Question about Bose Audio Players & Recorders
CD intop changer position will not play or eject. CD in top unit plays ok. Radio plays. How can I eject CD in Accessory changer?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, postback with the exact model number of the Bose CD Player. Offhand, some versions of Bose units have a manual magazine release underneath.
Good luck and thank you for asking FixYa.
Posted on Oct 01, 2009
My cd won't play. It just ejects and has an err code.
If youre getting an error code and All cd's are being ejected than your CD mechanism " loader" is bad. You can contact United Radio in Syracuse, NY if you think its worth fixing, if its only certsin discs and Radio plays radio stations ok then it may be CDs that are not in MP3 format which will not play in your radio. Let me know. Lex.. 11_2_2013_3_15_32_pm.jpg
Sep 16, 2013 | Car Audio & Video
Sony CDP-C910 will no longer play cds or eject changer cartridge
Mine did the same thing. My player was primarily used in the garage and the cold weather may have caused my player to do the same thing. I just fixed my player. I removed the top cover and looked at the CD in the play position. In the upper right corner from the CD, you will see a spindle motor with a belt on it. Gently spin the motor back and forth carefully with your finger. I rotated it a half-spin in either direction, careful not to dislodge the belt. When I turned the player back on, the mechanism operated as it normally would and began playing the disc. I was able to eject and reinsert the magazine without any issues, solving the problem. Hopefully that will work for you.
Dec 17, 2012 | Sony CDP-C910 10-Disc CD Changer
Cd changer quit working
You might try Windows to search for drivers. It seems you hardware is OK but you have a software problem.-------------------------------------------------------------------------------
Diagnostic VAG
Dec 11, 2012 | Ford Windstar Cars & Trucks
5disc multiple choice cds stuck in slots how do i
Have a look for a small hole in the front of the CD player - this is the emergency eject button. Find a paper clip, unwind it and then press the paper clip through the hole - the CD should then eject the first CD and you will then be able to eject the others.
Apr 28, 2010 | Blaupunkt IDC-A09 5-Disc CD Changer
My original problem WAS that the magazine wouldn't eject which i'm told is due to a weak or dirty belt or gearing. I have a temporary solutuion for this (which is to undo the top of the frame INSIDE the...
there are small drive belts that provide the power to operate the different parts to eject the CD magazine, i suggest you remove the covers and check these belts for slack/strech, it is a common reason for this problem
Jan 28, 2010 | Alpine CHA-1214 12-Disc CD Changer
The magazine wouldn't eject which i'm told is due to a weak or dirty belt or gearing. I have a temporary solutuion for this (which is to undo the top of the frame inside the caring which releases the...
Hi
Open top cover, if the empty magazine was left inside the cd trays it can slide out into the playing area and jam the unit, check it like that anyhow. Sometimes you can see a small metal tab to release the magazine.
However Error1 means Battery inside CD Changer needs to be replaced.
And NO CD.CD error message means No CD in magazine or no magazine in CD Changer.
To fix the problem, disconnect the CD changer.
take off the top plastic slide cover,
with a small screwdriver slowly move the gearing so that the CD disc holder will move back to the load - unload position.
Pop out the CD holder.
Replace unit, reconnect the optic and power lead, switch on radio and the unit will work again.
grease the moving parts with light lubricant.
Thanks for contacting fixya.com
I have a Bose Wave Music System with add-on 4 cd changer attached. The top portion (radio & 1-cd function) is working fine. The 4 cd changer is not working, I keep getting an error message and none of...
Bose does not release their schematics or parts lists, effectively making themselves the only repair center for their products. Your only safe repair method is to contact the service/repair center at www.bose.com. They will likely offer you a flat rate repair or credit towards the purchase of a new unit.
Dec 07, 2009 | Bose Wave Music System CD Shelf System
Six cd changer with 6 cds stuck inside, none will play and message appears no cd, or cd error,or eject error in a 2004 ford escape
Ok this may seem barbaric but it worked on mine.......Hit the top of the stereo a couple of times and see if it corrects the problem.
May 30, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Blaupunkt CD Changer CDC-A08 - Cartridge eject problem
I am waiting for a reply from the Authorised Blaupunkt Service Agent for a solution to this problem &
shall let you know when it is solved. As per my telcon with him it is an alignment problem of the
Cartridge carrier, but he will have to look at the Unit later, when he is free.
Mar 22, 2009 | Blaupunkt CDC-A08 10-Disc CD Changer
Cds Stuck in cd changer. stuck at no. 6.
i have a infiniti i-35 2002 and my cd player won't play or eject i was switching cd's on no. 4 and when it went in it got stuck inside it won't play no. 1thru6 are there any suggestions
Jun 16, 2006 | Bose Wave music system Multi-CD Changer...
66 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
