E-Machines T5082 PC Desktop Logo
Posted on Oct 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I mistackingly pulled out power cord while on my pc when i reconnected it and turned it on it says that it has no os and to insert disk and push any key to boot system iv done that but it still wont do any thing
Anonymous
Level 2:
  • Expert 71 Answers
  • Posted on Oct 01, 2009
Anonymous
Expert
Level 2:
Answers
71
Questions
0
Helped
18537
Points
190
There seems to be some boot files missing. you must insert your windows install disk or the repair disk that came with your computer. when prompted run the 'repair' option and then run fixboot to copy the NTLDR file off the disk back onto your computer. this should solve your boot problem. hope this helps please rate me. thanks and good luck!
Anonymous
Level 2:
  • Expert 69 Answers
Anonymous
Expert
Level 2:
Answers
69
Questions
Helped
23456
Points
136
You have to re-install windows xp or vista
How to replace the cord in dyson's dc07
Things You Will Need
  • Dyson DC07 power cord
  • T15 Torx-bit screwdriver
  • Small can
  • Camera or cell phone with camera
  • Flat-head screwdriver, 3/4-inch or smaller
  • Needle-nose pliers
Tips
  • Do detach the black wire that goes to the motor as it does not require removal.
Warnings
  • Do not work on the power cord when it is plugged in.
  • Do not force the plastic-covered connectors from the switch or you could break the male ends. Pull them off firmly but gently to avoid breaking the terminals.
  • Do not apply too much force to the plastic arms that hold the housing in place. The plastic arms are fragile and may break easily.
References
1 - Unwrap the power cord from the Dyson DC07. Detach the handle of the vacuum cleaner by pressing the release button. Pull the handle from the hose. Slide the hose down the wand and push the button at the bottom to release the hose from the machine.
2 - Press the button at the top of the dust bin handle to remove the canister bin assembly from the Dyson DC07.
3 - Lay the machine on with its back with the power switch facing upward. Locate the Torx screw directly beneath the switch actuator. Remove the Torx screw, turning it counterclockwise. Place the screw into a small can so you do not lose it.
4 - Remove the switch box housing held in place by the Torx screw just removed. Carefully pry upward on the two plastic arms that clip the housing in place. Take a picture with your cellphone or camera of the open housing to make it easier to reinstall the wires where they belong in the channels and spaces provided.
5 - Center the needle-nose pliers on the female connectors from the power cord attached to the switch. Apply equal force to pull them from the male ends of the switch. Also detach the two wires that connect together within the housing, identified by the clear plastic connector between them. Depending on your machine\'s manufacture date, the wires might have different colors. For example, they may be white and brown, all white or one could be blue. Disconnect a total of four wires -- two from the switch and the two connected together. Leave the other wires alone.
6 - Trace the electrical cord on the machine until you reach its protective cover where it enters the Dyson DC07. Lift up the cord protector to remove it from the vacuum. The cord protector has slotted sides that fit within the plastic. Slide the cord protector from the power cord.
7 - Remove the plastic covers that protect the female ends on the power-cord wires that connect to the switch. The new power cord does not come with these. Insert the tip of the flat-head screwdriver through the top of the plastic connector with two internal ridges. Lift upward and away to pull the wire free from the connector. Repeat for the other wire. Push the female end into the plastic connector until it snaps into place. Repeat for the other power-cord wire.
8 - Thread the new power cord through the cord protector. If you have trouble pushing the wires through, reach in with the needle-nose pliers to pull both wires through the rubber protector.
9 - Reconnect the two separated wires back together by inserting the male end into the female end of the other wire. Reconnect the two wires from the power cord to the switch. Reinstall the switch housing on the machine. Align the wires in the channels provided to keep them from being pinched or pulled out when you reassemble the housing. Look at the photo you took earlier as a guide, if necessary. Insert the wire that goes to the motor in this channel and the white wires connected together to the left of the switch in the area provided.
10 - Put on the switch housing cover and secure it with the screw you removed earlier. Reassemble the vacuum in the reverse order you dismantled it.
I’m happy to help further over the phone at https://www.6ya.com/expert/charles_6bf94c079488b145
Different hard drive
Turn the computer off.
Disconnect the power-cord.
Open the side-panel on the computer's case, to reveal the insides.
Disconnect both the "data" and "power" cables from the disk-drive.
Remove the disk drive.
Take the disk drive to a computer store, and tell them that you want to replace it with one that is the same PHYSICAL size -- you may get one that stores many more GB of data.
Insert the disk drive.
Reconnect the cables.
Close the cover.
Reconnect the power cable.
Turn it on.
Reinstall Windows.
Hp desktop blinking green light won't come on
mine does that when it's in stand-by mode. I just push the power button and it comes on....
