Question about Vacuums
I also have a Hoover upright and I need to replace the electrical cord. I have dimantled the back, where the tools are stored, and the hose. I still cannot find the screws or whatever, to get to the area behind the cord, so I can replace it. I think I will have to take off the bottom too. Has anyone out there tried to do this? It seems crazy. This machine works great so I hope I can also put it back together. Thanks for the help.
  • 530 Answers
Since I do not know your specific model I can only supply you with general instructions. Be aware that most of the time you only need to gain access to the on/off switch to replace the power cord. Also Make sure that you are replacing the existing cord with a comparable one. Vacuum cleaner cords are different from most other types. They need to with stand being run over repeatedly and subjected to a spinning brush that would burn through other types in a matter of seconds.
If you keep that in mind then......
One of the most important rules in the universe is "If it was put together it can be taken apart". I take my vacuum apart just for fun. I will use as an example the most common type of vacuum, an upright bagless. You will need to remove the lower unit. You will find after the top section has been removed four screws, (two on each side), holding the upper section to the lower with two plastic half circles clamps. In most newer vacuums of this type these are the only things holding the two pieces together aside from the hose. The motor housing is usually held together by several screws. Once you get the upper and lower sections separated you will be able to gain access to the screws.
Probably the most important thing I can tell you is to keep track of the screws. Use a piece of styrofoam draw a shape of a vacuum on it and press the screws into it in the area that they came out.
If you need more specific instructions you will have to clarify this with the exact make and model.
Hope this helps.
Posted on Oct 01, 2009
I have a Hoover Deluxe Spin Scrub carpet cleaner that has lost suction. I read the solution by Chris Jones of GoVacuum.com, in which he described the design flaw whereby the tool attachment hose tears at...
A tear in the hose will only affect pick up through the hose when using it to clean furniture, stairs, and such. It will have no effect on the carpet cleaning operation. If the hose cannot be replaced for a while, black electrical tape is one solution to seal the crack.
Mar 29, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Hoover U5465-900 Power Cord Replacement
hello,
Please checck out the following link for finding the manual of ur device!!...Im sure you can find a manual there!..
http://www.hoover.com/CustomerService/Manuals/Default.aspx
Please post back for how things turned or for further assistance..Thank you!!...
Regards!!!...
Jul 30, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
How do you change the power cord on the Hoover u5475-900 Wind Tunnel 6200? Thanks for your help.
This procedure worked for replacing the cord on my Hoover U6425-900. At a minimum, you will need a number 2 Phillips screwdriver, wire cutter, and two electrical wire nuts and electrical tape. Remove the accessory tools from the storage compartment. Remove two screws, these are recessed. Remove the cover from the bag compartment, remove two screws located at top corners of bag compartment. You may have to open the side filter door but the accessory tool storage compartment should be free at this point and can be removed. You should see the power cord and related wiring. If you have a digital camera you could take a photo at this point in case you need a point of reference. Make note of the power cord strain relief routing and length of wire. Too much wire will make reattaching the storage compartment difficult and the routing prevents the cord from being pulled out.
On my model the wiring colors were purple, orange and white. My replacement cord had black and white wires. The orange wire will not be involved in cord replacement. Using the wire cutters clip the purple wire about three inches back from the existing terminal. If present, clip the two nylon wire ties and discard. The white wire will have a crimped on wire connector. Clip the white wire about three inches back from the existing wire connector. The old power cord can be removed by pulling it out from the rear, it should just slide out of the rubber insulating boot. If not use a set of pliers and crimp the boot from the wiring side and push it outside the vacuum housing. If you have to do this make sure you slip the boot over the replacement cord before you insert the new cord back into the vacuum housing. Remove about a half inch of insulation from the purple and white wires and from your replacement cord unless it was supplied with insulation already removed. Use new wire nuts and connect the white wires. Use the other wire nut and connect the purple wire to the remaining new power cord wire. Use some electrical tape and wrap the nuts to the wires a couple of times so they won't loosen. Make sure you route the power cord around the posts as this is the strain relief and prevents the cord from being pulled out. Reassemble and test.
Feb 03, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
How do i use the hose
Here is the link to the Hoover User Manual for your model. It shows how to hook up and use the hose and tools. This should take care of your needs.
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Feb 04, 2010 | Hoover SteamVac F5914-900 SpinScrub...
How to remove attachment hose to unplug
The vacuum to the dirt cup, whether from the floor, or from the tools comes solely thru the hose. You need to check the hose for internal obstructions/blockage, from the open end all the way to the entry to the dirt cup. Here is the link to the Product Manual: http://www.hoover.com/pdfs/manuals/U5172900.pdf
I recall the hose connects to the back of the unit with a 1/4 turn lock. so try to turn the hose collar at that connection 1/4 turn counterclockwise, then pull it off. If any other qustions, let me know.
Oct 16, 2009 | Hoover U5172900 Fold Away Widepath Bagless...
Need to replace cord on hoover u5720
un do all screws on back of vac replace cord screw back together
Feb 11, 2009 | Hoover U5720-900 WindTunnel Upright Vacuum
Connect or disconnect hose on upright vacuum
The hose has to be connected to engage the suction. To test this, is there suction in the hose when you turn the vacuum on? If so then the hose needs to be connected.
Jan 31, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
How to replace power cord on Hoover WindTunnel upright vacuum
The aforementioned solutions probably never even attempted this fix on this model. The handle does NOT need to come off. but the 5 screws on the front housing DO: 2 above the light and 3 below it. Then to get the colored housing off you need to access 2 screws on the underside that are beneath the agitator roller. To do that, obviously the 4 screws holding the bottom plate need to come off too. Here's a link to a schematic that might help as you attempt to do this, (assuming that you still do!) http://www.elkypro.com/hoops2005/vacuum_parts/hoover/U5461-900.html
Once you have the main body housing cover off, then you can access the 2 screws atop of each trunnion cover that holds the motor assembly cover halves together. If you've made it this far, then gently pry apart the motor halves keeping even as yo do. Now you can see all the wiring necessary to cut and splice. Happy cord replacing! As for me, I am headed for the store, as I am not so sure I can remember how to get the darn thing put back together. But it was fun taking it apart!
Apr 15, 2008 | Hoover U6616-900 WindTunnel Bagless...
Replacing a fraayed and twisted power cord on a Hoover windtunnel upright
ok so I took this vaccum apart completely except for the electrical and motor systems. It seems to me that without dismantling both of these systems on the vaccum you can't replace the power cord. And I wouldn't recommend taking them apart unless you know what you are doing since replacing the power cord seems to require cutting the old power cord and soldering the new one onto the old terminals. All in all its probably easier to get a new vaccum altogether.
Dec 13, 2007 | Hoover U6616-900 WindTunnel Bagless...
Repplacing power cord on Hoover Wind tunnel (not self propelled)
Hi
This is HARD and you NEED electrical knowledge and IF NOT UP TO IT YOU COULD CAUSE PROBLEMS TO YOUR SELF AND OTHERS.
You do not say what the problem is with the cord.If is it damaged then it needs to be replaced with a new one.and then above applies.
Take Care as to what you do.
SAFETY FIRST---ALWAYS
Hope this helps
Jay
Nov 17, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
123 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
