Question about Apple iPod MA446LL/A MP3 Player
My avi file is out of sync between the audio and the video is there a way to correct this? or is there a player that fixes the problem?
    President:
  • 803 Answers
Not to my knowledge that there is a way to really fix this. One thing you can try is pulling the video file into a video editing program and mess with the video and audio tracks and try and get everything to sync. but there is no proram that I have found that will do it for you.
Posted on Oct 01, 2009
RE: GPX Touchscreen Media Player MT851B My .avi movie files are showing "file format error " before convertion. After i convert the .avi movie files, only the first 15-20 minutes of the movie...
you will need an advanced movie editor or converter that can convert the video from the supported types(even if it is already an .avi file) to: 320x240 resolution, using the xvid mpeg4 codec for video and mpeg layer3 mp3 audio codec. the quality can only be as high as 64 kbps i believe.
the player itself comes with a converter either built-in or on a cd. this converter sucks though and wont sync up the audio to the video very well at all. so i suggest you use a high quality converter so the videos will be watchable.
Jul 20, 2011 | GPX Audio Players & Recorders
Tip
Standalone DVD player with DivX why does the VBR encoded Audio lag the Video
DivX or XVid encoded MP4 Video codec or AVI will almost always have either the Dolby Digital AC3 Codec or the MP3 encoded audio codec see the following links; Fraunhofer MP3 Decoder or LAME MP3 Encoder
This fixed audio lag can sometimes be caused by VBR audio encoded files and starts part way through the playback as opposed to CBR audio some standalone DVD players will exhibit sound lag in this case. It is a good idea to re-encode the VBR to CBR audio this usually solves the problem.
I suggest that you convert/encode all your DivX AVI files into CBR audio to avoid any such errors; all commercial DVD Video Audio is encoded in CBR (constant bitrate) which also reduces the audio filesize unless its encoded in LCPM which will give a much larger audio component.
Check the audio bitrate type open the AVI in GSpot the example below shows an AC3 audio already in CBR so can be left alone and should work fine.
MANUAL CONVERSION PROCESS
This audio MP3 conversion process it a bit of a long way around I know, but it does work!
  • Open video in VirtualDubMod or VirtualDubMP3 (if there is an index error this can sometimes fix it for you.
  • Ignore the error warning that the video contains VBR audio.
  • Extract audio as MP3 ("demux" in VirutaldubMod or save as WAV, then rename to MP3 in VirtualdubMP3).
  • Convert audio to WAV with CDex
  • Open original video in VirtualDub,choose "direct stream copy" for video and "WAV audio" with "Full audio processing" with CBR MP3 compression (and interleaving with appropriate delay if out of sync) for audio.
SEMI-AUTOMATED CONVERSION PROCESS
You could also use several other easier methods including AVIDemux which uses VirtualDubMod or scan in the DVD-Video using TMPEnc v4.0 Xpress and applying a time lead OR lag however this does not solve a progressive lag *** but can be used to re-author a fixed audio lag error in milliseconds you can use either Windows Media Player Classic or KVM Player in real-time to find this lag or lead error and then adjust accordingly
If you can't work AVIDemux then AVIrecomp will be your best solution this is a bit more user friendly
NOTE> always keep a Backup copy of the AVI before you make any drastic changes as you could make the file unplayable the above process will only work on FIXED AUDIO LAG AVI files.
Progressive Audio Lag (starts in synch and runs fast or slow throughout the AVI is almost impossible to remove with re-encoding the AVI using the above methods.
*** Feel free to comment if you know of a foolproof way other than performing a full re-encode from the MPG2 or DVD VOB file.
on Feb 08, 2010 | Philips DivX DVD Player
My Coby mp601 8gb won't play the converted mtv videos, says "format not recognized", what's up with that???
