Question about Kenmore Refrigerators
My Kenmore Elite freezes vegetables in the vegetable bin on one side. The interior temperature is set at 46. How can I keep food from freezing? The vents are kept open as well.....any suggestions?
    President:
  • 744 Answers
Hi, this problem is going to be with the running thermostat (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Posted on Sep 30, 2009
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
Fridge keeps freezing food
I have a 6 year old Kenmore Elite top freezer.. I have been dissapointed from day one with this fridge.. the fridge has air vents all over the inside of the fridge. We find that if one of these vents have anything in front of it that something somewhere else in the fridge will freeze. Its very frustrating.. I find that I loose allot of fridge space because I am always juggling space to make sure that these vents are always open... very bad design.. sounded like a good idea at the time.. but never again..
May 08, 2012 | KitchenAid Refrigerators
Amana AFI2538AES The refrigerator portion keeps freezing the fruits and vegetables. The chiller control is on the warmest setting and the refrigerator temp is set at 43. I have been raising every once...
Our Amana afi2538aes is doing the same thing. Had a repairman out. He called tech support at Amana. They had him adjust the "thermistors" but it is colder than ever running at 28-30degrees in the fresh food compartment despite being set at 46 degrees. Tech support also recommended installing some sort of "ice bin seal kit to take care of the problem" according to our invoice from repairman. Repairman was told that the ice bin in the fresh food compartment puts cold air out (to keep the ice frozen) which freezes the food in the fresh food compartment. I called Amana and the rep I spoke to said he couldn't find record of this being a problem with the model but tech support told our repairman "we've had a lot of problems with this happening."
Mar 31, 2011 | Amana AFI2538AES Stainless Steel (256 cu...
My vegetables are freezing in the vegetable/meat bin. How can I keep them from freezing?
Check your settings for your thermostat. Turn it down in increment's one letter or one number at a time. Higher letters and numbers normally mean lower temperature. Also, the veg bins have settings also.
Feb 13, 2011 | Kenmore 57029 Side by Side Refrigerator
I have a Kenmore Side by Side Refrigerator Model 363.9554780. Vegetables keep freezing in refrigerator both in crisper baskets and on shelves. Raised cool setting to warmer but still freezing. Other...
your control with the letters turn it to colder for freezer that will shut off some cold air from freezer. try different letters until u can twit it to stop freezing. ok
Feb 12, 2011 | Refrigerators
PSS25S side by side is freezing vegetables. We
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 12, 2009 | GE Profile¿ Arctica® Energy...
Vegetables are freezing inside vegetable bin
Most likely your refrigerator is set at too cold a setting. Just turn the temperature adjustment to a warmer setting.
May 03, 2009 | Refrigerators
Follow up to question: meat & veg tray freezing food on new side by sid refrigerator
with very littlle ice cream I would set freezer temperature to -2 degrees and leave the humidity seting where you have it remember to let the unit run for 24 hours to stabilize then you can make another adjustment. By the way you are not being a pest I don't mind helping you at all, I am a service manager and answer quesitons allo day long.
Jan 09, 2009 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
361 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
