Question about HP Compaq Presario V2000 Notebook
When i turn the laptop on it won't go pass the f1 to resume f10 to restart
  • 383 Answers
Computer BIOS information and help If the computer does not pass the POST, you will receive a combination of beeps indicating ... CH000301, Prompt to press F1/F2 each time computer boots.
Linux and UNIX cut command help Lines with no field delimiters will be passed through intact .
Good Luck please dont for get to Vote/Thank You.
Posted on Dec 20, 2007
When i turn on computer resuming windows appears then it goes to setup is starting services repeatly and will not do anything else please help
restart the computer, hold the key f8 and go in the safe mode with network, pass the scanner disk, antivirus+antimalware. use the defragmentation disk too. try again. If this fail restart again and press the key f11 or f10 depending of your computer model, and go to recovery system, and use the system what do you want, recovery to the setup factory, or normal
God bless you
Apr 05, 2013 | Acer Aspire Computers & Internet
I have a compaq m2105us and when i start it all i get is two beeps and a resume f1 and start f2
try to press f1 and resume set-up ..and make the changes for teh date and time ..and save all settings with F10 and restart should work ..and load windows if it has one ..The fact that it let you go in bios is good means it is not damaged but if it asks all he time f 1 to resume means the hard disk may have bads on it in system check ..and this is causing the f1 call ... basically the systems tells you that you have a bad hard disk and invites you to change it ..or to press f 1 to go with it anyway ..
so..either is calling you to go to bios and set it ..cause you somehow reset the bios to the factory ..or it is a hard disk notice ..
I f it seam not to find any hard disk in teh system ..try to go to bios by pressing F2 or F10 cause it is a hp after all ..and in there change the settings for the ahci function and let it run ide compatible may be the cause too for not booting up from hard disk ..
In the end I suggest to change bios battery ..cause a flat battery wioll also cause F1 on each boot to confirm the settings and set the date and time ..or just reinstall it cause it may have something on hard disk and caused the lost of data ..
let me know more about this if you can not manage or non of my scenarios does fit to the problem ..
Dec 23, 2011 | HP Presario m2105us Notebook
I turn on my compaq and the first thing come on screen is CPU=AMD-K6(tm)/300 00000640K SYSTEM RAM PASSED 00064512K EXTENDED RAM PASSED 0512K CACHE SRAM MOUSE INITIALIZED FIXED DISK 0:FUJITSU...
above 06 lines are related with system information, Go to the BIOS check the startup sequence, if everything is ok save and exit from BIOS.
Apr 01, 2010 | Computers & Internet
its showing operating system not found, because the system cannot detect your hard disk.
Open your system, remove and fix back the hard disk, then try again.
Take care.
Mar 03, 2010 | Computers & Internet
My laptop shuts down and attempt to restart but unable to do so.
your bios battery is low but also you need to do a clean xp installation.
Mar 09, 2009 | Computers & Internet
How can I turn wireless on, on my philips laptop??
press and hold the FN key on your laptop and then press the F1, F2, or F10 key on the keyboard, any one would fix the issue
or TRY FN + F2 ( mostly would fix)
TRY FN + F10,,
key combinations may vary from laptop to laptop
Feb 04, 2009 | Philips Audio Players & Recorders
Not starting up Compaq V2000
may be
but you try this methods
remove the cpu cover and remove the cmos battery then ,remove the hdd cable and replug ,make sure all input devices like keyboard,cd rom drive conneced properly,then run the pc,F1 appears -click F1,after os load ,turn off the computer and insert the cmos battery ,again F1 is appears u press F10 and again press F10 or save buttens ,
it is a possible solution not sure,but try it
Feb 28, 2008 | Computers & Internet
After turning it on it reads "press f1 to resume ;f10 to set up"
Hi I'm sorry, what is the message it shows? If it says "press F1 to continue" then do so, hit F8 and try "safe mode"
Really need to know what the message is.
Good luck
Dec 20, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
149 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