Check the specification of your MP3 player to determine thetype of video file format it uses. Most common video files that MP3 players use are, AVI andWMV, there may be others such as FLV, MOV and DivX. If your player cannot play a video then it is anincompatible video file format, then you need to convert that video file to aformat that your MP3 player uses. Click on this link for instructions on converting videofiles for MP3 players :- http://www.fixya.com/support/r5874192-play_videos_mp3_player
Mar 21, 2011 | Coby MP601 MP3 Player
I convert a video from youtube to my mp3 and i could play the video on my windows media player but when i sync the video to my mp3 player it either wont work or it will just become an audio
That means your computer can play lots of media files because it supported multimedia files example audio or video. Unlike your mp3 player has only limited file format supported. So much better if you try to convert into different media or video format example 3gp,mp4 or avi.Try to download and install this software it might solve your problem Total Converter or Real Player Sp converter.
Please Rate Me
Nov 18, 2010 | SanDisk Sansa Fuze MP3 Player
I converted an MP4 file to AVI and when i play the movie on quicktime the audio is out of sync and the movie plays like its on fast forward. i am trying to upload it on youtube and when i put it on youtube...
Hello.
Give this a try:
Download the latest version of AVI audio sync tool: YAAI_2.0.3.488.zip
from http://findfiles.com/list.php?string=YAAI_2.0.3.488.zip&db=Mirrors&match=All&search=
First of all, make a backup copy of your avi file (this is very important!).
Step 1. Unzip YAAI_2.0.3.488.zip file. Launch YAAI.exe , "Open AVI" dialog will appear.
Step 2. Find and open your AVI file.
Step 3. Click on "Sync Audio" tab. Small video player will pop up.
Step 4. Now, adjust audio delay or frame rate (FPS) using sliders or appropriate buttons.
Click Apply. Video player will start playing your file with changed settings automatically. You can adjust and apply these parameters several times to pick up necessary values for audio delay or FPS. So, try to experiment and to set appropriate audio delay or to change FPS (frames per second) settings for your avi file.
Step 5. Finally, close YAAI tool. When it asks the question: "Do you want to keep the changes?", click Yes.
Hope this helps.
Feb 02, 2010 | Computers & Internet
SAME old! JVC files mod, have converted with prism to avi in the past, with success. Now DVD player says (once) cannot read (next time) not compatible. using DVD-R
Are you talking about a stand alone dvd players?
If you are talking about a stand alone dvd player, that is correct they do not player .avi extension file. I know some portable dvd player can play avi extension files.
all avi extension files needs the right audio and video codec to be player. All stand alone dvd players does not and can not detect codec for you.
On the issues of dvd-r brands, Some stand alone dvd players can only play dvd+r type dvds. ck your brand of dvd disc and players, make sure they are complatible with each other.
Nov 04, 2009 | JVC Everio GZ-MG77 Camcorder
No audio on AVI files
Hi :
I would download virtualdub (free), install a divx convertor (free to some level), and input your original file in virtualdub (file-open file), check the video tab from VDUB, click compression, select divx, and save the file as an .avi file on harddisk of yr computer. If finished, check this avi file with a media player (winamp or so), see if it plays correctly, then transfer the file to your Archos. This will work.
I believe, when you converted, a stray codec was used for audio)
Gerard
Nov 17, 2008 | Archos 605 WiFi Digital Media Player
Avi file
Please down load and install the latest version of media player for your version of windows. or you can download and install winamp with its video plugin which will play .AVI file easily. Also make sure that you have installed correct display driver for your hardware. Normally no video codec is required to play original .AVI file. I think you may have a DV video fire (.AVI) file. This will play if install the DV video codec. Media player classic will play most of the formats.
Oct 01, 2007 | Ahead Software Nero 6.0 (60045) for PC
Zen Vision:M videos out of sync..EVERYTIME!
ZVM cannot handle the AC3 audio so the AVI files need to have mp3 audio. I have a lot of videos that I have converted over the years that I want to play on the ZVM. In order to check compatibility I have been using gspot. I just open the program, drag and drop the file, and get all the details I need in about 5 seconds.
Sep 18, 2007 | Creative Labs ZEN Vision:M Digital Media...
Problems with video types?
audio sync require resync with Windows Media Player, at least
Mar 19, 2007 | SanDisk Sansa e250 MP3 Player
Apple iPod MA446LL/A MP3 Player Logo
93 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
