Question about Olympus Stylus 800 / ? 800 Digital Camera
My camera doesn't charge either.
The light just flashes on the battery charger! i don't know what to ??
jackboy
  • 2985 Answers
SOURCE: when i try to charge my battery the red light keeps flashing
Could be battery or charger. 1. Buy new battery. Still in trouble? 2. Get new charger Its good to have two batteries
Posted on Jun 11, 2007
  • 374 Answers
SOURCE: Battery Charging Problem
First of all I would make sure that the battery is in correctly. There should be an arrow on the battery that should line up with a plus sign on the battery door. Once the battery is installed correctly then place the camera on the charger and the light should be a solid red. If that still doesn't work then I would be more inclined to think that you may have a defective charger. I would call Casio repairs and see what they can do to help you.
Posted on Jul 17, 2007
SOURCE: Battery will not charge
Yep. Same hear. Casio will replace with reciept - call 1300 728 606. Pitty I've lost mine!
Posted on Jan 02, 2008
walkietalkie
  • 32 Answers
SOURCE: battery wont charge flashing red
Every rechargeable battery deteriorates thoughout it's life of usage. may be it's time to buy a new one. Sometimes the terminals on the battery get in touch with metal things and short the circuits within.
Posted on Jul 12, 2008
SOURCE: Battery Charger Olympus li-40c
this appears to be a problem with cheap copy batteries. I've got the original Olympus battery that came with my camer and have no problems with charging i.e. the light comes on and stays solid red until the battery is charged at which point the light turns solid green. If i put in the cheap 'copy' batteries that I got off Ebay from China or somewhere, the led light flashes red continually, no matter how long I leave the batter on the charger for. I put the battery in my camera to check to see if it was charging at all and it has no charge in it. So I'm going to throw away the cheap battery I got. I think the flashing red light means that the charger is unable to charge that battery for some reason? Not sure why as I can't find any documentation on the net anywhere. Hope this helps some people.
Posted on Oct 26, 2008
Metz 76-56 battery charger keeps flashing red light
One of your cells is defective.
It maybe brand new, but we don't know how long it's been in the box.
You will need a DVM to troubleshoot the battery.
atdlee@netzero.com
Oct 04, 2012 | Metz NiMH Battery 76-56 for 76 MZ-5...
How long do you charge fujifilm JV300 camera?
Remove the battery from the camera, put it into the supplied battery charger, and plug the battery charger into a power outlet. The charging is complete when the light on the charger turns from orange to green.
Jun 03, 2012 | Fujifilm FinePix JV300 Digital Camera -...
Red and green flashing lights on 18v lxt charger
Batteries don't always look degraded but if they've been in use for a while or have a bad cell, they will show up bad on the charger and it won't charge them. The only way to test the batteries is to try to charge them on another charger. If the batteries show defective on another charger, they are bad and you'll have to replace them. Also try to charge some batteries you know to be good on your charger to see if it's the problem. If your batteries charge on another charger, your current charger is bad and they don't have any replaceable parts in them so you'd be looking at replacing it.
Feb 21, 2012 | Makita Tools & Hardware - Others
Im trying to charge my camera via computer. . there is a red light on the charge cable connector and a green light on the camera which i have switched "on". it still says "low battery even...
Hi, I'd suggest using a wall charger as they're able to provide more power to charge then a computers USB port. Often with camera's the USB port doesn't supply enough power so the camera doesn't charge at all.
Aug 18, 2011 | Samsung SL102 Digital Camera
My battery charger stopped charging the battery. Whenever I put the battery in the charger the green light flashes signaling a problem. I tried wiping the contacts as the book suggested but with no...
How long do you have the camera?
Rechargeable batteries don't last forever, and when they are too weak to take a charge, the little light just blinks.
They could also be shorted out.
This flasing is a problem code. "The book" should also tell you what these flashes mean, although it usually means: replace the battery.
Jun 24, 2011 | Panasonic LUMIX DMCTS2 / DMCFT2 Digital...
My DMC-TZ3 battery charger green light is flashing, why ?.
I have the same problem. When I try to charge a battery the green LED onthe charger flashes green and the battery does not charge. Any ideas?
Jul 08, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
I had this problem a few weeks ago (i.e. flashing red LED). All I did was remove the power plug from the charging unit, turned it around 180 degrees, then plugged it back into the charging unit. Red LED came on steady & the battery (which is the one that came with the camera) recharged as normal.
Aug 25, 2008 | Cameras
My Casio EX-Z18 charger light keeps on flashing. When I put the battery in the camera, it doesn't turn on. What is wrong?
My Casio EX-Z18 charger light keeps flashing red when i put the battery in to charge, it doesnt charge up therefore my camera doesny work. Can you hepl??
Aug 03, 2008 | Cameras
Olympus Stylus 800 / ? 800 Digital Camera Logo
43 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
