Question about Toshiba 62HMX84 62" Rear Projection HDTV
Picture loss after picture begins to flash. blue and yellow light
Toshiba 62"rear projection tv HDTV, DLP etc. picture begins to flash and then screen goes black. sometimes still have audio sometimes tv shuts all the way down. blue and yellow lights flashing on the front of the tv below the screen
  • 4 Answers
Most likely the lamp is dying. Try replacing the lamp before calling a repair tech. What does the Owners manual say about the blink lights?
Posted on Oct 06, 2009
techman
  • 3130 Answers
SOURCE: 62" Toshiba Theaterwide HD DLP
If you followed the directions in the owners manual, then the bulb assembly may have melted onto the light engine, and unless you have a service manual, and know how this set comes apart, the best advice I can give you would be to call out an authorized Toshiba service tech too assist you in this repair. The set may have had a cooling fan issue before the bulb blew, or could be why the bulb blew but got too hot before it did so. Good Luck
Posted on Aug 14, 2007
SOURCE: Television Problem
I have just run into the same thing, prior to the picture not coming on there was a loud whining noise, I thought it was the fan in the back, but, what I tried was removing the lower back panel, LIGHTLY tapping the light wheel assembly just left of the Bulb housing, and using a shop vac to first, **** the assembly around the edges and then reversing the air and Blowing it out. After much dust and dirt flying around the TV came on. It now only makes a little noise now and then, but, I will try this again today and then put the back panel back on. Since it would probably cost as much as a new TV for the color wheel, I gave this a try. For now, it is working.
Mr. Wizard
Posted on Jul 21, 2008
  • 58 Answers
SOURCE: Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Posted on Apr 18, 2009
roety
  • 585 Answers
SOURCE: Toshiba 65" Rear Projection DLP TV
Hi my name is Roety,
I can help you with your issue ,
Most likey you need the Lamp replaced
Use google to buy one using the model #
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Posted on Nov 20, 2009
SOURCE: My Toshiba 62HM95 62 in. HDTV DLP TV won't turn
Most likely, you need to replace your DLP bulb. The one that comes with your TV will last a few years max. The replacements seem to only last about a year. D:
Posted on Dec 09, 2010
DLP rear projection tv picture fades after a while, image flikers
Good day!!!!
That problem is usually cause of bad light engine..Try to replace it with the same part #..
Jan 07, 2012 | Toshiba 62HM95 62" DLP HDTV
I have a 62" DLP
Replace the lamp, model # is TB25-LMP. Good luck
Jul 24, 2011 | Toshiba 62HMX84 62" Rear Projection HDTV
My Toshiba 62HM95 62 in. HDTV DLP TV won't turn on...the green and red lights under the power button remain on and the red light flashes. How do I fix this?
Dec 08, 2010 | Toshiba 62HM95 62" DLP HDTV
Green led indicator light is off on my 62" toshiba
when you turn it off your light blinks because your internal fans are still spinning allowing the inside of the chassis to cool off, hence the reason you dont watch a DLP TV and then unplug it. DLP's are JUNK
Dec 01, 2010 | Toshiba 62HMX84 62" Rear Projection HDTV
Toshiba 62HM84 Starting Problem
you need a balist.
olso in the cust menu is a quick start mode . turn it off
Nov 18, 2009 | Toshiba TheaterWide 62HM84 62" Rear...
I have 62 DLP rear projection
Bad Color Wheel is my First thoughts,Light Tunnel, But if Spots begin to appear Then Light Engine.
Sep 19, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Toshiba Rear Projection Screen Problem
It's a DLP right?
I think ur TV's bulb is dying...check the running hours of the bulb in the menu.
Rifaa
Nov 19, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
Toshiba 62HMX84 62" Rear Projection HDTV Logo
422 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
