Question about Homelite Consumer Products MightyLite Handheld Gas Blower with Quicker, Easier Starting
Mighty Lite Blower won't start
So I have had it a year and used it 2 or 3 times. 3rd time it was very difficult to start. The next 2 or 3 times it would not start at all. Plug was getting fire, but the cylinder did not seem to be getting gas.
Read someone else's post about how the new carb jets might clog if using 32:1 mixture like my other equipment. Anyway, dumped the gas; made a 50:1 mixture; primed 7 times ( as instructed ) and it started on the 2nd pull. Wow, I bet I spent 3 hours the last 2 Saturday's pulling that stupid starter rope and it wouldn't start.
Anyway, hope this helps someone else.
  • 1,041 Answers
Check the fuel lines for cracks/breaks. If they are o.k., then:
You willneed to disassemble the carburetor and spray with carb.cleaner.Makesure the small screen is free of debris. (Should be able to see daylightthrough it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Nov 27, 2009
  • Jim Parker
    Jim Parker Nov 30, 2009
    Did this solve the problem?
    Jim
Homelite mighty lite 26bv gas Blower won't run full speed or only in Full Choke
Sounds like a lean condition. Rebuild carb, replace fuel lines and fuel filter and you should be ready to blow the leaves.
Nov 10, 2012 | Homelite Mighty Lite Blowervac
Homelite weedeater mod. 26cs
Try going to ebay and finding a carb for the model, some are as cheap as $12.
Mar 12, 2017 | Homelite Mighty Lite Lawn Trimmer
How much oil do you use? in the mighty lite
Homelite Mighty Lite engines require the gas/oil ratio to be mixed at 50:1. That is 2.6 ounces of oil per gallon or 1.3 ounces of 2 stroke oil per half gallon of gas. I recommend using synthetic oil. It lubricates much better, allows the engine to run cooler and smokes less.
Apr 05, 2011 | Homelite Mighty Lite Blowervac
After ten months without use, I start up the Homelite Mighty Lite 26cc gas model blower/vacuum. It runs on half-choke for about 30 seconds and dies or sometimes a few seconds on run and dies. The vacuum...
Well after you clean it out and get it running make sure you dump some sta-bil into the gas tank next time it is going to sit idle for over 3 months. the gas turns into a shellac which glues up the carburetor.
Oct 30, 2010 | Garden
Homelite mighty lite wont stay running
the problem is in the carburetor most likely, it may be cleaned and adjusted, if not it will likely need a new carb
May 31, 2010 | Homelite Mighty Lite Lawn Trimmer
91 mighty max wont start when cold
Next time when cold and it will not start remove a spark plug or two and see if the engines flooded. If so there are two things that come to mind; 1, worn injectors, leaking as engine sits with time causing difficult starts 2: bad oxygen sensor, if failed engines tend to run rich and the ECU may have your injectors pump heavy amounts of fuel to keep from running lean; often times you'll see poor fuel MPG if O2 sensor failed.
I hope this may have assisted you,
Tom
Oct 30, 2009 | 1991 Mitsubishi Mighty Max
Carburetor adjustment for Homelite 2 cycle engine The product doesn't start easy, and it does come to full throttle. If I run it on partial choke it runs fairly good, but it has been getting worse. Last...
I have the same problem with my MightyLite 26cc Blower/Vac. If it does start it runs rough on full choke and stalls on 1/2 choke or run. I've tried everything, fresh fuel, Seafoam, etc. Nothing works. First time I used it the exhaust burned a hole in my brand new Carhartt hooded sweatshirt. Best solution, throw it away, never buy another Homelite product and tell anyone who will listen what a piece of junk Homelite products are.
Sep 20, 2009 | Homelite Mighty Lite Lawn Trimmer
I have a Homelite 26vt Mighty Lite that will only start when I dump gas straight in the carburetor after it uses that gas it will not start
you have 1 of 3 things wrong
1 you have pluged jets
2 you have a pluged fuel filter
3 you have a stuck float
4 fuel line is crimped
1 2 3 4 thats all it can be
preasurise the fuel tank by blowing into it when almost empty
this will as times clear jets
if fuel line kinked un twist it
best bet buy a rebuild kit for the carb and enjoy some time with a screw driver
Jul 27, 2009 | Homelite Mighty Lite Lawn Trimmer
Correct gas to oil ratio for Homelite Mighty String Trimmer Model
most trimmers are 50:1. or 40:1. i would use synthetic 2 cycle oil and use the 50:1 ratio. i know guys with trimmers that require 50:1, and they use synthetic at 80:1 with no problems for years. they say the engine runs cleaner. i am a part-time lawn care operator.
Jun 18, 2009 | Homelite Mighty Lite Lawn Trimmer
Mightylite 26cc Edger
You need to disassemble the carburetor and spray with carb. cleaner. Use a Den Tek Brush,
(http://www.dentek.com/shop.php?target=products&product_id=7), to clean the small portals in the carb. Make sure to clean the small screen in the carb. as well. Reassemble and start.
If you need further assistance, just let me know.
Jim
Jun 07, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Consumer Products MightyLite Handheld Gas Blower with Quicker, Easier Starting Logo
351 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
