Question about Vacuums
Electrolux genesis lxe won't power on
This old vacuum was working fine until we changed the bag and then it would not power on. There is a red reset button which appears to be popped out, but it will not click in. Tried to punch it in while unplugged and plugged in with no results.
  • jwinkelman Oct 01, 2009
    Tried that no luck. The wifey tells me that it actually crapped out just before changing the bag. The cord is taped up at the top of the handle. Checked that and dont see that the power wires are comprised in any way.
  • Chemist1961 May 11, 2010
    Remove the bag and rotate it 180 degrees and reinsert. Be sure the bag is depressing the bag lockout (no bag) switch at the gasket area surrounding the bag chamber. \then try again and post back
SOURCE: Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Posted on Jun 20, 2008
  • 566 Answers
SOURCE: Electrolux #1521 Canister Vacuum won't stay closed
hi from uk your problem with the canister cover/door coming off whilst vaccing ? you have renewed bag ? ok but there is a filter/gauze also inside the canister where bag is fitted if you check inside you should see the filter at opposite end from where bag is secured it is usually fitted behind a slotted pull out plastic gate ? this filter/gauze is to allow air out of canister when vaccing and the filter traps any dust that may accumulate inside the canister case so the dust does not get blown out to atmosphere/rooms SO if this filter is clogged it will not allow vacced air to escape out of canister so result is build up of pressure within cylinder and eventually cover flips open ! so for now you can remove filter/gauze and wash then dry refit this will allow air to escape from canister but still retain dust particles from escaping as it is designed for however may i suggest you replace filter when convenient ? all above is on assuming that the latch on cover is working ok and not now damaged ? hope this helps best wishes
Posted on Mar 01, 2009
  • 73 Answers
SOURCE: Electrolux Vacuum keeps turning off and light looks like bag with
Turn the knob on the top of the vacuum all the way to the right.I had the same problem and that fixed it.
Posted on Aug 27, 2009
  • 5 Answers
SOURCE: Electrolux model LX vacuum- Problem, ejects empty
The vacuum is doing exactly what it is suppossed to do, on this model, the bag will eject when the suction is reduced due to the pores in the bag becoming clogged by dirt, dust, or fine powder. Try a NEW bag, and **** up less superfine dust such as baby powder or plaster dust that immediately clog the bag. Next, on later model LX's on the bottom of the canister near the bag door is a dial, setting the dial to a higher number will reduce the sensitivity of this automatic bag ejection operation and will allow the vacuum to continue to run until the bag is even more clogged, however, running the vacuum with a fully clogged bag causes the motor to overheat and reduces suction and damages the vacuum. If you have an early model LX, there may have been a "basement and attic" key mounted to the bottom, but often are lost by now and it is used to make such an adjustment. The 1952 model LX was the first with the diaphram automatic bag ejection system and the problem of the bag ejecting too soon was common. An improvement on the model LXI added the control dial with numbers 1 to 6 on it to adjust the sensitivity. I am looking up more info on adjusting a model without the dial because I just picked one up at an estate sale a few days ago and I've heard (some time ago) that the early ones with no dial had a "basement and attic" key that snapped to the bottom of the cleaner to make this adjustment, not sure where it is though and the one I have does not seem to have the key. Will let you know more if I find it! Thanks, I am an Electrolux fan and will use nothing else because I have used so many vacuums but love the convenience of Electrolux design and durability. They have been in my family since my grandparents came to America and are simply the best in my opinion.
Posted on Nov 22, 2009
  • 566 Answers
SOURCE: Electrolux Model 2100 vacuum won't work
hi from uk may i suggest you remove cover and the new dust collection bag then if you look in the bag compartment there is a gauze filter fitted usually grey in colour ? at opposite end of compartment where bag connects this gauze filter is the outlet from bag compartment that the air exhales when vac is operating ie as vac **** up dust into bag the bag has microscopic holes that allow sucked up air and dust to collect but keeps dust from passing into bag chamber but allows air to escape thro holes and so enter bag chamber then escapes via the gauze filter to outside of vac hope you follow this ?? now if this filter is blocked/never been cleaned/changed ? then the symptoms of indicator bag full light will come on you can remove and wash filter if it is gauze typ? dry and refit then try vacuuming ? or replace filter they are not expensive usually in pack of 3 in uk DO NOT RUN VAC WITHOUT THIS FILTER FITTED ! or you will have some dust in the room ? hope this helps?
Posted on Feb 27, 2010
The red light on my electrolux vacuum comes on and cuts power.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 26, 2010 | Electrolux Guardian Bagged Canister Vacuum
Canister starts, but vacuum does not start
Take the hose unpluged see vaccum is working or not.
IF NOT.
  1. BAG FULL
  2. HOSE CLOGGED
  3. BELT BROKEN/LOOSEN
Dec 28, 2009 | Electrolux Guardian Bagged Canister Vacuum
Electrolux vacuum power bar not turning
First thing is to push the circuit breaker button(reset button). If that dosen't work, check the belt. It could be broken.
Jul 10, 2009 | Electrolux Guardian Bagged Canister Vacuum
Vacuum just stopped working.
is there a filter in it if so clean the filter.try it without the bag in it.make sure the bag is in correctly.does the bag expand when you turn it on.you might have something caught up in the hose.take the hose off and blow througfh it.if you can't its clogged.also check the inlet where the dirt goes into the bag.the inlet might be clogged.please leave feedback
May 04, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Can't change bag - Electrolux Oxygen canister
my oxygen has a little red lever on lh side of bag enclosure, that has to be pushed to left and bag then is free to be removed. make sure you have the correct bag to replace.
Jan 28, 2009 | Electrolux Lux 5500 Canister Vacuum
My Electrolux upright worked fine
Are you using the proper bag? There's a kill/reset switch that needs to be pushed down by the rim of the bag before the unit will run.
Jun 22, 2008 | Electrolux Epic 6500 Vacuum
Full bag system works properly, but doesn't reset easily
Either there is something wrong with your switch. Which it doesnt sound like it. Take it to your dealer or call another one it sounds like the control valve needs to be replaced. I am a dealer 1-866-966-9350.
Jun 19, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Vacuums Logo
288 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
