Question about Canon NP 7130 Black and White Copier
Canon np7130f copier runs constantly
My canon np7130f copier runs ("hums") all the time when on.  It flashes the light for needing toner, but I just replaced the toner with a brand new one.  It does not copy.
    Sniper:
  • 153 Answers
What does it hum?? singing in the rain????
Posted on Oct 02, 2009
Canon MF4770n error light is flashing and there is no error. How do you get the light to go off?
IF the LED screen shows "TONER IS NEARLY OUT", the "ERROR" light will constantly blink and the "ENERGY SAVER" Feature is disabled YET printer copy-fax-scan operation working properly, the solution will be to replace the toner cartridge. This will solve these issues.
Sep 20, 2013 | Canon imageRUNNER 3300 All-In-One Laser...
I av a problem wit my canon copier ir 2018 .it is having a display red light flashing indicating out of toner while toner is there.wat is the solution of this problem?
TRY SHAKING THE TONER AROUND ----- COULD ALSO NEED A NEW TONER SENSOR
ARE YOU USING THE REAL CANON TONER ? WILL NOT SENSE CORRECT WITH OTHER OFF BRAND TONER .........
Jun 29, 2011 | Canon iR 2016i Black and White Copier
Canon 6035 keeps telling me to add toner when it is already full...error goes away after i open and close the hopper door..this seems to happen after every 5 or so copies(sorting and stapeling)
How do you know it's full? Did you record the copy count when you put the toner in? The only time the copier will indicate that it needs toner is when the developer unit is empty or if the toner sensor is not in contact with toner, you should hear a very high pitch squeal sound coming from the copier. If you are sure you have toner inside the developer unit then the toner sensor is bad. Does shaking the developer unit back and forth a few times help? Maybe the toner has developed a cave inside where the toner is supposewd to be touching the toner sensor.
Jun 23, 2011 | Canon NP 6035 Copier
I have a Samsung ML-2525 BW laser printer. Recently, the red bar second from the top started flashing and then it went solid. I thought this was because of the ink toner, and the cartridge was running low...
I guess it FixYa didn't accept my (very long, but totally correct) solution that I took the time to type. Because I refused to "sign in".
Here's the short version. Load Paper. The same thing happened to me. I replaced the toner cartridge with a new one (because of a FLASHING red light for several weeks) after the red light went to STEADY red. But it still would not print. The paper was "out". When I'd refilled the paper-tray, it printed fine. I had just ASSUMED that the steady-red light meant toner was finally OUT. WRONG! That steady-red light had nothing-to-do with toner; it meant "you're out-of-paper". Don't get confused like I did. Refill the paper-tray. Then take that expensive NEW toner cartridge OUT, and put the OLD toner cartridge back in. And keep using the "dregs" of the toner out of the old cartridge for several more weeks. And DON'T get confused by the paper-is-out condition making that red light STEADY.
Nov 01, 2010 | Samsung ML 2525 BW laser Printer
Canon image class MF 4150: it is flashing, message says toner is not set insert toner. Toner has been inserted, it was working this morning, I printed documents fine, now this message. I have taken the...
spacer.gif If you removed and reinstalled toner correctly several times and this error code is flashing, you need to try another new toner cartridge, even though the other one may seem still good to you. If this doesn't remedy problem the Troubleshooting section of the Canonusa.com website says to call 1-800-OK-CANON.
Jul 16, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
It will not copy after I emptied the waste container.
There really isn't enough information given to give a proper solution. This copier has the drum light come on steady or flashing to indicate the waste toner needs to be removed. I don't know if you're a technician or not but lay people have emptied the toner cartridge instead of removing the drum, removing the cap on top of the drum, emptying the waste toner , replacing the cap on the drum, then putting the drum back into the copier. I've never had a copier keep the drum light on after doing this.
Let me know if you need more help.
Nov 18, 2008 | Canon NP 7130 Black and White Copier
Canon np 7130f keeps running
does anyone know where to get an owners manual for cannon np7130f online for free??
Jan 22, 2008 | Canon NP 7130 Black and White Copier
Canon NP 7130 Black and White Copier Logo
161 people viewed this question
old marine
old marine
