Question about Arrow T50P ARROW STAPLE GUN
Stapler is jambed - Arrow T50P ARROW STAPLE GUN
  • 101 Answers
A staple is probably jammed in between the housing and the ram look at the bottom front where the staples are ejected you may need a small screwdriver to reach up inside and loosen the staple from the ram ... a little WD-40 may help also ... dont forget to rate me thx:)
Posted on Oct 01, 2009
My stapler won't wrap staples around the paper. What can I do?
Amazon.com : The Classics Staple-Free Stapler the "Paper ...
www.amazon.com/The...Staple-Free.../B000IGCUZE
Amazon.com, Inc.The Classics Staple-Free Stapler the "Paper Grip" with 5 Sheet Capacity, Kid Safe (TPG-133). by The ... Gift-wrap available. Enter your ..... It is hard to get the correct pressure on the paper--too much and it tears, not enough and won't fasten.
PaperPro Prodigy One-Finger Desktop Stapler, 25 Sheet ...
www.amazon.com/PaperPro...Stapler/.../B000GGY9L...
Amazon.com, Inc.
Rating: 4.4 - ‎399 reviews
Gift-wrap available. ... One-Finger Stapling Technology only needs one finger to stapleup to 25 sheets ... The Paper Pro Prodigy Stapler is the most distinctive, powerful non-elictric stapler available. .... This is such a great, easy to use, and quality stapler that once you use it, you won't want to use a ... A near-great stapler.
Swingline® Full-Strip Stapler, 15 Sheet Capacity ... - Staples
www.staples.com > Office Supplies > Office Basics > Staplers
Staples Inc.Stapler can easily handle up to 15 sheets of paper at a time and has ... refill this Swingline stapler with a full strip of standard office staples, so it won't run out of ...
Staples One-Touch™ Plus Desktop Flat Stack Full Strip ...
Jan 10, 2016 | Swingline 87845 Optima ® 40 Desk Stapler
Bostitch electric stapler wont open
Hello, Go to this website for support number and downloading of the operators manual for the model of stapler. Bostitch Office Products Staplers Pencil Sharpeners Hole Punchers Tools...
May 01, 2014 | Stanley Bostitch B8 Electric Stapler
E000532-8001
E532 Main cause Stapler shift motor (M10) Stapler shift home position sensor (P16) Detection The stapler shift home position sensor does not go OFF when the stapler shift motor is driven for 4 sec. The stapler shift home position is not detected when the stapler shift motor is driven for 4 sec.
Sep 29, 2012 | Canon imageRUNNER 8500 Copier
Swingline optima 40 how do you open and close the stapler?
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy Instructions
    • 1 Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
    • 2 Load the heavy-duty staples into the staple tray.
    • 3 Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Read more: How to Load a Swingline Heavy Duty Stapler ' eHow.com http://www.ehow.com/how_5822366_load-swingline-heavy-duty-stapler.html#ixzz1bVwG5bBn
Oct 21, 2011 | Swingline ® High-Capacity Heavy-Duty...
Stapler will staple ok then it will jamb and break staple in half,and driver will stick but you can put driver back and will run for a short time then has same problem. It also is breaking up staples as it...
It sounds like the gun is working properly but is having feeding problems. First, make sure you are using the proper staples for your gun. Senco makes three versions of the SKS(XP) stapler: The SKS L11-17 drives 18 gauge, 1/4" staples. The SKS M12-17 drives 18 gauge, 3/8" staples. The SKS N12-17 drives 16 guage, 7/16" staples. None of them use staples over 1 1/2" long and each gun will only shoot the staples it is set up for. If you are using the correct staples make sure the rail and nose peices are clean and the feeder shoe and staples are riding freely on the rail and the feeder spring holds them firmly forward in the gun. Lastly check the tip of the driver to make sure it is square, it should not be rounded or have any chips out of it.
Dec 07, 2010 | Senco SKS 18 Gauge Stapler
WHERE do I open it to refill it??
Located on the end opposite of where the staples come out, there is a spring loaded cap. Push it in toward the base of the stapler and slightly down to release the retaining hook. then let the spring release the pressure rod and pull it out. Connedted to the end of the rod you will see a plunger that is shaped like a short run of staples. Make a mental note of how and where this plunger slides into the base of the stapler. Place a run of staples into the stapler in the same manner that the plunger fits then replace the plunger into the same place following the run of staples. Compress the spring into the stapler and attach the hook as it was. Now you are ready to work.
NOTE: If you cannot compress the spring enough into the stapler you have inserted too many staples, just remove some of the run of staples and try again.
Nov 12, 2010 | Arrow T50P ARROW STAPLE GUN
Electric stapler won't staple; Panasonic as300 will fire but no staples come out and I do not see any jammed staples when I open the cassette.
On the side of the stapler are the instructions - no joke - stick a flathead at the lip of the metal striker and push the flat head up - while pushing the realse at the back - use A LOT of force - that is how ours popped open. It was jammed in the back with several staples that were not visible as a jamb in the front where the staples come out. the whole magazine will pop out when it is freed.
Sep 13, 2009 | Office Equipment & Supplies
Depressing top black bar doesn't cause stapler to work.If you take it apart as if to put staples in it you can see the part that would push the staple out and it is already down.and won't retract up
There may be a staple or a piece of a staple jambed in the driver. Sometime taking a screw driver and carefully pushing the drive back will clear the problem.
Mar 02, 2009 | Tools & Hardware - Others
Narrow crown stapler won't fire
If the gun has never been opened, the problem could be a lack of oil or worse, too much of the wrong kind of oil. No oil causes parts to stick. Too much of the wrong kind of oil caused the orings to swell and jamb parts. Carefully open gun to preserve head gasket and check for piston travel all the way down to the bumper. Piston should not be too tight, nor drop to the bottom under its own weight. The driver has a groove on one side that should align with the grove in the nose and it should not be bent. Next check the head valve by pushing the valve into the head with your thumbs. the valve should travel about 3/8 inch. If stuck apply air pressure to hole where gasket sits on head. The valve will pop out. Clean and lube parts replace orings or upper bumper if cracked. Assemble and test. Parts are not expensive at www.toolpartsdirect.com, enjoy
Nov 26, 2008 | Senco SNS41 16Ga Stapler 1" 2"
Arrow T50P ARROW STAPLE GUN Logo
468 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
