Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
The washer does not spin but will drain; husband put it on its side and we can see that the gear assembly between the motor and pump box is shattered broken. Can we just replace this part; does this sound like the problem?
  • 5,911 Answers
The part you are referring to is the motor coupling. This is a very simple and inexpensive repair. The following link explains step-by-step how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The part number is included in the link I provided. You can purchase a replacement on line at appliancepartspros.com for about $11.
NOTE: It is not adviseable to lay the washer on its back or side. The gearcase (transmission) has oil in it and it will leak through the breather hole in the top of it. The repair is performed with the washer case removed and in the upright position.
If you have any questions, please let me know. I hope this helps you.
Posted on Oct 01, 2009
  • 51 Answers
Yes this is your problem it is called a motor coupler and p/n is 285753a very easy fix
Need Help! Washer fills,aggitates and drains but doesn't start to spin,motor is running. What is odd is that if I unplug the washer and plug it back in,it will start spinning. What is causing this? ...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If it will drain but won't spin the problem is likely in the transmission. "Neutral Drain Assembly".
See the Whirlpool / Kenmore Service manual for top load direct drive washers.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
When ours had a similar problem, we looked at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) and noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 15Oz of gear oil (auto parts store) , remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Most likely the torque from the motor starting when you un-plug and re-plugging the washer is causing the cams to connect with the main spin gear allowing the washer to spin.
Jan 21, 2011 | Kenmore 22422 Top Load Washer
Kenmore top loading washer model #110.26952690 won't spin but will drain.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26952690
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
See the Whirlpool / Kenmore Service Manual for these washers to see how the Neutral Drain Assembly works.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
See the following
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
It is a messy job and may seem daunting but it's not that hard and much less expensive than having a repair person come out and recommend a $170 transmission.
Jan 29, 2010 | Kenmore 24872 Top Load Washer
Pump works, but tub won't spin
This is the Whirlpool PDF on installation and maintenance of direct drive washers.
If everything else works OK,, including the drain, and the timer moves, the problem could be in the transmission / gearcase.
If you lift the lid, put it down again and the washer begins to spin, or only the drain worksw the problem is likely in the transmission "Neutral Drain Assembly".
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again.
The Sears site for your washer may have a sub-component section on the gearcase with a part number for the Neutral Drain Assembly repair kit.
The top agitator uses a plastic 1/2" drive bolt. A 1/2" socket extension works well.
You can also see this site for removing the transmission.
ILLUSTRATED DESCRIPTION OF REMOVING CABINET THRU TRANSMISSION.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
With ours, all told, it cost less than $30 (including new 80-90 weight gear oil) vs. about $170 for a new transmission.
The job is a bit complicated and messy but not too difficult.
Dec 18, 2009 | Kenmore 22422 Top Load Washer
It will not spin, fills, washes, drains, but does not spin
This is a Whirlpool PDF on how these washers operate. It has a detailed section on how the transmission works.
It also has a troubleshooting guide.
Dec 11, 2009 | Kenmore 22422 Top Load Washer
Washing machine will drain but is not spinning. It makes a funny loud sound only when it is suppose to be spinning
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin. One side of the motor drives the pump for draining and the other side drives the transmission for agitating and spinning.
If the washer will drain but won't spin the problem is likely in the transmission "Neutral Drain Assembly".
See the Whirlpool / Kenmore Service Manual for top load direct drive washers, in particular the section on how the transmission works.
See the following for how to remove the cabinet, pump, motor and transmission. You don't have to remove the spin tube.
Nov 23, 2009 | Kenmore Washing Machines
Motor runs, water drains but tub doesn't spin. checked lid switch but that works fine.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again. The Sears site for your washer may have a sub-component section on the gearcase with a part number for the Neutral Drain Assembly repair kit.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt.
Nov 19, 2009 | Washing Machines
Kenmore top load year and half old, washes but will not spin my clothes
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
It your washer is only a year and a half old, I'd check the warranty first.
You may be able to get it fixed by Sears.
If not, there are a couple of things to check.
If the washer pump drains (and you hear the motor), the timer is directing power to the motor to reverse itself and spin the pump. (timer, motor and pump should be OK)
If the washer neither drains nor spins, the problem points to either the Lid Switch (not too expensive or hard to fix) or the timer.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is an excellent description by GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch.
If the problem isn't in the switch, and the Timer continues to move, the problem is likely in the transmission.
We had the same problem:
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt. You don't have to remove the drum.
WITH APPOLOGIES TO AMERICAL APPLIANCE.COM, DESCRIPTION OF REMOVING CABINET THRU TRANSMISSION.
If the cam that should have a spring doesn't, or the others look damaged, the washer won't go into spin mode.
Sep 28, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80 won't spin
The following has some assumptions.
1. The timer goes through it's complete cycle.
2. If you lift and lower the lid, does the washer go into spin.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If the washer pump drains (and you hear the motor), the timer is directing power to the motor to reverse itself and spin the pump. (timer, motor and pump should be OK)
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode. Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Pull the transmission.
remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (16 oz.) of 80-90 weight oil.
Remove the transmission cover.
Pull off the spin pinion.
Carefully remove the clip from the main drive gear (metal with white gears.
Under it are a number of cams (the instructions with the kit show where each one goes.
Carefully put everything back together and hopefully your problem is solved.
Sep 19, 2009 | Kenmore 24032\24036 Top Load Washer
My kenmore washer makes a rapid clicking sound during the spin cycle. replaced the coupler but it didn't fix my problem. clicking starts at the end of the rinse cycle when the washer starts to drain...
It's possible that the main drive gear (plastic) is stripped or the Spin Pinion (Whirlpool made them out of plastic for a couple of years) is stripped.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Check the Spin Pinion and main spin gear.
Sep 19, 2009 | Kenmore Washing Machines
I hav ehte Kenmore 70 series model 22722. It seems to drain, but my clothes are still wet?
Please see GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
Sep 19, 2009 | Kenmore 22422 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
335 people viewed this question
Dan Webster
Dan Webster
Sal De
