Question about Kitchen Appliances - Others
The halogen spotlight isnt working. i was told it might be the transformer. how can i change the transformer, i cant open the 230v unit to get the wires out. does that make any sense?
    President:
  • 1,714 Answers
Have you changed the bulb yet? The 'ballast' may be the problem, but they don't usually fail that often.
Posted on Oct 03, 2009
I NEED A POWER CORD CHARGER FOR THE 3,000,000 CANDLE POWER HALOGEN SPOTLIGHT. WHERE CAN I FIND ONE
If this is the usual sort of halogen spotlight, it is usually supplied with a mains charger adaptor and a lead to charge it from the car cigar lighter socket.
Both those items are also commonly supplied with a range of car-related rechargeable items, torches, jumpstarters and so forth.
I have several such items and I find the 12 volt lead and mains charging adaptor completely interchangeable between all of them. Rechargeable halogen spotlights generally have a very disappointing battery life of around 20 minutes unless a very expensive professional model is bought.
If it is not a rechargeable type that must be permanently connected to the car cigar lighter, the power cord is usually permanently fixed to the lamp but if it isn't, the cable will need to be substantial enough to carry several amps - something similar to that of perhaps a large coolbox.
Apr 11, 2017 | Camping, Backpacking & Hiking
12v Spotlights flicker
Conversion from halogen to LED lighting is not a simple plug-and-play process. The power supply is delivering more than 12v because the LEDs draw less current. The flicker could be evidence that the LEDs are gradually breaking down.
Dec 09, 2016 | Kitchen Ranges
VEC157BDC Spotlight
remove the black rubber guard from the front there is a screw on each side remove them then remove the lens guard then you can get to the bulb. I hope this helps. You will need a phillips screw driver and a flat head one small ones
Jun 14, 2014 | Black and Decker USA Black & Decker...
I have a Black and Decker Lithium Halogen Spotlight and need to know how it comes apart to replace the bulb. thank You
Pry off the rubber bezel with a flat head screwdriver, remove the Phillips head screw holding the reflector in place. to remove bulb you must loosen the phillips head screw and nut holding bulb in place , do not touch the bulb with bare hands use a paper towel or cloth, the oils in your skin will cause premature failure of bulb.
Sep 11, 2013 | Black and Decker USA Black & Decker...
How can I open this spotlight to replace the halogen inside ?
The small ring around the bulb should turn. Push up on it gently then turn it. when its loose the bulb and ring should both come down together.
Mar 04, 2013 | Garden
LOOKING FOR A UNIVERSAL MICROWAVE TRANSFORMER 230V 1400W
It is hard to find a universal with such a high output , I was able to get the part number for the transformer that goes into the unit you listed.
WB27X10893
should find it online ok , here's where I found it
http://www.partstore.com/GetModel.aspx?MfgName=General+Electric&BrandName=General+Electric&ModelNumber=JVM1640SJ&Page=1&SortBy=price&SortDirection=desc#PartsearchSKUList
Hope this helps.
Phil
Apr 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
US portastudio 2488: Can it play when connected with a transformer
The 2488mkII manual specifies that the unit can operate with either 120VAC, 60Hz (USA/Canada), 230VAC, 50Hz (U.K./Europe), 240VAC, 50Hz (Australia) so you should be fine with a transformer which can accomodate 230VAC, 50Hz).
I have actually conversed with people who have been using the 2488 in France without any power problems.
Cheers,
bd.
Sep 12, 2008 | Tascam 2488 Portastudio Multitrack...
18v. charger (dewalt)
I did a little hunting and it seems you really want to use your 110v charger on a 230v supply.....
So you could use a transformer (LINK)
or you could get a local power supply pack.
Read the label on back of power pack that attach's to wall socket and charger base, see what input it can handle, some gear can handle like 110v-230v, others cant ie will read 120v
Any adaptor that puts out the same output as the original would work ie 18v DC 2.5 amps is your specs i beleive so use a transformer or another suitable adaptor
Please check my quoted specs are the same as listed on power pack of your charge ie I am assuming you are using your 110v A.C. to 18v 2.5amp D.C power pack
Jan 30, 2008 | Dewalt 7.2-18.0 Volt One Hour Charger
Kitchen Appliances - Others Logo
116 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
