It was working fine yesterday. When I got home I took some things from the freezer and there was nothing wrong. This morning when I opened the freezer everything was thawed and running on the floor. Refrigerator is not working either. Everything getting hot. Have not heard motor come on this evening.
Try unplugging refrig for a few min , then plugging back in . This will reset the adaptive timer and at least get the refrig working . The adaptive timer , is located in the control panel . Pt # 4388932 . To replace this board , remove the knobs and pro the top of the panel outwards . Remove the 4 screws holding the panel ( 2 are on the inside by the light bulb ) . You should now have access to the board .
After changing the water filter the refridgerator leaks from the bottom only a puddle and about once...
(More)
After changing the water filter the refridgerator leaks from the bottom only a puddle and about once a day.
freezer is not pulling water into the ice maker, but water is available from front door...
(More)
freezer is not pulling water into the ice maker, but water is available from front door dispenser.What should I check?
