Question about Estate TGDS740JQ Gas Dryer
Burner will light, then go back out.
Burner will light, run approximately twenty seconds, then drop out. it will call for heat again, light. and run about ten seconds on second or following attempts. I have changed the coils on the control valve.
  • 1 more comment
  • brian_j_thom Oct 01, 2009
    the dryer does not have a thermocouple to the best of my knowledge, it has a hot surface ignitor. if that helps.
    I have already changed the coils on the control valve. it did not help
  • Kevin O'Brien
    Kevin O'Brien May 11, 2010
    Does this unit have a thermocouple? If so, it sounds like it's bad.
    President:
  • 744 Answers
With the limited information you gave I will assume this is a gas dryer that the flame starts for a minute or so and then shuts off. This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils burner will light, then go back out. - 57d5263.jpgThis The coils are mounted to the gas safety valve, This should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Posted on Sep 30, 2009
  • Mike Price
    Mike Price Oct 01, 2009
    Then your problem will be the light sensor mounted at the side of the burn tube.
Carrier apu blows cold air for twenty seconds and fan quits engine keeps running and fan starts again but only blows cold air for another twenty seconds
Have you tried rebooting the system? Just turn off the breaker for a few minutes.If you need more questions for your Air Conditioning Repair needs, check us out online.
Jul 07, 2017 | Carrier Heating & Cooling
The child lock engaged when a circuit breaker triped. I tried pushing the Rinse Only pad as per the manual. But, the dishwasher remains locked (light on) and won't run.
Hi Gayle, thank you for allowing me to assist you!
When the Child Lock light is on, the control is locked and no cycles can be selected or started. To de-select the Control Lock, press and hold the heat dry key or press down on the lock icon for approximately twenty seconds. If issue persists, try resetting the dishwasher by either unplugging it or flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn the unit on. Select a cycle and your dishwasher should resume normal operations. I ask that you please follow up with a comment on the post, at your convenience to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Sep 27, 2013 | Frigidaire 24 in. PLD2850 Built-in...
Electrolux dishwasher in locked mode
Good Afternoon David - When the light is on, the control is locked and no cycles can be selected or started. To de-select the Control Lock, press and hold the heat dry key or press down on the lock icon for approximately twenty seconds. If issue persists, you may reset the dishwasher by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. The dishwasher should resume to normal operations.
Jun 24, 2013 | Electrolux Dishwashers
Carrier gas furnace does not cycle right.
Check out the flame sensor see if it is clean and check the connections .
May 21, 2017 | Carrier Heating & Cooling
I have a builder installed Goodman GDS80904BHA that is approximately 5 years old. Recently, when the furnace completes a heat cycle, approximately 1-2 minutes after the cycle has completed and after the...
I would guess that the fan off setting on your limit is set a little to high. If you have the manual you can see what it says about changing the running time for the fan after the burner has shut off look on the control board and you should see two switches,one to set the time for burners to fire before main blower starts and one to set time for fan to run after burners shut off. To help with the problem you are describing set fan run time up so fan wii run longer. Hope this helps. Thaks.
Nov 22, 2010 | Goodman GDS80904BNA Open Flame Heater
AO Smith Burner Issues
This system uses an electrical test to make sure that the burner is lit. The flame sensor will either be broken or will be covered in deposits (clean with an emery cloth).
The flame sensor is usually a small metal rod that would be in the direct line of fire of the burner with 1 wire attached.
CAUTION:
The ignitors can be very fragile and are expensive. They are very brittle, do not touch it.
Jun 07, 2010 | Water Heaters
Burner lights 5-10 seconds shuts down. Good air flow. Gas smell at times out vent.
The burner will shut off for various reasons.
First, there is a sensor right at the burner flame. If the sensor does not indicate flame the gas is shut off to avoid filling your house with gas. It is usually a short metal rod. Oftentimes cleaning it will get it working again. Or the signal from the sensor isn't getting back to the controller, so check for loose connections.
This page explains it well.
http://www.acmehowto.com/howto/appliance/dryer/gdryer/check/flamesensor.php
There are some other sensors that will shut the heat down. A temp sensor where the hot air leaves the dryer drum. This is to keep from overheating the clothes and lighting them on fire. If this sensor is bad, or the wiring to it is not getting that signal back to the controller, the dryer will shut the burner down. Although 10-15 seconds is pretty short, this is a possibility. Try different heat settings to see if you get the same result. If it only happens on one heat setting you most likely have a bad temp sensor.
Visit here for more info.
http://www.acmehowto.com/howto/appliance/dryer/gdryer/check/thermostat.php
Another possibility is that the gas valve (solenoid) is getting near the end of its life and can't stay open long. This is not likely, but still possible since the burner does light.
http://www.acmehowto.com/howto/appliance/dryer/gdryer/check/gascoil.php
Next possibility is that the gas line is partially plugged. When the burner fires the gas pressure drops rapidly. When the burner goes out the gas sneaking past the obstruction raises the pressure back up.
Final possibility is a bad controller.
Jan 19, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My rayburn will fire up and run for thirty seconds and cut out and eventually will go after about twenty times
clean the magic eye or photo electric cell as it is not seeing the flame so shuts off the power to the burner. just pull it out and wipe the end and put it back in again
Jan 17, 2010 | Kitchen Ranges
I have had the gas off for two years. I got the pilot light to work but when I turn the thermostat up to get some heat it got the heater going about three times in over twenty-five tries over a couple
you need to clean the burner assembly. Over time dust and settled inside the unit and it is possibly restricting the flow of gas through the burners. This is a dangerous situation. get it cleaned before you try again.
Apr 29, 2009 | Heating & Cooling
Possible heat related problem to television.
If you had the back off ,while in there jump any switchs that are related to cover being off,turn on set kisten for fan bearings .check air path ,especially in light unit.wayne
Oct 19, 2006 | RCA D44LPW134 44" HDTV
Estate TGDS740JQ Gas Dryer Logo
150 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
