Question about Kodak EasyShare MD853 Digital Camera
Camera lense is stuck out and camera wont turn on
Turned it on tried to zoom, camera turned off and now the lenses is stuck out and i cant turn back on the camera
SOURCE: optical lense stuck in the "out" position
My camera had this problem too. Try replacing the batteries. That worked for me.
Posted on Dec 31, 2007
  • 3 Answers
SOURCE: zoom lense on a kodak
try recharging the batterry.
Posted on Dec 07, 2008
SOURCE: Kodak Easyshare camera turns on and off
Yes you are. My wife denied that she dropped in the sand but I found a list of photos that she wanted to print on a post-it paper in the cover and it had sand all over the sticky part. Used the pressure air spray to clean the rings and it is back to life. Well It worked but there was some problem during zoom in&out, so I spray the rings while zooming and out and that cleaned it. I hope I don't have to open it to clean the mechanism. Thank you.
Posted on Jun 08, 2009
  • 1382 Answers
SOURCE: Kodak m1033 lenses stuck 'open'.
Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to auto focus while the lens is extending, hopefully seating the lens barrel guide pins in their slots. Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Thank you!
Posted on Jul 14, 2010
  • 420 Answers
SOURCE: lense error
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Posted on Sep 15, 2010
Finepix j27 When the camera is turned on "Zoom error" message appears and lense is stuck in an extended position. When the power is turned off, the lense remains extended. Do you know how...
hi, Zoom Error occurs when there the lenses are not able to move and something is obstructing the movement like some dust or sand grains etc., to dislodge the obstructing particles try tapping the lense side corner of the camera on a table top lightly (not too hard please, as the lense and autofocus combination is quite fragile) a couple of times in switch off mode and trying to power on after every 2-3 taps.
or you might send it out to a service centre, the charges are generally just the serviceing charges as no new parts needed.
hope this helps
cheers
May 05, 2011 | Cameras
Canon powershot zoom lense is stuck how can i get it to
There are a few things you can try. Here is an excellent blog about lens errors and stuck lenses, and it covers what can be tried to free it up:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
They say about 50% of lens problems can be fixed trying their suggestions. Hope you're one of the lucky ones! Also, if nothing works, get an estimate before having it repaired. Often, it's just better to get another camera.
Jul 09, 2010 | Canon PowerShot A540 Digital Camera
My camera lense is stuck and my camera wont turn on
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u
rate me!!!
Jul 28, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
Fuji finepix a600
If the camera was on when it was dropped you probably jamed the lense coil. The lense coil is what helps the camera smoothly pull in the lense and back out. Now, just to specify, what exactly are you having a problem with? Will the actual lense not go back into the camera when you turn it off; or can you not get your camera off zoom?
Let me know~
Olivia
Oct 30, 2008 | Fuji FinePix A600 Digital Camera
Zoom Error
this usually happens when you turn on the camera with the lense cover still on. just turn it off and remove the lense cover and turn it back on again. hope this helps.
Mar 16, 2008 | Fuji FinePix S5100 Digital Camera
Zoom Feature
I have a problem as well, I installed the zoom lenses and it wont turn into zoom, I know something might be wrong but I cant figure wich, I have tried a couple of times to unscrew it and screw it.
Feb 24, 2008 | Vivitar V3800N Zoom 35mm SLR Camera
Zoom won't work
wow alot of people have gotten this problem with the lense in this camera.
Well to cure this problem , firstly turn on the camera, ensure the lense is out ,Then GENTLY tapp on the lense in the direction that the lense feels uneven or unequal length to the outer ring (place that looks uneven).This should hopefully get the gears aligned once more.
Nov 22, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
HP R707 Digi Cam...zoom lense not working
I had the same problem - try to wiggle the zoom lense really carefully and the switch it on again. The zoom objective is canted a little bit and the motor is too weak to move the zoom objective. You can also open the camera by removing all 8 screws around the camera and then removing the metal front (Just pull it in the direction of the zoom lens with your fingernails). Then you can access the zoom lens better ... Andy
Sep 05, 2007 | HP Photosmart R707 Digital Camera
Kodak EasyShare MD853 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
