Question about TruTech PLV16320 Television
Turns off, then back on -- when image on screen is mostly white
My wife noticed that when ads come on TV where the product is shown with a mostly white background (YouTube the Mirapex ad to see what I mean) we lose the picture for a few seconds.  It's almost like the TV turns off, then back on.  The little "YUV1 - 1080I" writing even comes up on the screen when the picture returns.
At first we thought it was DISH Network's stream (sometimes we lose the picture when the sky's cloudy) but when it started doing it on clear days, we began to suspect the television.  Our model number is TruTech PLV16320.
We tried changing the brightness settings to the default "Soft" mode thinking it might have something to do with the intensity of the light, but it continues to happen, regardless.
  • Mulcyber Feb 02, 2008
    Okay, I think I figured it out by myself.  There are two inputs for the YUV settings; YUV1 and YUV2.  The cords for the YUV2 actually plug in on the side of the computer rather than under the back panel (like the YUV1 does).  Anyway, I just switched the RGB cords from the YUV1 inputs to the YUV2 inputs and voila -- no more blank screens.
    I guess the YUV1 input is damaged or something.
    President:
  • 814 Answers
You can contact TruTech technical service for help with your problem at these telephone numbers: 1-800-525-6123 and 1-888-525-6252. They should be able to help you with your problems with the hook-up. I hope this helps you with your problem.
Posted on May 17, 2009
Blurry, purple bar across middle of plasma tv screen
Plasma screens are extremely susceptible to getting broken from any impacts to the face of the screen. What you are describing sound very much like distorted or dead pixels. It may not be a fixable issue, you may have to replace the entire unit or live with the purple bar. The reason you don't notice it as much when the screen is dark is because purple is on the darker end of the spectrum, and will be most visible in contrast to lighter ad brighter colors.
Apr 01, 2016 | Samsung Televison & Video
I have a Mitsubishi ws 55905 that I got for free. Noticed it works at first, then after about an hour. The tv power light is still on, but no image. Unplugged it and plugged it back in. Worked fine. The...
Internal circuit fault. Your TV need a through checkup. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jun 17, 2014 | Televison & Video
Rainbow static on Plasma Tv
The color static, if we are talking about the same thing, is usually a digital signal interference. Check cables, and digital converter if used.
May 21, 2013 | LG 42PQ30 42 in. Plasma TV
My sony KP-65WS500 turns on to blue screen then black with only sound, then shuts off? They just replaced are cable box a few days ago. We unhooked everything and tried to play a dvd....same thing happens?...
It seems that you have an issue with your Video Board, but you say that when the screen turns black, it shuts off. The lamp is not going to be the issue here, since it only produces a white light, regarding the image cutting off, it could be the ballast, but before this, you should've notice a dimmer image. For what most probably the power supply might be having a glitch. Definitely I recommend to contact a Tech so they can analyze the symptoms on the TV and diagnose the issue.
Oct 18, 2009 | Sony Televison & Video
Philips Magnavox Projection T.V
you need to replace a cople of the opticoupers most likely, if you want to repair this and save yourself a lot of dough, contact me at techman32k-at-yahoo dot com
Larry Dillon
Aug 06, 2009 | Televison & Video
Sony Trinitron KV-19TS20 Screen displays purple static or awful image.
This unit needs a tuner. A new one from Sony will run over $70, so I doubt that it is worth it. It is possible that poor ground connections could cause something like this, but the symptoms seem a bit too severe. I think it is time to invest in a newer set.
Dan
Oct 01, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
New Sharp Aquos LC37X20E. After 30 mins turns itself off to standby and comes back on after 2-5mins (even though the automatic return to stanby has been set to "disable"). Eventually after...
According to Sharp it is a software problem. Engineer came, installed software update ,10 minute job.....TV worked fine for 1/2 day unfortunately: Then images turned black and white in all channels TV turned itself off, and stanby and OPC buttons started flashing. When TV came back on its own 10 mins later , screen had 2 large square staines superimposed in image (as if it was a burnt screen)...Engineer will be back next week...all quite sad really for a new TV.....will keep u posted
Jul 03, 2008 | Sharp Televison & Video
No image through lens
Normal 0 MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";}Service Notice: CCD Image Sensor Advisory (Updated 10/31/2006)
This Service Notice will update Canon U.S.A.,Inc.'s previous CCD Image Sensor Advisory, dated October 6, 2005.
It has come to our attention that the vendor-supplied CCD image sensor usedin certain Canon digital cameras and digital video camcorders may cause thefollowing malfunction: When the product is used in recording or playback mode,the LCD screen and/or electronic viewfinder may exhibit either a distortedimage or no image at all. While reports of this malfunction have been rare inthe United States,we have determined that it may occur if the product is exposed to hot and humidenvironments.
Notice of Additional Affected Products:
As a result of our continuing investigation of this malfunction, we havedetermined that the 11 models listed below, in addition to the 16 models listedin our Service Notice concerning this malfunction, dated October 6, 2005, may be affected.
Affected products:
- Camcorders: ZR60, ZR65 MC, ZR70 MC, ZR80, ZR85, ZR90, ELURA 40 MC, ELURA50
- Digital Cameras A60, A70, A75, A300, A310, S230, SD100, SD110, A40(*),A80(*), A85(*), A95(*), S1 IS(*), S60(*), S200(*), S330(*), S400(*), S410(*),S500(*)
*Models added as of Oct.31, 2006
Malfunction:
It has been confirmed that the connecting parts of the internal wiring of theCCD used in affected products may become disconnected, especially if theaffected products are stored or used in high-temperature and high-humidityenvironments. If this occurs, the signal is not output from the CCD normally inShooting Mode, which may cause a distorted image or the absence of an image.This malfunction can be confirmed on the LCD monitor screen during shooting.The same malfunction also appears on the recorded image.
Canon's Response:
Effective immediately, and regardless of warranty status, Canon will repair,free of charge, the products listed above exhibiting the above-mentionedmalfunction if Canon determines that the malfunction is caused by the CCD imagesensor. Canon will also cover the cost of shipping and handling in connectionwith this repair.
U.S. residents are kindly directed to contact the Canon Customer Support Center for furtherassistance at 1-800-828-4040. Support hours are Monday thru Friday - 8:00 AM
Apr 25, 2008 | Canon PowerShot SD110 / IXUS IIs Digital...
Image retention
most manufactures say not to have a still image on the screen for more than 15% of your viewing time. to fix this you will have to replace the optical assy. i did come across a sony projection where the burn in was actually on the screens themselves. the only thing you can try is to put an all white video pattern on your tv for at least 48 hrs.
Oct 06, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
Yellow residual image/smear
I think it is time to buy a new set but if you want to invest some money in it then take it to a qualified tech as these projection sets are a bit complicated.your problem is a convergence the projection lens needs to be adjusted lens.good luck and bleeeing from belize
Mar 20, 2007 | Hitachi 57F500 57" Rear Projection...
TruTech PLV16320 Television Logo
112 people viewed this question
Top TruTech Televison & Video Experts
Steve Allison
Steve Allison
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
