Question about Dell Dimension 3000 PC Desktop
My dell dimension 3000 goes to blank screen after it shows windows xp logo and seems to stop there, how do I fix this?
  • 26 Answers
Have you tried starting in safe mood and then ran a scan of the hard drive, it could possably correct any file errors that the start up files may have Hope this Works Steve
Posted on Oct 01, 2009
My Dell Dimension 8400 desktop computer using Windows Xp operating system. The monitor shows the Xp Logo at first. Then the screen goes blank about 30 seconds into the boot process. What can I do to g
If you hit <F12> key upon boot-up and the monitor displays a boot menu, then you probably have an issue with your XP software. Meaning that you may have to re-install XP (by the way, XP is no longer supported).
Jan 28, 2012 | Dell Dimension 8400 PC Desktop
Dell Dimension 3000 Video problem
There may be a problem with your windows installation. Search Google for Hirens boot CD, it is a free download and should contain a live XP installation. When you turn on the computer tap the appropriate button to reach the boot menu, then insert the CD and select your CD drive. Once booted it should display a live XP.
Alternatively you may have your monitor set to an incompatible resolution. If tapping F8 won't display the advanced boot menu then try finding an auto setup on your monitor or change the resolution using the monitors controls. If the advanced boot menu does display then select low resolution mode.
Hope this helps,
www.PuterCare.com
Jul 02, 2010 | Dell Dimension 3000 PC Desktop
I want to factory restore my dell dimensions 3000.
There are three methods available.
1) Use Windows XP System Restore.
If you cannot access Windows XP, the following two methods are available.
2) Use the Dell Operating System CD, and the Dell Resource CD.
If you do not have these restoration CD's,
3) Use Dell Restore by Symantec
With this method all personal files you have, and any programs, or applications you have installed, or downloaded, will be GONE.
(Personal Files: My Pictures, My Music, My Videos, and personal files you have created)
Turn the computer on. AS SOON as you see -
www.dell.com, appear in the blue bar, Press -
the CTRL key, AND the F11 key -
AT THE SAME TIME. (Not shouting)
If you do not press both keys at the same time, and in time, let the computer load. It may stop at a blank screen, with a blinking cursor.
It's okay. Now press the CTRL key, ALT key, and DELete key at the same time.
This will restart your computer. Try again when you see the www.dell.com logo.
If upon pressing the CTRL key, and F11 key, you go to the next screen, left-click on - Restore
On the next screen click on - Confirm
Takes about 6 to 10 minutes.
After the restoration has stopped, click on Finish.
Your computer will now reboot.
Should you need help with Windows XP System Restore, or using your Dell restoration disks, please state so in a comment.
Jan 31, 2010 | Dell Dimension 3000 PC Desktop
It starts with Dell Scrn followed by Windows Logo, then it stops
Should not be with the hardware This seems to be a problem with windows.Try starting on safemode. Otherwise you may have to reinstall Windows.
Regards
Aug 11, 2009 | Computers & Internet
Dell dimension 3000. Just Black Screen no Windows XP.
From your description, you were able to boot the machine properly in Safe Mode. While in Safe Mode, change the video resolution to the lowest possible (color depth does not matter at this point). You should also check that you are configured for single monitor operation if your video card supports multiple monitors. Reboot the machine normally. If all goes well, you can readjust your video settings for a higher resolution again.
Jul 06, 2009 | Dell Dimension 3000 PC Desktop
Dell 8400 Refurbished by with WinXP Pro preinstalled will not boot up. Gets past Dell XP Logo, then goes to blank screen with curser...however, keyboard locks up and can not get any further? What's th
windows is not loading properly.
if you're not worried about anything on the computer:
insert the recovery CD, boot the system to the CD, and reinsatll windows.
May 19, 2009 | Dell Dimension 8400 PC Desktop
Dell dimension E310 wont boot
Go in bios and change the SATA mode to IDE or compaitibilty then check whether it is working or not
Feb 17, 2009 | Dell Dimension E310 PC Desktop
Blank screen when computer is turned on
When you get the Dell splash screen press the F2 key to get into setup. Use the arrow keys to go down to Drive Configuration and press enter. Go down to Primary Master Drive and press enter. Is the Hard Drive listed there? If not, that is your problem. Press Escape then use arrows to go down to Memory Information and press Enter. Is all of your Memory listed? If not, that could be the problem. Press "esc" to get out of setup. If the Computer does not freeze while in setup I would suspect the Hard Drive is bad. Is the Pointer responding to Mouse movement or does it lock up? In your situation I would first try to Boot from the Windows CD. Write back and I can explain how to do this. If that does not work I would begin to test Hardware. Do you hear any Beeps when the unit is turned on? If you can, E-mail back with more Info.
Jan 16, 2009 | Dell Dimension 3000 PC Desktop
Blank monitor
To resolve the problem,do the following step,
1. Power on the system
2. At dell logo screen before windows xp starts to load tap on the F8 key slowly 5 to 8 times
3. Select safe mode
4 Hit enter on the next screen and logon using the administrator or your name
5. Do the system restore, when you have logged on, this would return your system back to the date when it was working fine
6. To system restore
click start>all programs>accessories>system tools >system restore
Thanks
proton
Oct 11, 2008 | Dell Dimension 2400 PC Desktop
Used Dell Dimension 3000 drive issues
If you mean you need to install windows, you need to set your cdrom drive as first boot device in advanced bios settings or it will try to boot into a non-existent windows. Make sure your hdd is showing as the master drive, save settings and exit bios. Re-boot pc with windows disc in cd drive and hit enter when prompted to boot from cd.
Jan 26, 2007 | Dell Dimension 3000® Pentium® 4...
Dell Dimension 3000 PC Desktop Logo
451 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
