Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Crafstman riding mower cutting off now won't start at all
I have an older Crafstman riding mower model 917.270722. It's 17HP w/ 42 inch deck. Recently it runs fine until about 15 minutes in then shuts off. Until today, I was able to restart it seconds later and it would run for about 5 minutes before doing the same. Today, it ran for 10 minutes, did the same and then died. when I tried to start it it spun slower and slower until eventually, it won't turn at all. It's doing nothing. I checked the battery and it's showing fine. Help?
  • 148 Answers
The two most likely suspects for the symptom you describe are:
a) Ignition coil failure under high heat.
OR
b) Decompression failure due to normal wear.
For a positive diagnosis try the following:
For scenario a)
Run the engine until it shuts itself down. As quickly as possible, check for spark using a spark tester (availabe at local auto parts store). If no spark when hot, allow to cool down and test again. If good spark when cold and no spark when hot, change the ignition coil.
Proper part number (assuming your machine is still all original) Briggs & Stratton part #492341.
For scenario b)
Run the engine until it shuts itself down. Try to restart but pay close attention to the speed of the spinning starter. Next, remove the spark plug and spin the engine over (WITH SPARK PLUG WIRE WELL OUT OF THE WAY!!) If the engine spins super fast and free you can discount the theory of a bad battery and you will need to adjust the valve lash.
Determine which is the case and reply to this post. I will gladly give a detailed explanation of the valve lash adjustment procedure in another post.
Hope this helps!
Posted on Oct 01, 2009
DIAGRAM OD DRIVE BELT ON 46 INCH CUT HUSKEE MOWER
You will need the model number to find this info. Usually on a plate or sticker under the seat. The use a parts site like jackssmallengines.com or simply Google your make and model followed by "deck belt"
Oct 07, 2016 | Huskee Tractor Replacement Riding Lawn...
Will an older 42 inch murray riding lawn mower deck interchange with an older rally riding lawn mower deck ?
Mower decks are very specific to the tractor. Unless it was the same manufactured mower, and just branded differently, then not likely! Belts are your next problem as even an inch longer or shorter will cause problems.
May 07, 2016 | Murray Garden
How to replace the cable that engages blade on an MTD 42" cut riding mower
Utube or ur library...has shop manuals. Do it slow n safe...dont endup the er
Sep 12, 2015 | Mtd Garden
42 murray mower deck TROUBLESHOOTINGmanual
It sound like pto or safety switch may be shorted. Hope this helps.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Jul 31, 2013 | Garden
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
Jul 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have A craftsman riding mower 18 1/2 hp 42 inch deck have changed spark plugfuel filter took off tank and blowed it out but the mower still cute off after about 10 minutes like it has no gas what else...
Do you have a Briggs or kohler engine.I am having the same problem.I have changed the fuel filte, fuel pump, and cleaned the carb.Sears has been no help at all.The reason I ask about the engine you have is that people are having the same problem no matter what engine they have.So therefore it probably is not the engine so it is something else on the mower.My mower runs fine for about 10-15 then starts to stutter and backfire.I am continuing to pursue this problem and I will post back here if I come up with anything.
Jul 06, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
447 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
