Question about Samsung Instinct Cell Phone
Frozen screen My screen has been frozen for about 4 hours. I have taken the battery out about 3 times.. no luck!
  • 438 Answers
Update the firmware dude...thats the problem.....
Posted on Oct 01, 2009
How do i get my asus tablett out of frozen
Assuming the restart option isn't available after pressing and holding the start button for a few seconds; you can let the battery drain ... but it may take a few hours. (Adapter must be unplugged). Then connect the adapter and restart. Another way is to remove the battery.
After the tab restarts check if system updates are taken care of. If the problem happens because of a particular app consider to uninstall that app.
Feb 17, 2015 | ASUS MeMO Pad HD 7
Frozen mobile touch screen
sounds like you bricked it. try taking the battery back out than hold the power button for 5-10 seconds than put the battery back in and try it than.
Dec 10, 2013 | Samsung Cell Phones
I have a gateway pc laptop that is 3 years old. It was working fine this morning. I had to manually power it down because my screen was frozen.(this happens from time to time) When I tried to power it...
Try removing battery and power cord let the laptop discharge. Plug the power cord in without battery after 1/2 hour. If it repeats the same thing plug a regular monitor into the vga output see if you get picture if so it maybe a lose connection to lcd screen or bad lcd screen.
Dec 30, 2009 | Computers & Internet
Nokia E71 - Keyboard frozen
Your firmware seems to have got corrupted. get it re-installed. Do not do it yourself. What happens is that when you do it over the net, only the corrupted files are replaced. If you get it done from Noia Care, the have the download of the whole SW. Over 200 MB of download in total. The install is full and total. It takes about half an hour.
Aug 23, 2009 | Nokia E71 Smartphone
My LG Viewty phone has been frozen for 4 days. The only thing I can do is answer calls and make calls to numbers in my call register. Everything seems to still work perfectly, exept for the screen. I've...
My LG KU990 viewty screen has frozen....meaning...the touch screen doesn't respond when I press it.
I can answer the phone and only call numbers i've already.
Does anyone know how I can fix this
I stupidly did not get it insured
I've turned it off and left it off for some time, taken the sim card out, but this doesn't help. Does anyone have a solution?
Aug 17, 2009 | LG KU990 Viewty
Mousepad Frozen
the acer has a driver and software restore program on your desktop, I suggest you re install the driver for the mouse pad, you may have to use an external usb mouse to do it. try that
Jun 21, 2009 | ASUS Eee PC 1000H Laptop
Please help!!!!!!!!!!!!!!!!!!!!!!1
My Zune 30 is frozen. What should I do?
Follow these steps:
  1. Disconnect your Zune from USB and AC power sources.
  2. Because the player is frozen, its battery will drain—this is good. Wait until the battery is empty and the screen goes black. If the battery was fully charged, this might take a couple of hours.
  3. Wait until after noon GMT on January 1, 2009 (that's 7 a.m. Eastern or 4 a.m. Pacific time).
  4. Connect your Zune to either a USB port on the back or your computer or to AC power using the Zune AC Adapter and let it charge.
Once the battery has sufficient power, the player should start normally. No other action is required—you can go back to using your Zune!
Dec 22, 2008 | Microsoft Zune JS8-00001 Digital Media...
Phone in water
Don't turn it on. Take battery off. Put in a bowl or bag of dry white rice, Leave for 3 days. If you are lucky it will be ready to charge and like new after the rice pulls the moisture out.
Apr 09, 2008 | Motorola Mobility RAZR V3
New camera that doesn't respond...
I am assuming you are talking about a Polaroid 8MP I830 camera.
http://www.polaroid.com/service/userguides/digital/cameras/i830_ug_en.pdf
Link for manual
Factory reset
Resetting to Default Settings
You can easily change all the settings you made back to the camera default setting by the following steps.
Please refer to "Camera Default Settings" on page 103 for more details.
1. Access the setup menu.
2. Press or to select (RESET ALL).
3. Press the or button.
4. Press or to select "YES".
5. Press the button.
Setup Menu 3/3SelectExitBattery Type AlkalineReset All NoSetup Menu 3/3SelectOKBattery TypeReset AllYesNo
NOTE:
The following settings do not change with this procedure:
• Date & Time setting
• Language setting
• TV out setting
Contact Information
Phone: 1-877-388-3779
Email: Click Here
Customer Support Hours:
(Mon - Fri:) 10:00am - 7:00pm EST
(Sat:) 10:00am - 4:00pm EST
Warranty on Cameras 1year parts and labor
There is no response from the camera while pressing any buttons.
The LCD screen is frozen or the camera is hanged.
Remove and re-install the battery or batteries to reset the camera. Your valuable data stored in the camera will not be lost.
I hope some of this helps, if not above is the contact number for Polaroid tech support. You camera seems to be still covered under warranty.
Good Luck
Mar 28, 2008 | Cameras
Hour and second hands on my Casio Wave Ceptor watch appear to have frozen
They ususally say leave it alone for about 3-4 minutes and it goes back to time keeping mode. Or - you have "turned it off" a feature to conserve the battery while it sits in you drawer.
Manuals can be downloaded from Casio at
http://world.casio.com/wat/download/en/manual/
Dec 29, 2007 | Watches
Samsung Instinct Cell Phone Logo
248 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
