Question about LG DU-42PX12XC 42 in. Plasma HDTV
1-2 pixel width vertical line on my TV
About 6 months ago I noticed a 1 pixel wide vertical purple line running down the left side of my screen. It used to be when I grabbed each corner of the TV and slightly twisted clockwise then slowly released the line would go away and not come back until you turned the TV off then on. All I had to do was repeat and it would go away again. Now when I slightly twist two more lines of different colors show up and then my originally 1 pixel wide line turns into 2 wide and turns either red or almost black. This happened far less than a year after I bought the TV and I know it's not dead pixels because if I alter it enough or wait about an hour after turning it on, the lines go away. I would really appreciate some help on this. And preferably help at no cost considering I had to pay $1100 for this Thing.
techman
  • 3130 Answers
SOURCE: nec plasmasync 4200w 3 vertical lines one yellow two purple
Sorry to tell you, it is not a scratch, but a bad cable connection from the driver IC's, connecting up the plasma screen to the drive board, or the drive IC for that section of the screen is defective. It is not a repair a user can do as there are no user replaceable parts inside this set. Your going to have to call NEC or an experienced Plasma repair shop.
Posted on Oct 08, 2006
  • 1153 Answers
SOURCE: Black horizontal line 1 pixel high
Depends on what area the line is in the bottom half or top?
Posted on Mar 10, 2008
  • 133 Answers
SOURCE: pixelated lcd tv picture
usually this issue is caused by a week signal issue, those tv's need a stronger signal than an analog tv, i would call the cable company, have them come out and hook a meter to that cable, they may sujest a house amp, usually charge 50 bucks for it
Posted on Jan 11, 2009
gsalmen
  • 77 Answers
SOURCE: thin red vertical lines on left side of 50
this is not an easy fix. the screen ,or the x or y screen drivers are bad .
Posted on Jul 10, 2009
  • 458 Answers
SOURCE: vertical red line through screen
This is a problem within the screen, probably the connection from the internal ribbon connector to the display. Unfortunatly the only way to repair this is to have the screen replaced.
Posted on Dec 26, 2009
Testimonial: "Thanks I was afraid that might to the case."
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 24, 2015 | Panasonic Viera Tc-p50u50 Hd Plasma Full...
2 thin vertical blue lines, near center and right side. Do i need to replace LRC buffer boards. Z50p3 50 in plasma.
By thin line I assume its one pixel in width. A single pixel wide line is an indicator of a defective panel.
Oct 30, 2013 | Zenith Z50P3 50 in. Plasma TV
42" Panasonic Plasma - Vertical red stripe 6" from left side
We originally had a red stripe roughly 3" wide running vertically on the ride edge area of our Panasonic 52" Viera plasma tv. It has now been joined by a solid black stripe of the same width running from the top to the bottom. Living in Germany and purchased at local PX long enough ago that the warranty is likely expired. Now what?
Jan 18, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Lcd tv screen shadow
they call that line pixels and the only way to fix is a new lcd panel. if you have under 8 pixels your warrinty won!t cover with some companys
Aug 31, 2008 | Sylvania 6427TE 27" TV
Dark band on left side, Samsung HL-R5668W
the reflecting mirror is likely loose and falling down inside the light reflecting tube. you should have seen the band getting darker and larger,
the small mirror is in front of the lamp and bends the light,
remove the lamp and look down the tube (light path)
May 06, 2008 | Televison & Video
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Jan 01, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Nec plasmasync 4200w 3 vertical lines one yellow two purple
Oct 07, 2006 | NEC PlasmaSync PX-42VM2A Television
LG DU-42PX12XC 42 in. Plasma HDTV Logo
241 people viewed this question
Computer Repairing
Computer Repairing
