Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Top loading washer whirlpool
When we move the drum, even with our hand, about 1/2 way through, there is a loud clicking, popping type noise? Sounds like a train is coming through the house before it stops the cycle?
  • Anonymous Dec 20, 2007
    model is c45 whirlpool
Posted on Dec 20, 2007
Whirlpool Twin Thin Washer makes very loud noise on drain/spin.
Sounds like the bearing on the drum has gone , open the door and see if you have any play on the drum by moving it side to side and up and down good luck
Dec 13, 2017 | Whirlpool Washing Machines
Washer drum making loud noise when spinning
Reach into the drum (on a front-loader)and push upward to see if it moves at all, you should feel no play where the drum support shaft passes through the bearings... The bearings will "roar" loudly during spin if the main seal has leaked water into them... Top-load washers will exhibit the same roaring if the seal fails in them also. Whirlpool Tub Seal and Bearing Kit W10435302
May 13, 2016 | Washing Machines
Duet washer making a loud noise on spin cycle, it squeaks on low spin and then when it gets up to high speed, it is really loud. What could this be?
In most cases it is something that is sticking between the drum and the housing. Check inside the boot by the door. If that is not helpful move the drum by hand and listen to see if you can locate the area of the noise.
Dec 30, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Loud noisy when spinning
If it's a load whinning type of noise the drum bearings may be starting to fail and will need replacing. To check this open the door and find the bottom edge of the outer drum and press down on it and use your other hand at the top on the inner drum and press the two in opposite directions. If you feel any movement between the 2 then the bearings are on their way out and need replacing.
Dec 22, 2012 | Whirlpool AWM5104/1 Front Load Washer
Hi When spin drying or any fast spin cycle it has a very loud rough bearing type of noise
sounds like main tub bearings are gone ..turn the drum by hand if it rumbles its bearing dont use it ... this is not a good job to do.
Feb 27, 2011 | Amana NAV5800AW Top Load Washer
During the spin cycle the washing machine becomes VERY noisy, sounds like its off-balance, but happens EVERY time, even with very small loads. The whole unit doesn't move when it happens, just extremely...
During the spin cycle the drum moves at a higher RPM and so the counter weight of the clothes within can make the drum rotate eccentric or out of sync.
So check if the belt is loose on the motor, checck if the spindle is tight with friction or the drum assembly suspension is out of alignment.
You must check the reason with the following points to confirm the drum spinning making noise. check point of noise , is this on hitting the sides , or from the motor, any foreign objects or the drum spindle. But you are the judge with a first view. Use good lighting to look out and confirm the fault.
Sep 16, 2010 | Frigidaire FEX831CS Top Load Stacked...
Makes a loud bumping noise when washing.
About 76 cents worth.
We have had this machine for about 18 months with one
service call which involved the pump being replaced. Of
course that didn't fix the noise problem.
There are two tabs in the front of the washer that have to be
pushed in for the lid to be raised. There is a plastic shroud
around the top of the drum that comes off by snapping the tabs
and disconnecting one hose. In the center of the drum at the
bottom is a plastic cover plate over the bolt that secures the
drum to the drive shaft. Pop that off with a screwdriver and
remove the bolt with a 7/16 " socket and rachet. Grab the
drum under the lip at the top and pull it out of the washing
machine. Maybe you'll find enough change to buy a coffee.
There is also a plate held by two 1/4" screws at the back.
You might remove those screws and see if there is any more
change there.
Hope this works for you.
Feb 20, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer noisy
Open up the back or front. Check for the shock-absorbers, springs. Rotate the drum to hear anything. Of course the machine shd be disconnected from the power wall socket. There may be 4 springs, 2 shocks. Chk out
Mar 31, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
142 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
