Question about Quinny Buzz Jogger
Deflated Quinny tire
How do I buy one tire that won't hold air?
  • 60 Answers
Go to this link for Quinny Parts and you can either fill out the form or call them directly at their 800 number shown.
http://quinnybaby.com/info_replacement_parts.asp
I hope this was helpful, DutchTexan
Posted on Nov 06, 2009
I got a Qunny Buzz last year. One of the rear wheels can't hold air in it, so it is flat now. Where can I replace it or fix the wheel tire?
Hi
Please visit www.quinny.com and select the country you're in, then choose the "Contact Us" tab for the enquiry to be sent onto the customer care team for your country.
Mar 22, 2012 | Quinny Buzz Baby Gear
I need a new wheel for my quinny freestyle, it keeps going flat and now i have a thorn in it. i need it asap
Most strollers use the same tires and tubes as kiddy bikes. 10" or 12" your local bike shop could help. I buy spare tubes and tires from Kmart.
Jun 03, 2011 | Quinny Freestyle 3 XL Stroller
Struggling to fit replacement inner tube and tyre to our quinny buzz3... Any tips?
You need a set of tire levers to begin with.. anyplace that sells bike parts/tubes tires will have these.. they are just a nicely set of angled thin yet dull levers.
Using the levers you will need to lift one edge of the tire off the rim so the tire is half way on the wheel. To simply replace the tube.. continue on to B.
To completely remove the tire off the wheel.. flip the wheel over and using the levers pry the tire the rest of the way off the wheel. working your way around.. it will be snug then suddenly free.
Replaceing the tire is the same..except you only want to put it on half way before inserting the tube..
B. Remove the air stem cap and if you have the tool to remove the needle valve from the stem.. do that too as to let ALL the air out of the flat.. then pull the bad tube out.
Put the new deflated tube inside the wheel as flat and wrinkle free as possible starting with placing the air stem through the wheel.. and working it around until well seated.. some folks will use a bit of talcum powder on the tube.. usually they come dusted to allow them to properly fit when inflated.
Once you have the tube in the wheel.. start pressing the tire bead back under the rim.. depending on the wheel.. you may want to partly inflate the tube.. just a tiny bit.. so it will not get trapped between the tire and wheel rim when you re-seat the tire.. you can usually re-seat the tire to the rim with your fingers..becareful not to pinch yourself.
Inspect the wheel to make sure no parts of the inner tube is visible.. inflate to proper psi.. put on the stem cap.. replace the wheel.
You can buy a set of tire liners that will prevent punctures.. but of course this involves doing most of the above times four.
Lastly.. if you feel you just can't get it done.. stop by a good bike shop.. they will do it for you in just a few minutes.. possibly for no charge or little charge.
Best of luck!
Apr 11, 2011 | Toys
Inflating tires on a 2000 4 plus Quinney
Hi, If you go to your local bike shop they will be able to help you. Regards marie
Mar 26, 2010 | Quinny Freestyle 4 Marina Stroller
Quinny pump for wheels
You have to really push hard to get the tire pump on the valve. If it still doesn't work, check the valve itself...is the center post bent? If so, the tire pump won't be able to fit over it to air up the tire.
Sep 21, 2009 | Quinny Buzz Jogger
Quinny Buzz
you should be able to find the manual here
http://www.quinny.com/quinny/productdetail.aspx?id=3
Robert
Please rate the solution
May 19, 2008 | Quinny Buzz Jogger
Quinny Buzz Jogger Logo
249 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Al Toledo
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