Assuming you've already tried that....push and hold the power-button down for 5 seconds and the power SHOULD go out. *IF* it does not, then disconnect the power cord in the back for 1min....then reconnect and try to boot. If it *DOES*, then do the same...unplug the power cord for 1min and reconnect and boot.
Tallon41
2answers
I got a Lenovo ThinkCenntre M58P with Win7 64-bit OS. If I had a power failure the machine doesn't startup from the HDD as it gives an error that it cannot see the OS. When you check in the BIOS, the...
Reconnect both connection to harddrive then when you power up the computer press F8 key 5 to 6 times untill you see the safe mode and other menu if you are able to enter in safe mode then os still fine run 'chkdsk /r" in run but if you are not able to enter in safe mode or same error then need to check with bootable windows disk insert that disk set first boot device as cd/dvd rom then boot with windows disk then follow the procedure if it able to see windows then repair it .then it will working again. Let me know if you need further assistance. Thanks for using FixYa.
It wont turn on but the box light is orange
The orange light on the brick indicates that the power supply is in standby mode. This can happen when the power supply cord is not fully inserted into the 360s socket. Disconnect and then reconnect the power cord at each end to make sure that you firmly connect the cord. If your using an extension cord of some kind, disconnect and instead plug it directly into the wall socket. Hope this helps!
Try using another Power outlet or try turning it on by pushing the eject button. Your power button may be defective. I'm sorry, but if that doesn't work I'm afraid your gonna have to call 1-800-4-MY-XBOX There may be something wrong with your console.
Unit failed to boot and observe the followng; - No start-up display - No CMOS boot-up display - Hard disk clicking sound and OS won't start
Disconnect the AC power supply.
Remove the battery.
Remove the disk-drive.
Reconnect the AC power supply.
Turn the computer on.
Put any "data" disk into the CD-drive.
Does it display the CMOS boot-up display?
Can you hear the PC try to spin that "data" CD, i.e., trying to "boot" from it?
If it works "better" without the disk-drive attached, the disk-drive is the problem.
1helpful
3answers
Hp pavilion a1520n power on but no video signal what could be
Open the cpu cabinet cover.Clean dust from all parts. Pull cmos cell from motherboard. Reconnect RAM memory.Try with another RAM if you have. Reconnect processor and it's fan. Make sure motherboard is not ground with cabinet cover. Remove pci card if any if you use vga card then reconnect it. Pull cmos cell from motherboard for 10 minutes then put back it into it's original position. Then check. Let me know if you need further assistance. Thanks for using FixYa.
My laptop will not start after BIOS update pushed to me by HP Healthcheck.HP will not fix and expects me to replace PC or pay $399 for new board. Hewlett-Packard needs to be accountable for pushing a...
I had exactly the same problem last night. HP's 'Health Check' recommended that I flash the BIOS of our new HP Dv7-1175. Had the computer about 3 days, and was receiving some strange errors reporting unrecogized USB devices not recognized and a buggy USB driver. So, OK, Flash the BIOS.
Precisely the same thing occurred. The utility for flashing the BIOS ran, seemed to work, shut down the computer. Then nothing.
I restarted to a backlit screen, no POST or BOOT. Here's how I solved the problem (though I can't tell you why it worked, other than it obviously reset the CMOS).
1) Turned off the computer
2) Removed Battery and disconnected power cord.
3) Waited, pensively, for 5ish minutes (read several places to wait for 20 minutes; I didn't)
4) Plugged the power cord back in (I did NOT reinsert the battery)
5) Holding down the Insert/Scroll button, I held the power button down for 20-30 seconds. Nothing happened until I released the power button. When I released the power button (still holding the Insert/Scroll button depressed), the computer came up and Windows booted. Could not, at that point, get ESC pressed; wouldn't let me into the BIOS.
6) Restarted and prayed, came up normally; opened the BIOS by hitting ESC at the proper time, reset to defaults (just to be sure).
The computer has seemed to work operate normally since, though for the life of me, I can't tell you why this worked. I was, for the record, trying to press the Insert button, so if yours has these separated-- as my Toshiba does-- then I'd start with that.
Hope this helps someone.
2answers
How do we eject a disk from a intel core 2 duo
Do you mean that a CD or DVD is stuck in the CD/DVD drive?
If it does not eject by pushing the eject buttom on the front of the CD/DVD drive, then straighten a paper clip and insert it into the tiny hole just below the drive tray and push the paper clip gently in the hole. The drive tray will pop out slightly, then grab the tray and pull it out until you can remove the CD or DVD disk.
1helpful
Won't turn on even with power cord plugged in
By dumping the power while running you have trashed your Operating System or blown up the Ram
Insert your OS disk and see if it comes to life , if it does then you may have to try a repair from the OS installation CD
If you have popped the Ram then the only solution is to get it checked out on another PC
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
