Question about Coby MP-C582 MP3 Player
Hello i am having problems setting my coby mp3 player to the vaio computer so that i can put song on the player i already have my playlist in order but when i press start sync nothing happens what should i do rhondasuggs9
    President:
  • 803 Answers
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer?s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings. Then following the following the instruction about loading it throuh Windows Media Player: Connect your MP3 player to the computer using the USB cord. Open the Windows Media Player program. When you open the program, your device will be recognized through the "Sync" button on the tool bar that runs across the top of the page. Click on the "Sync" button. To the right a column will appear which says "sync list" at the top. Below the sync list it will say "Drag items here to create sync list." Your library is located in the middle part of the screen. (Your playlists and library listings are in a column to the left.) To select the songs you wish to transfer, simply click on the song and literally drag it over to the listing on the right. When your mouse is over the column, the text will lighten, and a small box with a plus sign will appear. When this happens, let up off the mouse button. The new song will be listed in the sync list. When you have a listing of all the songs you wish to ad, click on the "Start sync" button near the bottom of the column. You will be taken to another screen which will have a listing of the songs you want to add. The computer will sync the songs to the device. When the synchronization is complete, the sync device column will return to the right of the screen. A message will appear letting you know that it is ok for you to disconnect your device. When you unplug the device, the MP3 player should flash a message that says, "Creating (or configuring) library."
Posted on Oct 01, 2009
How do I put songs in playlist on my Coby MP620 MP3 player
The Coby is weird, but I found a way to create playlists. It might not be the "real" way, but it works :)
Before I plug the mp3 in my computer I create folders containing the songs I want for each play list. For example I'd create one folder labeled "work out" for songs I want to listen to while working out, and another folder labeled "sleep" for songs to listen to while sleeping, or you could label them based on artists or genre or etc. Then I would copy the songs I want in each playlist into their respective folders.
Next, I plug my coby into my computer, and open it's folder. (should be in computers, and have a icon with a C on it). I'd copy (or click and drag into the coby folder) my play list folders (the ones I labeled work out and sleep). Then eject and remove my mp3.
If you do this, when you turn on your mp3 you should select Music. Then select Broswer (on the bottom). Select the first row, which has the symbol "\" [underneath this is all your songs] and you'll see the names of your play list folders (they'll be below ROOT, MAC OS X Coby Me, and PHOTOS) . If you select your play list name you'll see and be able to play the songs under that playlist.
Feb 19, 2013 | Coby MP620 MP3 Player
How do I create a playlist on my Coby MP620? I can not get the songs onto the playlist
I have the same problem with mi COBY MP3, no matter how mush I search I cant create a working playlist. So you better buy another mp3 player. COBY sucks at every thing.
Nov 10, 2010 | Coby MP-610 MP3 Player
I ADDED SONGS TO MY COBY MP815 USING WINDOWS MEDIA PLAYER AND NOW IT WONT TURN ON. I PLUG IT INTO MY COMPUTER USING MY USB AND WHEN I UNPLUG MY USB FROM THE MP815 THE SCREEN FLASHES WHITE FOR A QUICK...
Assuming the player is charged. (For charging always connect directly to the computer, not through a reader or hub).
When buttons on the player do not react, reset the player:
Disconnect the player from the computer.
See that the HOLD button is not engaged.
Gently push the RESET button on the rear side: use a narrow pointed
object, like a paperclip.
Did synchronization of the songs in Windows Media Player fail ?
For transferring songs, check in Windows Media Player:
1. The player is detected in Windows Media Player 10 or higher.
2. Setup the Library / Add to Library: add the location of songs you want to transfer in the library.
3. Create Playlist; give the list a name and put songs in a playlist
4. Sync Playlist: transfer the list of songs onto the player and wait for the message until you're allowed to disconnect.
Jun 23, 2010 | Coby MP815 Digital Media Player
How to get songs back in the coby mp3?
On the MP610 you could use either Windows Media Player 11 or Coby Media Manager for transfers of songs.
Next steps are important for adding files onto the player:
1. The player should be detected in the software for transfers, when connecting the USB cable.
2. Setup your library in the software (Add to library): There has to be a list of folders in the software manager, where your music is located on the computer.
3. Create a playlist in the software: make a list of songs, you want to transfer onto your player
4. Sync the playlist onto the player.
When needing more help, just add text in this reply.
May 11, 2010 | Coby MP-610 MP3 Player
How do you make a playlist
You can make a Quick Play List for your favorite songs to playback on the MP610, see page 13 of the manual:
http://www.cobyusa.com/files/manuals/MP610_MN.pdf
You can also use the Coby Media Manager for making playlists on the computer and transferring the lists to the player, connecting through the provided USB cable.
Need more help ? Just post a comment.
Dec 30, 2009 | Coby MP-610 MP3 Player
What does sychronizing do?
Synchronizing on most mp3 players is used for transferring one or more playlists from a computer to the player, having a connection through USB.
Creating playlists, putting mp3 data in a list with a certain name,
mp3 could be put in a specific order.
The player preserves some space of memory to remember these playlists and the playing order.
Some players support subfolders, but not having the manual for the
MP200 I'm not sure if that will work.
e.g.
MUSIC > music list 1
> music list 2
Dec 20, 2009 | SanDisk Sansa e250 MP3 Player
Coby mp705-4G mp3 player won't put songs in the right order
In the settings of the player there is an option to order the tracks in your album . U can check it and can make it work as u wish
Thank U
Please rate as it wil cost u just one click
Nov 02, 2009 | Coby MP-705 Digital Media Player
Shuffle seems to play same songs
The shuffle feature shuffles songs randomly - no way to change the order.
On the Sansa Clip, you have to make the changes to the song order in Windows Media Player first, before you transfer the playlist to the Sansa, using the advanced tag editor function; change the track number. If you have already transferred the song(s) over to the Sansa, you must delete the songs on the Sansa first, or else it will not accept the playlist transfer with the new track order. You can always go back and change the track numbers that are stored in your WMP library after you have transferred the playlist to the Sansa.
-Tha Mp3 Doctor
Jan 25, 2008 | SanDisk Sansa Clip MP3 Player
Can't transfer playlists
Try to do a firmware update on the device..if thats doesnt solve the problem contact coby...its a well known problem with the sandisk devices but i am not sure if its the same for coby...
Jan 05, 2008 | Coby MPC895 MP3 Player
Coby MP-C582 MP3 Player Logo
161 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
