I have a Whirlpool Duet model GHW9100LW1 purchased in Nov 2003 and the tub just began a serious knock during the high speed spin cycle. I checked the shocks, springs to ensure they were connected and they were. Could the shocks be bad? Could the drum bearing be bad? I have no water leaks. I have 4 boys in sports and being without a washer is bad news. Can anyone assist? Thanks, J Rancher
    President:
  • 744 Answers
Hello with the limited information you have supplied this sounds like it is going to be the bearing, this is not something I would suggest a DIY fix since you have to replace the rear half of the drum with this model. If you have any other questions please feel free to comment. Good Luck! Mike
Posted on Oct 01, 2009
Whirlpool trouble shooting
All Spin cycles regardless of load or even when unloaded and spinning?
If so suspension is broken.........Technician repair only, even the balance weights in the tub are too heavy for DIY to remove and replace springs
Sep 07, 2014 | Whirlpool WFW9550WW Duet 27" 4.4 cu. ft....
Whirlpool Duet Washer GHW9100LW1 symptoms of knocking noise during spin cycle. Efforts so far: checked shocks manually and observed during spin cycle and no excessive movement. Drum drive pulley:...
Always worth while adjusting the 'balance'!
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 01, 2011 | Whirlpool GHW9100L Front Load Washer
We have a Whirlpool Duet WFW9400SW02 that is making loud noise during the high speed spin cycles. It is only 13 mos old. Whirlpool will not even stand behind the parts. The repair person estimates over...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Loud knocking and vibration during spin
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
GHW9100LW1 outer front tub replacement. Is this a DIY project?
The first question I have is why to you want to replace the front tub? I had a problem with the metal tub knocking and gouging the front tub. When I took it apart, I found a broken bracket on the metal drum that caused it to spin off center.
If you want to replace the front tub, It is hard to get to, but it can be done. The front tub is held in place by two large springs at the top and 4 shock absorbers at the bottom. The shocks just turn 90 degrees and they can be disconnected.
Please be aware that there are three heave weights in the washer to make it run smooth during the spin cycle. Therefore, the tub assembly is heavy. There are also several wiring harnesses that have to be disconnected to get the tub out.
Once you get the tub out it is fairly easy to get the front off. There are about 20 clips that hold the front to the back tub.
It is a two man job since it is so heavy.
Nov 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9100 Drum Knocking/Plastic Tub Shredding
This is joyce
The bearings is gone in the drum, causing the drum to rub and run the wrong way one the pully, yes it is very exspensive, I have the newer model.
let me know if I can help
thanks
joyce
Feb 13, 2009 | Washing Machines
Whirlpool front load washer, Clicking noise during spin cycle
i would open the door nad with your hand (glove on if preferred), feel around the intereior of drom for prhaps a nails, or hair clip that has gotten caught in one of the many holes in tub
Dec 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
270 people viewed this question
Top Washing Machines Experts
