Question about D-Link AirPlus G DWL-G510 802.11g/b Wireless Adapter
Changed router to airport extreme - no connection
I recently moved and change from a Linksys router to an Apple Airport Extreme 802.11n router.  I'm told it should work with my d-link wireless, but I have not made a successful connection.  Is this WP2 compatible?  is the Network key format the same?
    Scholar:
  • 102 Answers
Bayoubill:
I am sure that Airports are WPA compatible. You manually put in the key of WPA or WPA2 in the router itself (in your case since you changed the router so please put in the key onto your aiport) make sure that this key matches the key onto the clients workstations or laptops.
Let me know.
Thanks
Posted on Dec 20, 2007
My iPad won't connect to Airport Extreme WiFi
Is your A P E a hidden network?, if so just type in the name of your router name and scan, it will find and ask for a password
Apr 28, 2012 | Apple AirPort Extreme Router
Trying to update firmware on y airport extreme but i forgot my password
You need to perform a soft reset of your router. There directions to do this from the Apple web site are:
  1. Connect the AirPort Base Station or Time Capsule to power.
  2. Press and hold the reset button with a pen or pencil for 1 full second, then release it. The light (LED) will begin flashing amber, indicating that the AirPort Base Station or Time Capsule is in soft reset mode.
  3. From the AirPort menu bar item, choose the network created by the AirPort Base Station or Time Capsule (the network name does not change).
  4. Open AirPort Utility in Applications > Utilities on a Mac using Mac OS X, and in Start > All Programs > AirPort on a computer using Windows.
  5. Select the AirPort Base Station or Time Capsule and click Continue.
  6. A window indicating that the device has been reset will appear.
  7. Select "Restore the previous settings" and select OK.
  8. Move through subsequent windows to make changes to your passwords or other settings as desired, clicking Continue after each one.
  9. When you have moved through all of the selection windows you will be able to select Update. Click Update to install the new settings.
  10. Click Continue to allow your AirPort Base Station or Time Capsule to restart.
  11. Quit AirPort Utility.
These directions are from the Apple Support Web Site:
http://support.apple.com/kb/ht3728
Jan 02, 2011 | Apple AirPort Extreme Base Station
Is too short for her MacBook Pro. -Thanks.
I would recommend purchasing a newer router that is more powerful. The Apple Airport Extreme is a fantastic router. If none of these choices work then you can either connect your Macbook via ethernet or move it closer to your router. here is the Apple Airport Extreme. http://store.apple.com/us/product/MC340LL/A/AirPort-Extreme?mco=MTY3ODQ5OTY
Dec 19, 2010 | Linksys WRT54G Wireless-G 802.11g...
Wont connect to each other
connect the airport extreme to the voyager using a network cable... factory reset the extreme and then connect to it using the airport utility... you should get a setup screen where you can switch the extreme to "bridge mode" .. everything else should happen automatically.. you will then have 2 wireless networks?
May 03, 2009 | Apple AirPort Extreme Base Station...
I want ot disable DHCP on apple extreme router. Because MS 2008 SBS R2 scans for DHCP servers and fails to config if found an other dhcp server (apple extreme)
1) Open Airport Utility (Applications/Utilities).
2) Select the Airport Extreme in the left hand panel and press Manual Setup
3) Choose Internet in the top menu bar
4) Change Connection Sharing to 'Off' (Bridge Mode.
Press update to restart the Airport and save the settings.
Mar 16, 2009 | Apple AirPort Extreme Router
Airport extreme / Windows XP with VPN problem
have you reset the airport extreme? theres a tiny hole you can push in w a paperclip. Also, do you have the latest firmware?
Mar 10, 2009 | Apple AirPort Extreme Router
Apple extreme bridged to apple extreme (Windows network)
OK, do you have the latest version of Apple's Airport Utility: Version 5.4.1 (541.9) ?
If you don't, get it... it's got an excellent interface that will walk you through bridging two wireless routers together.
Once you get your hands on it, you will need to choose which airport will be the primary and which will be the secondary. Ideally, pick the one connected to the highest speed and most reliable internet access.
Connect to the secondary airport and configure it as bridge to the primary, the Airport Utility will walk you through it step by step.
Jan 13, 2009 | Apple AirPort Extreme Base Station...
Cant connect to internet with Airport Extreme 802.11n
An airport extreme is just a dunb Wireless Access Point. It could be that it has been mated to the Linksys router and is looking at a different set if IP addresses that are not coming from the etherent connection out of the wall.
If you know how to obtain network addresses on your computer, find out what you get from the wall jack and from the airport through the Linksys. You can try to reset and reconfigure the Airport, but if you are not familiar with the hardware, get someone who is to help you. The manual offers several tips and procedures to do this http://manuals.info.apple.com/en/AirPortExtremeBaseStationSetupGuide.pdf
Carl
Oct 09, 2008 | Apple AirPort Base Station
D-Link AirPlus G DWL-G510 802.11g/b Wireless Adapter Logo
382 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
