Question about eMachines EL1600-01
I need to install a fax modem and do not know how
I need to install a fax modem and can not remove the computer cover
  • 26 Answers
Hey thier is some screws holding the case cover to the chassis should be two at least Small phillips head screw's ,and depending on your case it either has a side panel that can be removed by gentally pushing off the side after the screws have been removed ( dont for get to unplug the energy supply cord before seeking to remove the cover) if your comp is a one peice cover you will have o remove at least four screw's to get the cover free to be removed off of the chassis,they also slide back and then come off Hope this helps Steve
Posted on Oct 01, 2009
HP USB Modem does not break dial tone
If the information connected to your post is all correct (56k V90 usb), and you are using one line for both the internet and the fax, you should hang up from the internet before you try to dial out the fax.
You have not indicated your PC model, so I don't know what operating system you are using. For XP and newer versions, you have to set up and configure the fax using the wizard or configuration software. If you have not done that yet, you need to.
In xp, go to start, Programs , Accessories , Communication , Fax , and then click Fax Console.
You said your computer is new. Win 7 and Vista are much the same:
1.Click the Start button , click All Programs, and then click Windows Fax and Scan.
2.At the bottom of the left pane, click Fax, and then click New Fax on the toolbar to launch the Fax Setup wizard.
3.Click Connect to a fax modem and follow the instructions.
You also need to make sure that your fax/modem is correctly listed in the control panel. In XP, start, control panel, printers and devices. If you do not have a fax printer listed, you need to "install a local fax printer."
The installation wizard should work in both OS without much trouble. If you do have difficulty, Microsoft and adobe both have "virtual printers" you can use. Look in Microsoft office or online.
Also check control panel of 7 to make sure that your modem and fax are listed correctly. Thanks for using Fixya.
Jan 01, 2010 | HP (56K V90 USB) Modem
Tip
How to Configure Windows XP to send and receive Fax?
If you are using windows XP, you can use sending and receiving option for fax service built into windows XP. You can enjoy free facilities of fax from your computer, because buying a dedicated fax machine for home or small office may not be a feasible option. Using windows XP based fax services; you can read, save, forward, delete the fax messages. By default fax service is not installed in your windows XP, but if you have windows XP CD, you can install fax feature using Add or Remove Program option.
Follow the gives steps to install fax components:
  • To install this feature, you will need to be logged into your computer with administrative rights.
  • Make sure, you have installed modem driver on your computer before running fax components setup.
  • Now click on Start button and go to System Control Panel then double click on Add or Remove Program.
  • Select the Fax services check box under Add or Remove Windows components.
  • Now click Next to finish the fax installation wizard and close it.
After the fax components installed, now configure the fax setting before using it.
  • First click on Start button, go to All Programs> Accessories> Communications then click on Fax Console.
  • Now in fax configuration wizard, type the fax cover page information then click on Next.
  • Select the suitable modem for fax and also enable others send and receive options.
  • Now type the TSID (Transmitting Subscriber Identification) and click Next then type here CSID (Called Subscriber Identification) and again Next.
  • At the end select the printer to be automatically printing the fax and click to finish.
on Feb 13, 2010 | Computers & Internet
I am trying to use the fax facility on my epson600fw.my isp is aol .Problem no dial tone. What connections are necessary............via printer,modem & computer ?
Typically, a fax machine is connected directly to a telephone wall jack with a known working connection. Try plugging the fax machine directly into a wall jack first and pick up the handset on the fax machine if it has one. You should get a dial tone. Then try to fax something to someone you know.
The machine can also usually be routed through the modem in a computer by connecting the "line" cord on the modem to the wall jack and plugging the fax machine into the the "phone" jack on the modem. You may need to install the software that came with the fax machine to get this to work.
If you have no dial tone, check the wall jack with a known to be working single line phone. If there is a dial tone, it's something to do with fax machine, the computer modem or the connections.
Some fax machines can take advantage of internet faxing through a cable modem or DSL connection. Check your manual for the options available.
Apr 18, 2009 | Lexmark X5470 All-In-One InkJet Printer
NetoDragon voice-fax 56k modem - i need a driver for this
this might be the driver
http://www.modem-drivers.com/dgdlsm.php?driverid=658529
Answer the I am not a robot question and the file will download being
the zip file LM-156n-lg-winxp-sp2.ZIP
use http://www.7-zip.org/
zip7 to unzip it (download and install if you do not have an unzipping software already installed)
then point the driver have disk option for updating the modem driver / or adding the modem - to the folder you extract the drirer files to.
Not sure if you have a pci modem or a external modem
Not sure about the updating file that was exe was not game to run this might be dangerous (virus / spyware danger )
May 01, 2017 | Motorola Computers & Internet
How fax work in DFM-560EL
my windows XP detect my PCI smart link modem
but can't find the driver for it
Oct 28, 2008 | Computers & Internet
I need to know how to connect my fax to my computer.
hi there,
May i know what is your purpose connecting those unit?
If you want your computer can dial up internet connection, just plug your phone line to computer modem port and other side plug to the phone port at your fax machine.
If you want your computer can send fax, same with above tips. but you must install fax program at your computer, so you can directly send fax through your computer.
br
Aug 07, 2008 | Computers & Internet
Fax software
Good software, but not quite free!
MightyFAX has a 30-Day Free Trial, after that $19.95, with free updates for life. http://rkssoftware.com/mightyfax/overview.html
eFax Messenger $19.95
http://www.efax.com/en/efax/twa/productOverview
Jul 19, 2008 | Computers & Internet
Neto dragon v92 fax modem drivers
i have card neto dargon fax modem ,when i was formated couldn't work...
because this CD for fax modem was losted>>
so can send to my this file for this fax modem to install on my computer?
Jun 28, 2008 | Telebit Refurbished OPEN BOX EXTERNAL...
I need a driver for my NetoDragon 56k modem fax & voice. My computer was redone and the dingbat I took it to didn't even load in my drivers for fax or my fax talk communicator program which i had asked him to do. (unfortunately my regular computer guy is out of the country until..
Dec 16, 2007 | Neto Dragon FM56-V92 Modem
eMachines EL1600-01  Logo
74 people viewed this question
Top eMachines Computers & Internet Experts
brian soufane
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
