Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Having a problem with a mower on a model 2210. I
Having a problem with a mower on a model 2210. I cant keep the blades tightened. I keep twisting the bolts off in the spindles. What can i do to prevent this problem. The bolts are m12x25
  • 115 Answers
Lock washer or nylon could use lock tite to
Posted on Oct 01, 2009
LT2000 craftman mower bolt and nut that tightens blades keep coming loose
Get some red lock tight and put it on the spindle shaft threads. Sounds like the threads are worn down and just won't hold the spindle nut tight any longer.
Jul 02, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My blade keeps coming loose after hitting a rock on lawn mover
is the bolt stripped so it wont tighten?
Is the threaded hole on the Crankshaft of the mower cracked
Jul 26, 2013 | Mtd 22" Yard Machine Push Mower
Troy bilt lawn mower
check to see if spindle bearings or bad or a bent or split pulley or bent or twisted deck or for broken lawn mower frame uallaslly around a weld frame twist deck belt comes off
Jul 10, 2013 | Garden
Are the nuts holding on the blades reverse threaded?
If a blade, when viewed from above, rotates clockwise, it will have right-handed threads. This is because the shaft is turning to the right, and the resistance imparted on the blade will tend to tighten a right-handed fastener. If a blade rotates counter-clockwise it will have a left-handed fastener. I don't know this mower, but this is a universal thing.
Apr 23, 2010 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
I need help fitting the blade belt to my MTD RH125/92 can you help i cant find the manual anywhere
This can be a tricky job. There is two 180 degree twists when fitting the belt. Viewing the deck from behiend, looking toward the front, run the belt coming from the engine around the left blade pully. Twist the belt 180 and run it at an angle to the front of the right blade pully, this is to drive the blades in opposite directions. Coming off the back of the right pully go around the tensioner pully and between the tensioner and the engine pully make another 180 degree twist. I have fitted a few of these and i have a diagram here in front of me but i cant find a way to show it to you. Hope this helps. Stephen.
Sep 14, 2009 | Mtd Garden
I cant get the nuts off the blades on my cub cadet do you turn them l or r
Not sure on your particular mower but most all mowers are left hand threads so you would loosen like you are tightening normally. I hope that is clear to you. lol
Sep 11, 2009 | Classic Accessories Garden
How do you replace the belt
this is not easy you have to turn the mower on its side <make sure the carb is down > take off the blade belt guide and look at it the space is really tight and you have to hold the trans with two fingers and then walk the belt on. its hard because the trans is spring loaded to twist backwards to keep the belt tight
Aug 13, 2009 | Toro Garden
Husqvarna gth main belt keeps breaking
Make sure the mower rake angle is not too much,On level floor point one of the blades in a front rear orientation,measure height of blade from floor the front measurement should be no more than 1/4" lower than the rear measurement.If the front of the mower is too low the angle the belt has to run is too much and the belt will twist and wear rap[idly.To raise the front of the deck there are either one or two adjustment rods that attach the front of mower deck to frame tighten this adjustment up to raise the front of mower deck.
Jul 17, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
HOW TO TIGHTEN MOWER BLADE NUT
check out www.toolpartsdirect.com for parts diagram for proper installation. the 2 last step is the square metal washer then the nut. to install the metal washer the match the shaft guide. if still can't tighten the nut then the problem is the armature ring may drop down.
Jul 04, 2008 | Black & Decker 19" Electric Lawnhog...
Blade assembly does not tighten
check out toolpartsdirect.com for parts diagram.
Jun 18, 2008 | Black & Decker 19" Electric Lawnhog...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
56 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
