Question about Lexmark P315 InkJet Photo Printer
I am asking this question for my son. His power went out and now his printer when you turn it on blinks blue and will do nothing else. Is there something we can do?
  • Lexmark Expert
  • 228 Answers
It seems there is a possibility of a problem with the printer itself, or perhaps the cartridges. You should first self-test the printer, using the instructions below. (Since we are unsure where the problem exists, we must do eliminative troubleshooting to rule out parts of the printing system. The self-test allows us to rule out software and the cable by testing the hardware by itself. Please note that this is not a "fix," but rather a diagnostic test to determine if your hardware is at fault.)
First, please disconnect and then reconnect the power supply on the printer and make sure it makes a setup noise when the cable is reattached. Will the printer perform a form feed with paper loaded when the gray button is pressed? If not, you can stop here and write back to let us know and we can give you further instructions. It's most likely, however, that the power-on and form-feed will work fine.
Next, try this printer self-test by following the steps given below:
1. Press the "Menu" button to escape "Photo Mode."
2. Press the "Down Arrow" until the screen shows "Print Test Page."
3. Press the "Select" button to print the Test Page.
4. The test is not continuous.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously).
Should this test fail, remove both cartridges and try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, you may have a paper jam, or the printer may require service.
Remove the paper from the printer and check for any obstacles (pens, thumbtacks, paper clips, etc.) or other obstructions. If you don't see any, disconnect the cables from the printer, turn it upside down and gently shake it to see if anything falls out. (Be careful to hold the cover shut during this procedure, and don't look up into the printer while you're shaking it.) In the event nothing comes out of the printer, you may require service to the printer. Stop here and let us know if this is the case, and we can provide you with further instructions.
If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
However, you may have to clear the NVRAM to resolve this issue. Please follow the steps given below:
3. Press the "Up-Arrow" and "Menu" Buttons at the same time.
4. Press the down arrow until the LCD displays "Clean NVRAM."
5. Press "Select" The LCD should display "Success" or "Failed"
Posted on Oct 01, 2009
My Brother HL-2140 Went out in a storm. All three lights just keep blinking no matter what I do. Held down on the blue light button a number of time, restarted computer, turned off printer, reloaded ink...
You can find the usre's manual here:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hl2140_all&dlid=&flang=English&type2=-1
1) If the LARGE BLUE BUTTON is blinking:
Data remaining in memory
There is remaining print data in the printer memory. If the Ready LED is blinking for
a long time and nothing has printed, press the Go button to print the remaining data
in the memory.
2) If the TONER LED is blinking:
Toner low
Indicates that the toner cartridge is nearly empty. Buy a new toner cartridge and have
it ready for when Toner life end is indicated.
The Toner LED will turn on for 2 seconds and off for 3 seconds.
3) If the DRUM LED is blinking:
Drum life end soon
The drum unit is near the end of its life. We recommend that you get a new drum unit
to replace the current one. See Replacing the drum unit on page 69.
The Drum LED will turn on for 2 seconds and off for 3 seconds.
4) If the RED ERROR LED is blinking:
Front cover is open
Close the front cover of the printer.
Fuser cover is open
Close the fuser cover located behind the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 85. If the printer
does not start printing, press the Go button.
Memory full
The printer memory is full and the printer cannot print full pages of a document.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document.
Mar 26, 2010 | Brother HL 2140 Laser Printer
Screen went dark
Ur video ic inverter board is dead.
U need a new one.
Aug 25, 2009 | Televison & Video
I have a JVC LT-42X579 TV. I got home tonight and
This is common problem of the failure of power supply board inside TV. You need technician to figure out this problem.
Aug 13, 2009 | Televison & Video
Canon Pixma iP2000: yellow power light blinks-reset doesn't work
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 02, 2009 | Canon PIXMA iP2000 InkJet Printer
Attention light on hp 1115photosmart
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Jan 01, 2009 | HP PSC 1410 All-In-One InkJet Printer
No power
When I turn on the tv, there's the green light, that shows it's on, but it's blinking green and the screen is black
Jul 01, 2008 | Hitachi 53UDX10B 53" Rear Projection...
No power
check ur smps and power connector Mother board ok
next power switch for on/off ok check front panel byy
May 17, 2008 | Intel Motherboard
Printer is on but cannot print
if your power light is off and the paper and ink lights are flashing try this.
1. remove all the paper,
2. open the cover and check for paper jam
3. make sure the ink cartridge lid is securley in place by opening and re closing the ink cartridge lid
reclose the lid, disconnect the power supply and hold the power button for 30 seconds. reinstall the power plug and turn the printer back on.
hope this helps
May 12, 2008 | Epson Stylus® Photo R2400 InkJet Printer
TV turned off, blinking power
probably horizontal output went out,and cap(big Blue box cap).
Sep 09, 2007 | RCA F20TF20 20" TV
Lexmark P315 InkJet Photo Printer Logo
98 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
