Question about GE Nautilus 24" Built-in Dishwasher
How do I unjam a dishwasher motor? It hasn't been run in a few weeks and apparently locked up.
Dishwasher won't drain, makes a funny clicking/scraping noise when it is supposed to be draining.
Water does not drain from the dishwasher:
  • Check sink drain and drain hose for restrictions
  • Unjam the motor
  • Unjam the pump
  • Check the drain valve
  • Check the drive belt
  • Test the timer motor
  • If you have a brand new dishwasher or garbage disposer, check the knock out plug on the garbage disposer.
Apr 01, 2010 | Dishwashers
Cleaned coil as instructed, water did not drain
  • Check sink drain and drain hose for restrictions.
  • Unjam the motor.
  • Unjam the pump.
  • Check the drain valve.
  • If you have a brand new dishwasher check the knock out plug on the dishwasher.
Jan 22, 2010 | Kenmore Dishwashers
I'm getting an "LE" code also, and the dishwasher will not drain.
LE is a Motor error
Wiring connection is OK? The Impeller of Washing Pump is locked. The rotor of Washing Motor is locked. The Blade is locked.
Check the wiring connection. Replace the cause of restriction. Replace the Washing Motor. Replace the PCB
Sep 07, 2009 | LG LDF6810ST Stainless Steel Built-in...
Dishwasher will not drain
Hi...
If you dishwasher fails to drain you need to check this following:
Thedrain hose and recirculation hoses can be responsible for leaks. Thedrain hose can cause the dishwasher to fail to drain properly. Therecirculation hose can be responsible for problems with poor rinsing ofdishes.
  • Unjam the motor
  • Unjam the pump
The timermotor regulates the length of time power is routed to each component.If the timer motor does not function properly, it can result in a widerange of problems. Common symptoms include sticking in a cycle, cycletimes running too long, or failure of the dishwasher to start at all.
Good luck !!!
Regards
PCmania
Aug 27, 2009 | Maytag Dishwashers
Dishwasher runs though cycles but fails to drain in the final cycle
Hi...
The drain hose and recirculation hoses can be responsible for leaks. The drain hose can cause the dishwasher to fail to drain properly. The recirculation hose can be responsible for problems with poor rinsing of dishes.
  • Unjam the motor
  • Unjam the pump
The timer motor regulates the length of time power is routed to each component. If the timer motor does not function properly, it can result in a wide range of problems. Common symptoms include sticking in a cycle, cycle times running too long, or failure of the dishwasher to start at all.
Good luck !!!
Regards
PCmania
Jul 15, 2009 | Dishwashers
My the dishwasher will not drain. The pipes are not blocked or kinked. If I shake the pipe the dishwasher will drain. But I cant do that all the time. Any suggestions?
Hi..
If your dishwasher will not draining you need to check this
  • Unjam the motor
  • Unjam the pump
Good luck !!!
Regards
PCmania
Jul 13, 2009 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Dishwasher
motor is locked. you can sometimes try opening the bottom panel and manual turn the motor and unjam it. ge models are the easiest to do so.
Jul 07, 2009 | Maytag 24 in. MDB5651A Built-in Dishwasher
Dish washer not draining
Try following:
  1. Check sink drain and drain hose for restrictions
  2. Unjam the motor
  3. Unjam the pump
  4. Check the drain valve
  5. Check the drive belt
  6. Test the timer motor
  7. If you have a brand new dishwasher or garbage disposer, check the knock out plug on the garbage disposer.
pls rate my suggestion...
Jun 24, 2009 | Westinghouse Dishwashers
Hello my dishwasher will not drain after wash.
  • Unjam the motor
  • Unjam the pump
Jan 12, 2009 | Dishwashers
How do I fix a dishwasher that will not drain? Or how do I troubleshoot the problem? Thanks.
  • Unjam the motor
  • Unjam the pump
Oct 01, 2008 | Dishwashers
GE Nautilus 24" Built-in Dishwasher Logo
217 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
