Question about Peg Perego John Deere Gator HPX Ride on Toy
How long is the battery suposed to charge for the john deere gator
    Genius:
  • Peg Perego Master
  • 1,508 Answers
1 hour for each ah the battery is, so if its a 12ah battery charge it for 12 hours
Posted on Jun 12, 2012
  • 60 Answers
SOURCE: old john deere gator and battery new charger still will not move
Could be several things.  Your battery could be bad. After not being charged for a while, they do go bad- often. You may want to try a new battery along with your new charger.  You could also have a switch /connection problem. If you get a new battery and it still doesnt work, you may want to check the switches and wiring. It is not uncommon for the switch to go bad especially if it had been stored outside.
Posted on Mar 11, 2009
SOURCE: kids john deere gator shifter won't go into reverse
I took the shift assembly apart. The switches weren't set in right. Once I put them in the shifter lined up and it works fine
Posted on Mar 20, 2009
  • 156 Answers
SOURCE: help for my childs John Deer Gator
the peg perego gators have two switches in the shifter that need replaced.
I have replaced them before on my grandkid's gator.
Here is the website I get my parts from
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
You can also call them direct at 1.801.655.0800.
They seem to always know which part I need and I have always been very happy with their service.
Hope this helps
Posted on Mar 18, 2010
  • 19 Answers
SOURCE: john deere gator 1999 4x6 overheating.replaced
bleed air out of cooling system contact dealer for instructoins
Posted on Aug 17, 2010
Samir3050
  • 70 Answers
SOURCE: Our son's peg perego john deere gator stopped
It is most likely the Gearbox, it is easy to find and easy to replace. It is right under the gear shifter and is a "harness" with wires that will need replaced, if you call the tech support for Peg Perego they are very helpful and will get you on the right track. Your old battery is most likely fine, but keep it until you fix the gearbox switch. Afterward (when gator is again operational) I would imagine you could return the new battery since you really should not need it. Peg Perego support is 1800-728-2108 and you can also look for parts at www.mypegperegoparts.com
Posted on Mar 01, 2011
Someone gave me a Peg Perego John Deere Gator that needed a new battery.
check the battery with a multimeter and make sure that it is putting out at least 12 volts
Mar 20, 2013 | Peg Perego John Deere Gator HPX Ride on...
Our john deere gator won't run
how do you know that the battery is charged? it could be that the charger isn't working. I would check the charger with a multimeter and verify that its putting out enough volts to charge the battery, it should be putting out between 13.8 and 14.6 volts
Apr 29, 2012 | Peg Perego John Deere Gator HPX
Help for my childs John Deer Gator
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
May 09, 2010 | Peg Perego John Deere Gator HPX Ride on...
Hope this helps
Mar 17, 2010 | Peg Perego John Deere Gator HPX Ride on...
Battery is charged but car is still not working,
I have the switch go bad on the gas pedal. You can find a replacement here http://tigerimports.net/sunshop/
Nov 30, 2009 | Peg Perego John Deere Gator HPX Ride on...
Old john deere gator and battery new charger still will not move
Dec 15, 2008 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego John Deere Gator HPX Ride on Toy Logo
148 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
