Question about Boating
Yamaha 9.9 shift linkage in lower leg is acting like it's disconnected. Can't change gears or go to neutral. Removed leg to fix water intake and when I hooked it back up unable to shift. Removed lower leg again and linkage moves up and down but not disengaging.
    Problem Solver:
  • 12 Answers
Make sure that throttle is all the way back to idle or it will not be allowed.
Posted on Oct 08, 2009
1983 Johnson outboard . Model J25TECTE. Runs Forward/Reverse. Shift rod connection OK. Shift in neutral it runs in reverse. Do I need to change something in the gear case section?
you have removed the leg to replace the water pump impeller
the leg has the selector rod for the forward and reverse action
as the direction selection is a simple dog that moves forward or back to connect the spur gears and it was working before you pulled the leg off , then I am thinking that when the leg was reassembled that the selector was in a wrong position and now you are only moving it in one direction neutral or reverse instead of the 3 positions forward neutral reverse
nothing else can change except where the rod connects in the leg
Jul 07, 2016 | Boating
What can i do to fix my 2000 chevy astro van it wont shift into any gear
Sounds to me like your linkage is the problem. To check it you'll have to have someone in the vehicle and raise it in the air (to have wheels off the ground) disconnect the linkage from the transmission. Have the person in the vehicle apply the brake and shift the transmission at the neutral safety switch. If it shifts into gear you need to change the linkage, if not you'll need to have the transmission checked.
Feb 14, 2015 | 2000 Chevrolet Astro
Yamaha 40 hp outboard
Look below lower mountings you will see the shift rod with along nut and a lock nut,undo long nut,do this with motor in reverse gear,some 40s have a stainless plate cover which you have to remove first
Aug 18, 2014 | Clymer Marine Maintenance and Repair...
15 hp yamaha not shifting stuck in gear
First, check the linkage under the motor cover. It stoops you from given the engine too much throttle when the motor is in neutral but can jam the system if you try to shift out of gear at too fast of speed. Or a link in that system could be broken/loose. If all looks OK the check your lower unit oil. If none or water, the gear case could be trash.
May 26, 2014 | Yamaha Impeller, 8, 9.9, 15 HP Outboards...
I need to disconnect the shift linkage of a 1983 Johnson outboard motor. I already disconnect at the water inlet. The lower unit still will not come all the way down.
some shift rods unhook midway thru the leg ,others you unhook at the top and the entire rod comes out . caution getting the shift rod lenght the same as when removed is critical or you will have shifting problems.
May 16, 2014 | Boating
How do i replace a force 120 impellar pump?
Most impellers are in the leg and require the lower oart of the leg to be removed by disconnecting the gear linkage and undoing the bolts that hold the lower half of the leg on, they are just above the water intake.Don't forget the bolt near the prop. Wiggle the leg and slide it down to remove, then place the leg on the bench. The drive shaft protrudes through the impeller housing, remove the bolts that hold the housing on and slide it off. When fitting the new impeller be sure to fold the fins in the correct direction. When re installing the leg be careful to align the cooling pipes correctly.
Cheers, Timo.
Apr 16, 2010 | RTO Outboard Motor Bass Fishing Boat Rod...
Where is the water pump on a 1985 yamaha 25 horse?
In the leg, undo the gear link and undo the bolts that hold the lower half of the leg on, they are above the water intake pointing up, don't forget the bolt neat the prop. Wiggle the leg off and put it on the bench. The drive shaft protrudes from the center of the water pump housing, remove the bolts and slide the housing off. When you replace the impeller make sure the fins are folded in the correct direction to avoid pinching. Be sure to align the water cooling pipes when reassembling the leg.
Cheers, Timo
Apr 12, 2010 | Boating
Replace water pump impellor 15hp yamaha outboard . how to remove lower leg.
Put the motor in neutral.On the leg of the motor there is a little side cover plate.Remove.Undo the bolts.This is the gear change linkage.At the cavitation plate,there is 4 bolts.Remove.If the lower housing does not drop,give it a soft whack with a soft hammer.When dropped,you will see the prop shaft and the gear linkage.Lower it all the way out.Its easy to work on if you put the lower skeg in a vice.Take the water pump apart BUT!!! have a look at which way the impellar blades are pointed.Grease the new impellar as you put it back in and turn it at the same time to get the nodes in properly.Heaps of grease to protect all the bolts.Makes it easier next time.Hope this helps
Nov 15, 2009 | Boating
50hp force that jumps in an out of gear
I need year model to be precise? But here are the basic tools and troubleshooting steps. TOOL (1) a black marker.(2) a tape measure (3) a second person. TROUBLESHOOTING STEPS(1) the force need water so put it in the lake or install water hose.(2) do not start engine yet. remove engine cover and find shift cable by shifting remote control. once you find were the shift cable connects to the shift linkage. learn which way is forward and reverse. is it push or pull by the cable. remove the cable.(3) now the shift mechanism is removed from the boat controls. this test will require you shifting the shift linkage by hand so stay clear of the flywheel and all moving parts. (4) start engine. at idle speed and you in a safe location near the shift linkage shift engine into forward gear by the shift linkage. be aware how far you need to move the linkage before it shifts into forward. Mark that location with the maker somewhere you can see.(5) shift the linkage back to neutral. mark location were neutral begins. you will fill it click out of the forward gear.(6)now shift into reverse gear marking that location.(7) shift it to neutral making that location as you fill it leave the gear(8) shut off engine turn off water or take it out of lake (9) look at you marks and measure the distance between neutral and forward. the measure the distance between neutral and reverse(9) the second person needs to be in the boat to work the remote control. you need to be at the engine with the tape measure. person #2 needs to make sure remote control is in neutral. you need to measure the remote control cable end so you get a measurment with it in neutral. make a note of the neutral lenght.(10) person #2 shift remote control into forward gear. you measure cable end for distance traveled to go to forward.(11) make the measurement for reverse same way.(12) this is how you find out if you clutch dog is to wore out to stay in gear by the travel of the shift linkage compared to the travel of the shift cable. There are adjustments but they only go so far. that means you will have to sacrifice one gear for the other to make up for the distance of travel.
Sep 05, 2009 | Boating
We have a 9.5 johnson outboard motor, it works in neutral and reverse, but when we put it in gear, it immediately pops back into neutral. How do we disassemble and fix this problem?
I would think that the problem is a worn clutch dog. Drain the gear oil from lower unit. You need to disconnect the shift linkage and pull the lower unit like you would to change the water pump. Then remove waterpump housing and waterpump base. The base will have a seal so you need to be careful and gently and evenly pry the base up until it comes off. Next you need to remove the prop and depending on the year there is a ring screw around the prop shaft that needs removed. Also there is a phillips screw that needs to be removed near the lower gear oil drain plug. That screw holds the shift cradle in place. From here you should be able to slide the drive shaft up and out and the prop shaft should slide out. The clutch dog is the smaller piece in between the two gears that engages fwd and rev. You really should have a mechanic do the work but if you get a book it will help you. Pay very close attention how it comes apart and make sure that you dont mix up the fwd gear with the rev. gear.
Aug 05, 2009 | Boating
Boating Logo
308 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
