Question about Polaroid i633 Digital Camera
The lens is stuck in open position
The lens is stuck open on my Polaroid i633 digital camera
4 Suggested Answers
SOURCE: lost USB cord to digital camera
Use a card reader. No battery drain while using the reader hooked to your computer.
You can find them bor between $8 and ????
Good luck.
Posted on Nov 01, 2007
  • 11967 Answers
SOURCE: polaroid i733 digital camera lens stuck open
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 29, 2010
  • 421 Answers
If the lens is stuck out then you will find it is usually one of a few reasons.
1. Check the
batteries. (obvious I know).
2. The
camera has been dropped or knocked.
3. The camera has grit or dirt in the lens mechanism.
Providing the batteries are ok then 2 and 3 usually mean a professional repair. The lenses tend not to be something that the average
home user can remove and take apart. The cost of repair also might be more than the camera value so you will need to find a good repair shop near you and get a quote.
Posted on May 30, 2010
My camera lens doesnt open fully for pic and screen is blurry,I tried to Zoom and it shuts down. should I send to get serviced?
You could get it fixed. If you hear a crunching noise when the lens tries to open the gears are chewed up. If thats the case usually to expencive to repair. You could try to pull the lens out manually with your hand. Sometimes that will free up the lens. Hope this helps.
May 25, 2011 | Polaroid i633 Digital Camera
I bought a sandisk 4 gb sdhc card for my polaroid i633 and it says card error why????
Read your manual my camera is only 3 years and won't support sdhc,i have to use a standard 2g sd card.
Mar 29, 2011 | Polaroid i633 Digital Camera
Polaroid i733 digital camera lens stuck open
1. Check the
2. The
May 15, 2010 | Polaroid i733LP Digital Camera
My lens is stuck!
Sometimes this can happen if the battery cover was accidentally opened while the lens was moving. Try something simple. Turn the camera off. Open the battery cover and remove the batteries for 5 minutes. replace the batteries and secure the cover. Turn on the camera. The lens should go to it's home position. Let me know if this helps. And thanks for coming to FixYa. Don't forget to rate my answer!
Rob
Feb 08, 2009 | Polaroid T831 Digital Camera
My polaroid i633 won't work!
YOur camera is looking for verification that the lens is extending. Once it sees the lens has extended when you power on, the sensors in the lens tell the Operating system that the lens is Ok.
If it does NOT see verification from the lens, it shuts down. Never force your lens back in. You may have to take the camera apart to reset the lens. you do this by removing the Zoom gear drive assembly and free you lens up by hand. 1 grain of sand or grit is like a Monkey Wrench in a Gear cog. Clear the obstruction with a can of compressed air, and work the lens with your hand. once you can that put it all back together and it should work.
Mar 15, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Polaroid i633 camera
http://www.polaroid.com/service/userguides/digital/cameras/i633_ug_en.pdf
Dec 22, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Lens stuck open
In a nutshell, this error happens when the lens gets stuck while trying to extend and comes slightly out of alignment. Particularly if it's been dropped while open. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
If your camera is still under warranty, the best thing you can do have Polaroid should fix it. If your camera is out of warranty, or if Polaroid refuses to repair it for free, the one thing you can try is to If you gently, and I do mean GENTLY push against the lens with the PALM of your hand as you turn it on, it may cause it to depress back into the camera. If that doesn't work, and you can't reset it or turn it on/off several times, then you may have to send it in for a repair estimate anyway.
Dec 04, 2007 | Polaroid i832 Digital Camera
Lost USB cord to digital camera
Good luck.
Oct 24, 2007 | Polaroid i733LP Digital Camera
Polaroid i633 Digital Camera Logo
56 people viewed this question
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
