Question about Panasonic BT-LH1700W Monitor
Has a blue vertical line down right side of the
Video Image is good but has a blue vertical line down right side of the display.
5 Suggested Answers
SOURCE: LCD TV - Vertical Blue line
My Lcd monitor has blue line? How can I solve this problem?
Posted on Jul 23, 2008
  • 23 Answers
SOURCE: Blue vertical line at reght side of screen
This is normal. Depending on what you have connected to it the lines could be white, black and white specs, or green. Just mode will show the entire picture event the parts that aren't supposed to be seen. I would not recommend that setting. Full is the best mode if you want to see the entire picture in the correct ratio.
Posted on Apr 24, 2009
Slinteriors
  • 8617 Answers
SOURCE: panasonic plasma tv th42px8ob 2 inche vertical line showing
do the proper isolation proceedure and try unhooking the Su from the SC board to see if you then get a normal picture all the way across the bottom half of the screen? I am assuming the Vertcal extends extends all the way from top to the bottom of the screen?
Posted on Aug 07, 2012
gopakumarg43
  • 74377 Answers
SOURCE: How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Posted on May 25, 2015
What is causing interpolated image shifting on my Sony KDL-403000 LCD TV? It has wide vertical bands of horizontal lines that are shifted parts of the displayed image, only occurring on the sides.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Mar 10, 2017 | Sony Televison & Video
Why appear blue and black lines on my tv screen?
Feb 11, 2015 | LG Televison & Video
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
Vertical color lines on the display
this is due to fault in the screen take it to the technician
Sep 02, 2009 | Fujitsu Siemens LifeBook N6200 Notebook
LG RU-42PX11 42 plasma TV has black bar
The screen does not work properly .Ribbon wire fails.
Mar 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
LIGHT BLUE VERTICAL LINE ON MONITOR
The vertical line is a bad pixel sensor at the edge of the screen, your screen has hundreds of vertical and horizonal pixel sensors. This is an indicator that the screen is going out and need replacing.
Jul 03, 2008 | Sony VAIO VGN-NR220E/S Notebook PC
Vertical lines in my laptop screen
Yes the problem is with your video system hardware, most likely. A repair may be possible as it could be the delicate ribbon cable that provides the video signal from a connection on the motherboard to the actual display screen. It could be the display screen. If some tech-savy friend with a good rep and an anti-static mat, good tools, and good lighting wants to assist you or check it for you, you may give that a try. Consider first that if you have or can get an extended warranty from the manufacturer then you can have a higher likelihood of a good resolution of the problem of the vertical lines that distract from viewing the display.
Jun 04, 2008 | HP Compaq Presario C500t Notebook
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
Got a blue vertical line on me plasma
I had the same problem, a vertical blue line from top to bottom on my samsung TV.
Try this download this http://www.jscreenfix.com/video.php i burned it to a dvd and it fixed it within a minute.
Nov 07, 2007 | Samsung HPN5039 50 in. Plasma HDTV
Panasonic BT-LH1700W Monitor Logo
53 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
