Question about Garden
Stops after short period of use. it used to run longer but kept getting shorter. Carb adjust?
SOURCE: Panasonic CT32D-11 turns itself off
This is a classic switchmode power supply, the Protection Circuitry has sensed a severe potential problem, and is shutting down to avoid a fire, explosion, or both. The "Fault" is sensed, the set shuts down, the "Fault" clears, the PSU starts up detects the fault, shuts down, and so on, this will keep on, until the faulty components finally do fail completely, often with catastrophic results. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center, Panasonic, in your case, now, this point is very important for a good result, Always contact, "their" local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done
Below is a link for your service manual.
http://elektrotanya.com/?q=showresult&megnev2=CT32D20B&kategoria=tv
Posted on Nov 11, 2010
SOURCE: I just got a new Honeywell Utility Pro Thermostat.
Sounds like you also have a high efficiency furnace like mine.
Here is a procedure to slow down the number of cycles you are experiencing.
1. press System
2. press and hold buttons 3 and 5 on the bottom of the screen. (there should be 7 buttons displayed)
3. set code to 240
4. change setting to 3 for 3 cycles per hour. (your thermostat probably shows a higher number, probably 5? That is why your unit is cycling so often).
Posted on Mar 02, 2011
  • 42 Answers
SOURCE: I have a 266 se husky saw and I can not get it to
it probably damaged the diaphram when the carb came loose. you could try adjusting the carb. that will solve it every once in a while.
Posted on Jul 31, 2011
SOURCE: Adjusting carb on mower (Jacobsen commercial
Jacobsen Commerical Front Rotary mower looses power under load.
Posted on Aug 27, 2011
hunter19_46m
  • 7482 Answers
SOURCE: Runs for short period then stops
Hi abob
Posted on Apr 28, 2013
Which home loan is better: Long term or Short term?
A home loan is always considered to be a good debt. So, longer home loan tenure is going to benefit the applicants more. An applicant who is apply for a home loan online, you enjoy the benefit of tax deduction for the entire tenure of the loan.
In case of short term home loans, your house loan EMI amount will be pretty high, so you may not be able to afford it. But you have to repay less to the lender. But in case of long run, your per month repayment will be less and affordable, but you will end up paying much more than what you have actually taken as loan. Your principal amount and your repayment amount will have a huge difference.
Jul 25, 2016 | The Computers & Internet
Craftsman Chainsaw 2.0/10" Carb Adjustments
there are 3 makes of carbys used on small engines and they are all adjusted the same
in your browser search bar type in --- adjustments for walboro (or yama if that is on yours) carby or workshop manuals for ( what ever you have ) and there manuals to download that explains how to repair and adjust the screws
Jan 11, 2018 | Garden
Cannot identify between which is high/low adjusters
hello mike, the high is longer the low is shorter,
Jan 22, 2012 | Mantis 2-Cycle Tiller
I bought an ariens 932027 ST724 W/ 7HP Tecumseh HSK70 130266S Engine. It seems to have a problem running for longer period of time than 5 or 10 min. after that it starts back firing and shuts down. It will...
Almost certain, having had this problem with this mower several times, that your petrol cap which is suposed to let air into the tank does not. after a few mins of running suction develops and the engine stops. you check the fuel level and its ok so you restart and it goes fine for another 5 min. by removing the petrol cap you let air in and temporarily fixed it. Clean out the arangement of screws and springs and filters under the fuel cap.
Dec 28, 2010 | Sport & Outdoor - Others
I have recently been given a Scott Bonnar SX 4000, Model mower. It would not start. By spraying petrol in the chamber it sometimes started but then stopped. Checked the spark and have disconnected and...
I would suggest 2 things to start.
1. Get a can of carb cleaner in the spray can and spray inside the carb.
2. Get some fuel line cleaner and put in the gas tank.
If neither of these fix problem, a carb cleaning is undoubtedly in order.
(If there is old gas in the tank, by all means drain and fill with fresh.)
Oct 31, 2009 | Garden
Yamaha TW 200 starts but won't run.
If the bike has sat for a long period of time without being run - the gas that is sitting in the carb(s) will shellac.. Then the carb(s) would need to be cleaned and "rebuilt"..
Sep 14, 2009 | 2001 Yamaha TW 200
1992 kawasaki Vulcan 750 stops running
Check the intake manifold/s, even a small leak will make it run poor. Being stored for five years then putting it into use, you may have a blocked main jet. Sea-foam is a great product and I would have used that product to store the bike but not to get it running. It is slow acting so it doesnt work like carb cleaner.
Jun 01, 2009 | 1992 kawasaki VN 750 Vulcan
Toro lawn mower sputters and stops working after running
fuel delivery probblem might be vapor lock(to much heat getting to fuel lines and carb) may also have dirt in fuel bowl on carb and in tank ,gas tank lid may not be venting . it will be one of these three things
May 01, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
