Question about JVC RX-618V Receiver
How to get an EQ to work on a JVC RX-618V
I have a JVC RX-618V that is working but I can't get the EQ to come through the receiver. Turning it on and off has no effect. I've hooked it up properly. On most receivers you can turn it on through the receiver (I. E. VCR2/ EQ) or some other method. Short of hooking up devices directly through the EQ itself; is there some way to make the equalized sound go through the receiver? There has to be a way to do this.
Thanks
SOURCE: JVC RX-884VBK RECEIVER
The JVC RX-884VBK is a great machine, I had it for over 5 years and had no problem at all. I came across the (NO SOUND at all) and I believe it is an easy fix. Check the Front left, there are 2 keys marked 1 and 2 for SPEAKERS output, sometimes you don't notice that you connected the speakers to 1 and the 2 key is pressed. You could have both keys pressed and you will get the sound. I hope that helps.
Posted on Jan 14, 2008
tech48
  • 624 Answers
SOURCE: I have a JVC rx-6032v
yes, you must use the setup menu and assign the optical input to the input you are using. Some receivers have a "input mode" switch. If this one does, you only ned to press it until it says "optical". If you have a owners manual, it will decribe all the settings that need to be made to accomplish what you need.
If you do not have one, I have uploaded one to my website for you do have. It will only be there for a limited time before I remove it, so get it quickly. You need Adobe Reader to read this, so if you don't already have iton your computer you can download it free here:
http://www.adobe.com
Here is the link to the owners manual:
http://www.get1here.net/rx-6032v-ownersmanual.pdf
I would appreciate a "FixYa!" rating for this free information and manual. Let me know if I can be of any further help.
Dave
Posted on Jul 12, 2008
SOURCE: jvc rx-5032v audio/vido control receiver
HI MATE YOU NEED THE REMOTE
Posted on Aug 19, 2008
SOURCE: I have a jvc RX-550V
The display is back-illuminated by small incandescent bulbs. Burnt out bulbs equal no display, although the chances of several bulbs failing at once is not high so the power supply for the display/bulb assembly is a good place from which to start fault finding.
It needs a repair shop - as a user there's nothing you can simply dig into to fix.
Posted on Aug 24, 2008
SOURCE: jvc receiver OVERLOAD
possible short across speaker wires somewhere or even inside speaker
Posted on Jan 23, 2009
Yamaha eq 32
The RX-150 does not have preamp out and power amp in connections. However, if you wish you can take the line level signal from tape OUT (assume it has one) and feed that into your Yamaha EQ. The OUT from the Yamaha can then be fed into an independent stereo power amplifier and then to your speakers. You would then be using your RX-150 only as a pre-amp. Alternatively, (professionals only) and I have done this several times, you can identify the output of the preamp stage inside the amp and bring this to a pair of RCA connectors cut into the back panel. Similarly, find the inputs to the power amps and do the same. For normal operation, bridge these. Otherwise, use these connection points to insert your EQ. This process, of course, requires that you are proficient at working with high voltage electronic devices. If you are not, take it to a professional who should be able to do this for very little cost. JVC, of course, would not consider this to be an acceptable modification. As always, take extreme care and never attempt anything you are not qualified to do, especially when it comes to electricity.
Cheers, Don.
May 22, 2014 | Audio Players & Recorders
Yamaha rx v757 av receiver
tape out to line in on eq, line out from eq to tape in on receiver, use tape monitor switch to make eq work
Mar 14, 2014 | Audio Players & Recorders
Can a ten band equalizer be used on a JVC rx-8030v 6.1?
Yes.
Use the Tape/MD or the one next to it (lower)
Aug 12, 2012 | JVC RX-8030V Receiver
After market receiver periodically resets itself (JVC KD-DV5300)
In KD-DV5300, replace capacitor C751. Capacitors dry with age.
Feb 16, 2012 | JVC Car Audio & Video
My left channel in my JVC RX-305 isn't working...what do I do to fix it? When I either push the volume up or down it makes a clicking sound. It was working just fine last night. My right channel is...
Try swapping the speakers or just check the left connections WITH POWER OFF. Disconnect the left speaker completely and see if the clicking stops.
Sep 05, 2011 | JVC RX-618V Receiver
I have a JVC RX618V stereo receiver which is about 20 years old that suddenly is not outputting a stereo signal. Any idea what the problem could be?
Please clarify. No "stereo" output or no output, period?
What source(s). Try FM.
Is Tape Monitor On? Turn it Off.
Speakers On or Off?
Jun 26, 2010 | JVC RX-618V Receiver
Owners Manual Needed
http://books.jvcservice.com/ enter in model number and download manual
May 22, 2007 | JVC RX-618V Receiver
JVC receiver Auto muting?
I had the same problem. I had bad antennae connection. I re-did the antennae conection and it fixed it. HOpe this will work for you...
Dec 03, 2006 | JVC RX-618V Receiver
JVC RX-618V SOUND IS MUFFLED
check to see if the radio is clear. If it is it may be the signal going into the amplifier. if it is muffled as well, depending if you have an Equalizer hooked to the unit. This also could cause the problem. Finally check the bass, treble balance and volume knob but turn them back and forth while unit is on and see if signal clears up momentarily. if this is the case the control knobs need to be cleaned. Also spin the connection jacks {RCAs} in the rear and see if this clears it up. If not you may have to have the unit serviced by a professional.
Jul 13, 2006 | JVC RX-618V Receiver
59 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
