is quite when...
sounds like you have broken glass in the wash pump you will have to remove pump from sump and clear also check the drain pump.good luck let me know how it goes
Jun 22, 2010 | KitchenAid KUDK03ITBK Built-in Dishwasher
Miele Dishwasher G841 - Water not draining after wash cycle
If you suspect the dish washer, try discharging the drain in a bucket. After the drain cycle check the wash tub. If water is still left, you have to clean the drain filter attached to the bottom. Refer user guide.
The final drain end of the dish washer where you discharge, the fixing junction has to be cleaned, incase it is clogged.
Jun 01, 2010 | Miele 24 in. Touchtronic Platinum Built-in...
Not cleaning fully - tablets left in bottom of unit - some of runners on bottom tray missing
Well first of all you can check the Water-inlet valve
Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need replace it.
After then you can check the Drain valve,  that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Please post comments if you need more help or information..............
Good Luck!!
Thanks
Jan 07, 2010 | Zanussi 24 in. DE6544 Built-in Dishwasher
Kenmore 655 Ultra Wash- dishes not getting clean and have a residue on them when done washing. Arms appear to swing freely.
Does the dishwasher drain the water properly at the end of the rinse cycle. Meaning, is there any leftover water at the bottom of the dishwasher.
Sep 01, 2009 | Kenmore Dishwashers
Kitchenaid dishwashes makes wining noise during wash
It sounds as if there is something in the bottom part of the dishwasher arm (it sprays the water around the bottom of the dishwasher). I would suggest that you take out the baskets and then remove and clean all of the parts that water comes out of as well as the bottom drain. If this works or does not, I would also suggest that you run an empty load using 1/4 cup vinegar. Hope this helps!
Mar 13, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Not working 100%
One the water in the bottom of the machine is more than likely becuase it is not draining properly reason?
Thenpump or drain pipe could be blocked or the filter or outlet at the bottom of the unit is clogged with food,Two are you useing dishwasher powder or blocks and not dishwashing liquide,three chech the wash arem holes are not clogged with food all holes must be open if two or so clogged it will spin the arm but will not wash properly and naturally will not rinse properly they must aslo be clean.Last make sure the machine is heating the water and not trying wash cold do this by stopping the machine mid cycle and open the door is there steam if so cool leave it to finnish the wash so clean filter ,wash arms,drain pipe blow into it and see if ant food particals appear in the machine,
Hope this helps
Jan 23, 2009 | Frigidaire 24 in. FDB635RF Built-in...
LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
Hope this helps!
Oct 22, 2008 | LG LDF6810ST Stainless Steel Built-in...
Soap foam left after dishes are washes. can't dry properly. and always has soapy water left in it and on the washed plates.
Try adding some liquid fabric softener to your dishwasher. This will reduce the foaming. Also make sure there is rinse agent in the proper dispenser, this will reduce the soap sticking to the dishes. Finally, reduce the amount of dishwasher powder or liquid you put in for each wash. If water remains in the bottom of the dishwasher, check if there is a filter or drain hose clogged. Is the dishwasher drain hose connected an undersink garbage disposer? If yes, make sure it is run periodically so it does not clog up.
Aug 09, 2008 | Dishwashers
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
50 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
