Question about Maytag Refrigerators
I installed a universal ice maker and it did nothing
  • 80 Answers
Check for power where you plugged it in at.
Verify that the universal one is wired the same.
Posted on Oct 01, 2009
Installed new ice maker, it made one cycle but now does nothing.
Whats the modle #. Is there ice in the fill tube? Does this ice maker set side ways in the freezer?
Oct 28, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
No water to ice maker. Water dispenses in refrigerator ok. Filter is new. Also control panel not working in refrigerator section.
Its unusual that both parts would go at one time it could be you had a lightening strike or a power surge that took out both parts as they have nothing in common that one causes the other to operate other than temperature. This is what I would do. Since the control board is obviously bad I would replace that first. Let it run a day or two and if the ice maker does not start I would replace that part. I have linked them below.
To replace the ice maker module you must remove the ice maker and then remove the wiring before installing the new module to prevent the contacts from being bent inside the ice maker wire connector. Install the new module then connect the wires and place it in the freezer. Also if your ice maker has no water in it now the module is not the problem....get back to me.
Control Board
Ice maker Module
May 22, 2010 | Jenn-Air JFC2089HE French Door...
My ice maker is making ice but it won't harvest it out of the ice cube maker
Check for voltage between T and H; if you have 120 volts then the bi-metal (inside that ice mold thermostat) is bad. If it's good you will have 0 volts.
The thermostat is very easy to replace. Get the head off, then seperate the ice mold and frame. Replace the thermostat $24, nothing to it.
Part# 627985
May 08, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Ice maker is not working.
Ice maker has built in thermostat that turns cycle on at around 10 degrees F. If freezer temp does not reach that point the ice maker will not cycle. So either the freezer is not cold enough or the thermostat is faulty.
Make sure that the ice maker motor that turns the cams and controls the various stages is also working.
Apr 08, 2017 | Frigidaire 20.6 cu. ft. Top Freezer...
ice maker probably needs changed take a volt meter across the white and black wires to check for voltage if so change the ice maker,
for the compressor clicking on and off i recommend buying a universal 3n1 relay and trying it ... www.whirlpoolpartssurplus.com
May 07, 2009 | Kenmore 74810 / 74813 Top Freezer...
Ice from ice maker does not taste right
Hi
Ice storage bin needs to be emptied and washed. Unsealed packages in the refrigerator and/or freezer compartments may be transmitting odors/tastes to the ice cubes.
Interior of the refrigerator may need cleaning.
Water chemicals. Installing an in-line filter can help with many odor/taste complaints.
An open box of baking soda in the refrigerator section can help with preventing the transmitting of food odors.
This is a common in-line water filter, they are fairly easy to install and usually come with instructions.
Even when your well or municipal water supply provides healthy, potable water to your ice maker, some impurities may remain. These can affect the smell or taste of the ice cubes, and therefore the beverages in which you serve them. A taste and odor water filter on the incoming water-supply line--such as our charcoal "Universal Replacement Water Filter"--can help a lot.
Also, over time, the ice cube bin can absorb difficult-to-remove odors from the freezer. Some manufactures recommend that you replace the bin every 2 to 3 years, whenever it seems to be retaining objectionable odors and transferring them to the ice cubes.
A Fixya Rating would be appreciated.
Thanks
Rylee
Feb 11, 2009 | Whirlpool ED2GHEXN Side by Side...
Ice maker doesn't work
I have the same problem. I've had the freezer for 2 years & ice maker just stopped making ice this week. Freezer works O.K.
Jan 11, 2008 | Frigidaire 20.6 cu. ft. Top Freezer...
Ice maker quit working
what happened you reset the computer (mother board) chances are you had a brief glitch in your power and it made the computer go hey wire
Dec 15, 2007 | Whirlpool ED5FHEXMQ Side by Side...
Ice Maker Not Making Ice
Ice maker was installed properly, when you put the arm down it doesn't call for water to fill unit. It doesn't make any kind of noises at all. The water is turned on and all plugs are in there are no kinks in the line but when the arm is truned down for it to call for water nothing happens
The is for a frigidaire refrigerator.Ice maker is all new..
Nov 01, 2007 | Frigidaire 20.6 cu. ft. Top Freezer...
Refrigerators Logo
27 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
