Question about Panasonic Lumix DMC-LS80 Digital Camera
Camera cuts on & off with new fresh batteries. lens goes in & out.
    Scholar:
  • 96 Answers
Try starting it in playback mode, see if same thing happens.
Hope you are using new Alkaline batteries, some cheap batteries will not power the camera properly.
This type of fault is usually caused by a lens problem.
Over 95 percent of lens problems are from Knock damaged or sand/grit in mechanism. if it has had damage to the lens or sounds "crunchy" when lens moving, then It will need to be serviced by an experienced technician.
Phone Panasonic customer care and find out where the closest Authorized service center is.
Cheers.
Posted on Oct 01, 2009
My olympus tg 310 is stuck with the lens open and won't come on at all even when a fresh battery is installed
If the camera is within warranty, return it to where you bought it. Common fault with a few different brands, to do with a lens open sensor within the lens assembly itself. Maybe allow the camera to dischage without the battery for a few hours and see does it power on with a new battery. Also chack the battery, if it has bubbled it a dud, and check the battery contacts within the battery compartment.
Jun 05, 2012 | Olympus TOUGH TG-310 Digital Camera
The lense won't open, it comes up saying system error and switches off.
Hello and welcome
The most common cause for a Lens error:
Misaligned Lens rings
Sand and grid wedged in between the lens and the barrel.
Dropping the camera
Ran down battery
The following solutions are there by which you may Fix the lens error
  • Firstly you can try removing the batteries and replacing it with a new set of fully charge ones
  • If the batteries ran down while you were taking photos with the lens extended, you might also get this error. Remove the the memory card and replace the batteries with a fresh recharged set. Try to power on the unit with the fresh set of batteries while the memory card is removed
  • Connect your camera to your computer using your USB DATA cable which came with the camera. Once the camera gets power in this mode, the screen should stay off, hence, supplying the lens with more power to push or pull out/in
  • Place the camera on a sturdy table with the lens pointing to the ceiling. With a fresh set of batteries installed(Do this without a memory card) hold down the shutter button while you power on the unit
  • Now, you can either use a compressed air canister to blow around the lens area. This will result in the sand or dust particles to be blown out of the area between the lens and the barrel. Or, you can use a vacuum and and carefully place the nozzle around the lens to out the particles
For more solution by which Lens error can Recover Here you Go. It will help you out more briefly
I hope this solution will helpful for you, Anymore help, I am here to help
If It is HELPFUL then your token of appreciation as Four Thumbs which are given below to this solution will be esteemed.
Thanks & Keep Visiting FixYa
Mar 30, 2011 | Sanyo Xacti VPCX1200 Digital Camera
My camera won't charge, i plug it into the computer throught the USB & the camera lights up like it's actually charging but after a cpl hours I took it off the USB & as soon as i cut it on it cuts...
The C1033 does NOT charge batteries. By plugging it into the computer you've actually drained the batteries faster since the camera has to spend juice communicating with the computer (even if only to say it has nothing to say). Put in a fresh set of batteries, and next time don't leave it connected to your computer.
Mar 26, 2011 | GE C1033 Digital Camera
Error message: "Lens error, restart camera" unable to get it to work Have powered on & off several times. Also removed batteries and powered on several times all to no avail.
There are 2 fixes I know for this you can try.
1. Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
2. If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. You don't have a memory card installed, so turn it off, slip in the sd card and turn it on one last time.
Jun 01, 2010 | Canon PowerShot A560 Digital Camera
I can only take a few pictures on my camera before it either shuts itself off and/or won't turn on again. When I try to turn it on the red light flashes but the lens doesn't extend, and then the light...
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
If your cam use manufactors rechargeble batt.:
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Oct 27, 2009 | Kodak EasyShare C330 Digital Camera
When cutting the camera on,the lens open up, get
The problem you describe is frequently battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing into the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 12, 2009 | General Electric A835 Digital Camera
Camera turns on then immediately turns off
Quick turnoff is normally a symptom of low battery power. Make sure that you have fresh/charged batteries in the camera. If fresh power doesn't solve the problem you will need professional service on the camera.
Bill B.
San Antonio
May 12, 2009 | Olympus Stylus 400 Digital Camera
Kodak Z885 will not power on
Remove the battery
Contact KODAK:
Apr 30, 2009 | Kodak EasyShare Z885 Digital Camera
Fuji FinePix S500
try using it with fresh pair of fully charged batteries.
Jul 24, 2008 | Fuji FinePix S5000 Digital Camera
Panasonic Lumix DMC-LS80 Digital Camera Logo
81 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
