Question about Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator
Is there a heating element in freezer?
Is there a heating element at the bottom of the freezer? I see an orange glow behind the inner wall and hear water sizzling as it drips.
    President:
  • 744 Answers
Hello, Yes there is a heating element in the back of the freezer. This is the defrost heater which kicks on every so offten to defrost the evaporator. Please feel free to comment again if you have any further questions. Mike
Posted on Oct 01, 2009
Ge profile bottom freezer model # PGSS5NFXA SS. Got up this morning and freezer thawing. pulleD back panel cleaned the condenser fins with compressed air. runs fun but can't get the temp to fall past
Hi and thanks for using fixya!
This could be any one of 3 problems on this french door GE refrigerator. So lets trouble shoot.
First let me say the most common problem (95% of the time) on this model refrigerator and other GE models like this one is caused by the main control board pt # WR55X10956. I'll leave a link below where you can purchase parts.
1st, (unplug unit) , pull the freezer door out and look on the back wall. (all cold air in fridge comes from the freezer behind the back wall.) Is there a snowy frosty ice build up on the back wall? If so, you have a defrost problem. In this case, remove the freezer drawers, take all food out and remove the back wall (usually 1/4 inch nut driver needed). Also look where the evaporator fan is (vents in middle-top) and you'll see a picture of flat-head screw driver. You'll need to insert screwdriver where it tells you to and pry off vent. Once you have back wall off you'll need to defrost any ice you see. After that you will notice a glass heating element at bottom with one wire connected on both sides. unplug those wires and test element for continuity. Around 0 is good. If you don't have continuity then the heating element is bad. pt# WR51X10094 Link to parts site below. Next, test the thermostat, round-cylinder thing, width of a quarter attached to the evaporator coils (usually at top right and has two wires connected to it, one yellow, one orange). You test this just like the heating element. No continuity means it's bad. pt# WR50X10069. If both test good (and most of the time they do) then you'll need to replace the control board listed above.
Here is link where you can purchase parts listed above. They have good shipping and good return policy.
Appliance Parts
Feb 03, 2015 | GE Refrigerators
Water accumulates and freezes on bottom of freezer.
Orange glow is defrost heater and that is normal. Crackling sound is heater heating up area around it, normal. Water and ice build up in the bottom is due to a clogged defrost drain.
Sep 01, 2012 | Refrigerators
The refrigerator not defrosting. Replacing of the defrost timer not solved the problem. Please your advice.
have you checked the defrost heating element and thermostat both mounted on the evaporator coil in the freezer behind the rear inner freezer wall,if theres a lot of frost on the rear wall carefully defrost with a hairdryer and open this panel and troubleshoot these 2 items
Jan 01, 2011 | LG LRTBC1825T Top Freezer Refrigerator
Top half does not freeze
There is a fan behind the back wall of the freezer about 1/2 way up from the bottom, you should be able to hear this running when the freezer is on. If you do not hear this then you need a new evaporator fan motor.
If you hear the fan run then you most likely have a problem with the automatic defrost cycle that would most likely be the heat element that is located just below the coils inside the freezer behind the panel.
Apr 21, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
I have a Lady Kenmore electric dryer (40 years old maybe?), model 110 6508923, which I cleaned the vents, strong air, tumbles fine. The heating element glows orange for a few moments, then as it finally...
The element is supposed to cycle on and off thru out the drying cycle as not to burn clothes. Is it just taking too long to dry. If it is your exhaust from the wall behind the dryer to the outside is clogged somehow. I like to use a leaf blower stuck inside the exhaust behind the dryer and blow the whole line out to the outside of the home.
Jan 31, 2010 | Dryers
Is the defrost light behind the back panel supposed to glow orange?
There is a heater behind the freezer wall that every 10 hours or so will turn on and get very hot and red/oranged color like a bake elemenet in an oven
Sep 17, 2009 | Refrigerators
Water dripping in the freezer We have side by side kenmore fridge and freezer and filtered water. I just opened the freezer and heard dripping of water behind back cover. It sounded as water is hitting...
this IS normall. the freezer is just in defrost cycle. the heat elements are on and defrosting the evaporator. you are hearing the water hitting the elements and running to the drain. this is normall, does it every day, just the first time you happen to notice it. shane
Aug 25, 2009 | Refrigerators
OVEN DOES NOT FULLY HEAT
assuming that we are talking about an electric range, lower element not glowing, you can check the element for continuity, froim behind. its either pass or fail. beaware to shut off power wires live all the time
Nov 16, 2008 | Whirlpool Ovens
Red glow (from defrost heater?) at bottom of rear panel in freezer
This is from the GE Appliance "Knowledge Database" Web site:
Refrigerator - Explanation Of Red Glow
In a no frost refrigerator, the defrost timer activates defrost heaters in the evaporator section (rear of freezer) which heat up and melt the frost off the evaporator coils. This process lasts for approximately 25-45 minutes and usually happens up to twice a day.
During this time, there will be no running sounds, no fan noise, and you may hear water dripping or sizzling as it hits the heaters. On side by side models, you may even be able to see an orange glow at the bottom of the freezer.
This is normal.
Aug 06, 2008 | GE GSS20IEP Side by Side Refrigerator
Heating element in a refrigerator?
The orange glow you see is your defrost heater. Your refrigerator goes into the automatic defrost mode three times a day. This keeps the unit frost-free.
Oct 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator Logo
226 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
