Question about Canon Office Equipment & Supplies
I changed the ink and now the alarm button is blinking and there is an E then a T2 on the screen i think it says error 5100???
    President:
  • 3,278 Answers
Hi, Michele.
Error 5100 is a carriage error, Check the timing strip (plastic strip about 1/4" in width) for contamination. Also, check for obstructions.
If still a problem, please let us know what specific Canon model you have.
Hope this helps.
Posted on Oct 01, 2009
Canon MP560 error 5100
Hello thanks for using Fixya
To solve the error 5100. Follow the given steps
  • Turn off printer
  • Hold down resume button and press power button
  • Keep holding down power button and let resume button go
  • Press resume button 2 times then let both buttons go
  • Green lights will flash and then stop blinking
  • When green lights are solid, press the resume button 4 times
  • Press the Power button and the printer should turn off if not
  • Press the Power button once more
Your printer will be respond normal now
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using fixya
Jan 18, 2011 | Canon MP560 All-In-One InkJet Printer
Alarm lights keep blinking after I changed my printer ink.
E5 means cartridges error - to fix press the "stop\reset" button for 5-7 seconds and then release it.
You can also try this:
1) With the printer power turned off but connected to a power source, while pressing the Resume/Cancel button, press and hold the Power button.
(DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and
Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s)according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4 times----Green (Power)------Waste ink counter resetting
Apr 07, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Cannon MP830 Printer purchased in July, 2007. Was working fine until yesterday. suddenly when printing from PC get "Service Error 5C10 and printer alarm light begins blinking". When trying copy -...
It is one of two things.
a bad ink cartridge (the chip located on the gold part of it)
or
bad USB cable.
IF you have a spare cable simply change them out.
If you are refilling your cartridges, it is time to replace them.
Oct 04, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Print Sometimes, and Sometimes Error 5100
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
here is the link for other printers: http://www.cyber-ink.com/member-canon.html
Jan 08, 2009 | Canon PIXMA MP470 All-in-One Printer
Canon mp160 prienter alarm light ,power light is blinking&lcd is keep on chngng the nos
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
Jan 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Error 5100?
here is the link to the service manual
http://soft-manufaktura.ru/manual/hp/iP6210dsm.pdf
the first thing I would do it make sure the ink is installed correctly and make sure nothing is rubbing or preventing the ink from moving.
Dec 26, 2007 | Canon Pixma iP6210D InkJet Photo Printer
It will not print.
Hi Greenhorn, Your info is slightly conflicting - I think. As I remember the C60 has just 2 LED's: 1 - Green for Power 2 - Red for Error The third button - Cartridge exchange - has no LED Now it is a while since I looked at a C60 and my brain leaks like a sieve, but that's the way I remember it and feel free to correct me if I'm wrong. The error codes I remember are: Printer status - Indicators - Priority Power - Error Power ON condition On - Ink sequence Blink - Ink Cartridge change mode Blink - Data processing Blink - Paper Out *1 - On Paper jam condition *1 - On Ink end (Black) *1 - On -> Blink Ink level low (Black) - Blink-> Blink Ink end (Color) *1 - On -> Blink2 Ink level low (Color) - Blink-> Blink2 Ink end (Black and Color) - On -> On No Ink Cartridge (Black or Color) *1 - On Maintenance request (Ink Overflow Countererror) *1 Alt Blink Alt Blink Fatal error *1 Off On Special setting Blink2 Blink2
Mar 27, 2007 | Epson Stylus C60 InkJet Printer
70 people viewed this question
old marine
old marine
