Question about HP Compaq Presario V2000 Notebook
After turning it on it reads "press f1 to resume ;f10 to set up"
My laptop stays there and does not process or do anything else although i can hear the fan running this is as far as i get. i used it 2 or 3 days ago and it was fine. now upon turning it on i get this message. any suggestions??
    Scholar:
  • 181 Answers
Hi I'm sorry, what is the message it shows? If it says "press F1 to continue" then do so, hit F8 and try "safe mode"
Really need to know what the message is.
Good luck
Posted on Dec 20, 2007
How to reset all settings to my lenovo a269i mobile thru pc
Is it a think pad ?
Power off your Thinkpad.
Press and hold the "F1" key and turn your Thinkpad on, still holding the "F1" key down.
Release the "F1" key when you hear repeating beeps. Wait for the "IBM BIOS Setup Utility" to load.
Select "Startup" using the arrow keys and press "Enter."
Select "Boot" or "Startup Sequence" and press "Enter."
Select "CD-ROM Drive."
Press the "F6" key repeatedly until "CD-ROM Drive" sits at the top of the list.
Insert your recovery CD into your Thinkpad's CD-ROM drive.
If you have multiple recovery CDs, insert the CD that has "Disc 1" on its label.
Press "F10" to save your changes and exit the BIOS Utility.
Select "Yes" and press "Enter" when the "Setup Confirmation" window appears.
Your laptop will restart. Wait for the Recovery Utility to load.
Select "Restore to Factory Specifications" to erase the contents of your hard drive and reinstall the Windows version and drivers that your Thinkpad originally came with.
Follow the Recovery Utility's onscreen instructions.
When prompted to insert another disc, do so according to the numerical labels on your recovery CDs (e.g., insert "Disc 2" after "Disc 1" and "Disc 3" after "Disc 2").
Your Thinkpad restarts when the restore process finishes. Power off your Thinkpad.
Hold down the "F1" key and power on your laptop to access the "IBM BIOS Setup Utility."
Press "F9."
Select "Setup Defaults" from the menu and press "Enter" so that your Thinkpad no longer boots from the CD-ROM drive.
Press "F10" and select "Yes" to confirm your changes.
Your Thinkpad will restart and load your newly installed operating system.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-61432
ThinkVantage Technologies downloads
Feb 20, 2014 | Computers & Internet
I have a compaq m2105us and when i start it all i get is two beeps and a resume f1 and start f2
try to press f1 and resume set-up ..and make the changes for teh date and time ..and save all settings with F10 and restart ..it should work ..and load windows if it has one ..The fact that it let you go in bios is good news..it means it is not damaged but if it asks all he time f 1 to resume ..it means the hard disk may have bads on it in system check ..and this is causing the f1 call ... basically the systems tells you that you have a bad hard disk and invites you to change it ..or to press f 1 to go with it anyway ..
so..either is calling you to go to bios and set it ..cause you somehow reset the bios to the factory ..or it is a hard disk notice ..
I f it seam not to find any hard disk in teh system ..try to go to bios by pressing F2 or F10 cause it is a hp after all ..and in there change the settings for the ahci function and let it run ide compatible ..it may be the cause too for not booting up from hard disk ..
In the end I suggest to change bios battery ..cause a flat battery wioll also cause F1 on each boot to confirm the settings and set the date and time ..or just reinstall it cause it may have something on hard disk and caused the lost of data ..
let me know more about this if you can not manage or non of my scenarios does fit to the problem ..
Dec 23, 2011 | HP Presario m2105us Notebook
My compaq presario laptop keeps getting an error: 0211 keyboard error it says press F1 to resume or F10 to setup but neither one of them does anything when I push them. Can this be fixed?
1. Turn off computer and unplug power cord.
2. Disconnect all external devices(open up the computer tower and then )
3. remove battery
4. press power button and hold for 10-15 seconds
5. plug power cord back into computer and press power button.
6. Check LED’s and listen for power supply fan.
7. If LED’s are on or power supply fan starts spinning, watch for boot screen
8. If coputer begins to turn on, turn it off.
9. Reconnect battery and external devices.
10. Press power button and make sure computer starts.
This should work....all the best
May 19, 2010 | Computers & Internet
ACER ASPIRE 3680 --OPERATING SYSTEM NOT FOUND
its showing operating system not found, because the system cannot detect your hard disk.
Open your system, remove and fix back the hard disk, then try again.
Take care.
Mar 03, 2010 | Computers & Internet
Press f4 to resume
u need to go into bios setup.this can be done by pressing del button on ur keybadr while booting is goin on. some time the key to be pressed will be F10 or F1 instead of del key.
There will be an option as stop booting on error. disabl;e that..n it ll be fine.. btw to find out the error u'l have to specyfy each n every settings in ur bios.So its better u to ask for a person who knows these things to ur home.. Else u can do by exploruing these things urself.It ll be fun..i would prefer this..
Feb 12, 2009 | HP Pavilion dv2000t Notebook
INTEL CPU UCODE LOADING ERROR
press "del" or F2 to enter in bios then detect your hardisk and set date and time then press F10 and save settins.
Jan 05, 2009 | E-Machines eMachines Desktop PC
When i turn the laptop on it won't go pass the f1 to resume f10 to restart
Computer BIOS information and help If the computer does not pass the POST, you will receive a combination of beeps indicating ... CH000301, Prompt to press F1/F2 each time computer boots.
Linux and UNIX cut command help Lines with no field delimiters will be passed through intact .
Good Luck please dont for get to Vote/Thank You.
Dec 20, 2007 | HP Compaq Presario V2000 Notebook
Compaq Presario M200
wat do u read before this??
Nov 15, 2007 | Compaq Presario M2000 Notebook
HP Compaq Presario V2000 Notebook Logo
133 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
