Question about EliteGroup K7AMA Motherboard
ELITEGROUP K7AMA good day sir glamaxjoe,I try to follow your advice "replace the battery" but the problem is still the same,cannot boot to CD ROM or HDD,please help me
    Problem Solver:
  • 19 Answers
How far does the Boot get? Is your keyboard active (is it polled?), do you see the BIOS boot screen? Can you access BIOS?
Can not boot from CD or HD, with BIOS screen showing, is one thing.
Can not get BIOS screen showing, is another.
Both are, can not boot from CD or HD.
Posted on Dec 30, 2007
Bad Locksum BIOS CD_Rom not found when I try to
it's not locksum ,its Check SUM or CRC errors.
what OP, are you running,? windows what. i guess.
the CMOS battery just died.
install a new one.
all puters this old do that, the battery is good for 7-10 years,
and all fail.
DO NOT FLASH your BIOS, fix the real problem first
when the battery dies, all our bios setting were lost
including boot device, and order
fix battery
then go into BIOS and put back boot order.
Mar 22, 2017 | HP Pavilion a815n (PS512AA) PC Desktop
How do i reformat my pc
Hi Good day!! Sir/Madam if you want to format your pc you will need and CD of a Operating system like WindowsXp/Vista/etc.(note you should have the product key after installing the OS)
here are the steps on reformating:
1. Open your Bios setup by Pressing del or f2 it depends on your board.
2. insert your bootable CD on your CD/DVD rom.
3. go to boot setup, set your boot priority 1st boot must be your CD/DVD rom, 2nd boot your harddisk after you set your boot priority press f10 and then save changes. it will restart your pc.
4. your computer will boot in CD and a message will appear "Press any key to boot from CD...." you should follow it. press any key!! if you boot from cd successfully you should be on windows setup it is a blue screen!! congrats!!
5. windows setup will load it's driver, when finish loading there will be a option on the bottom.
6. press f8 for terms and agreement (read carefully)
you can start formating just read the instruction.
REGARDS
JR
Oct 14, 2010 | Computers & Internet
Compatible ddr memory for K7AMA Motherboard
2 DDR DIMM Sockets and 2 DIMM sockets support (can not be used simultaneously)
Two 184-pin 2.5V DDR SDRAM (DDR266/DDR200) or
Two 168-pin 3.3V SDRAM (PC133/PC100)
Maximum: 2GB
Jan 03, 2009 | EliteGroup K7AMA Motherboard
PROCESSOR
Your M/B support Socket 462 (also called Socket A) is a PGA socket designed for AMD K7 family of processors. This socket can be used with AMD Athlon and Duron processors ranging in speed from 600 MHz to 2200 MHz (3200+) and with bus frequences ranging from 100 MHz to 200 MHz (400 MHz DDR)
Athlon (Socket A) (600 MHz - 1400 MHz)
Athlon XP (1333 MHz - 2333 MHz, or 1500+ - 3200+)
Athlon MP (1000 MHz - 2133 MHz)
Duron (550 MHz - 1800 MHz)
Sempron (socket A) (1500 MHz - 2200 MHz, or 2200+ - 3300+)
Mobile Athlon 4 (850 MHz - 1400 MHz)
Mobile Athlon XP-M (Socket A) (1200 MHz - 2200 MHz, or 1400+ - 3000+)
Mobile Duron (650 MHz - 1200 MHz)
I Recommend to go for Athlon XP with good cooling fan. :)
Dec 18, 2007 | EliteGroup K7AMA Motherboard
CMOS SETTING and BOOTING
I just had the CMOS checksum error while starting the computer, So pressed F1 and continued.. I just don't think it's the battery, because the computer is 2-3 months old, and all parts were new. I also have another problem. which is that it tells me at start upo the the IDE 80 connector cable isn't installed, or something like that, which prevents one of my hard drives to be found by windows....
CMOS SETTING
May be battery is dead replaced battery and check. below screen shotf6376c8.jpg will help you to locate it.
good luck!
Please Tell me, ASUS P4S8X-MX Problemn
First of all, try to reseat all the cables inside your computer just make sure there aren't any loose connections.
If that doesn't work you will have to reset your BIOS. (Follow the instructions in your motherboard manual.)
If even after resetting the BIOS the problem is not solved, you may have to replace your CMOS Battery.
Oct 18, 2007 | ASUS P4S8X-MX Motherboard
Motherboard k7ama-ellite group
try disabling the power saving features at the startup BIOS screen.
Aug 25, 2007 | EliteGroup K7AMA Motherboard
K7ama AMD duron
Hi, You can try a couple of possible remedies: 1. If you're using Win98/SE, download shutdown fix from the Microsoft website; or 2. If Win XP, update your networking card drivers; and/or 3. Reinstall/repair Windows. Hope this be of some help/idea, post back how things are or should you need add info. Good luck and kind regards.
EliteGroup K7AMA Motherboard Logo
109 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
